Question about SanDisk Sansa e250 MP3 Player
Yeah i reset my ipod
It worked perfectly
but when i unplugged it everything went black again
can u email me asap @
annaiskicking@yahoo.com
and tell me whats sup
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
Tip
Will this work on a samsung Myshot II phone I have cricket service and my phone...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Mar 15, 2010 | T-Mobile MDA
Ipod crashed, sad ipod face, do i have to get a new ipod? i already went to apple support. doesn't work. ??
There are a few last things you can do. Try entering diagnostic mode by holding the center and left buttons together on bootup. You can also try to see if itunes will recognize it when connected. If so, try to do a restore.
Dec 29, 2009 | Apple iPod MA446LL/A MP3 Player
My ipod wont play on my ihome
no you cant reset. call apple they will send one free
Oct 25, 2009 | Apple iPod nano
My ipod got erased and now my computer won't recognize it
try to format it with your comp.it will erase everything but it will reset your ipod to its factory settings.if you need i a guide on formating it email me and i will write one for you.email=gamecrazy944@yahoo.com
Jun 30, 2009 | Apple iPod touch
Kenwood iPod Interface
I have a Pioneer Premier Deck in my van and I get the same problem I just unplug it and plug it back in
Mar 06, 2009 | Kenwood eXcelon KDC-X579 CD Player
PHONE UNLOCK MASTER CODE
ive forgotten the phone lock code for my mobile its a sony ericsson k700i could you help at all i need it asap is there a master code for it ?  my EIMI:-35400800764305-4-27   email me on itsasif0074u@yahoo.com
Jan 19, 2008 | Sony Ericsson K700i Cellular Phone
My Computer and iTunes does not recognize my iPod
hold down the middle button and the Menu button until the apple icon came up on my iPod. At once, the iPod icon returned to my desktop AND on my iTunes window. Works great now. Just like nothing happened.Good Luck!!!!!!!
Jan 11, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 80gb black
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Dec 12, 2007 | Apple iPod MA446LL/A MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
