Question about Acer Aspire 5610-4648 Notebook
Replacement part for charger plug in on laptop.
A friend of mine has An Acer Aspire 5610-2762. The insert for the charger is broken. Is there a place I can get a replacement or is this made into the motherboard?
  • Acer Master
  • 13,433 Answers
The plug for the charger? its soldered into the motherboard. it requires a full disassembly of the laptop.
Just need to find a replacement for it.
you can try contacting http://www.acerparts.com/ with the laptop details for the power connector / plug
you can also look for it on www.ebay.com
computer repair shops should be able todo the job, really no need to replace the whole motherboard, just the plug. Also check is the cord of the power adapter broken? I had to take my power adapter, the black box in the middle of the cord from the wall to the laptop, one cable had came loose inside the power adapter, worked perfectly after I resoldered it in place.
Posted on Aug 11, 2008
My Acer Aspire won't recognize the battery charger. I plug it in and nothing happens. After I unplug and re-plug it back in several times, sometimes my computer will recognize it and will start to...
Try wiggling the plug around a bit to see if you can get contact. You could also try borrowing a power supply if you know someone with the same machine to isolate the problem.
Oct 16, 2013 | Lifetime Acer Aspire 4810TZ-4011...
Laptop charger gets disconnected
Is the Acer E1-571 charger broken? if so, you need a new replacement charger to support the Acer laptop works.
In order to confirm the where is the question, please kindly try it with another similar charger to confirm if the laptop still works.
Aug 12, 2013 | Acer Aspire E1-571-6650 Laptop
Low battery warning
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Battery
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called "Flashing the BIOS" where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
Adapter
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
http://support.acer.com/us/en/default.aspx
http://www.solarum.com/2010/01/03/acer-aspire-battery-not-charging/
Jul 14, 2013 | Acer Computers & Internet
Power is plugged in , battery is plugged in not charging with 0% available
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Replacement Acer Aspire 6930 AC Adapter 90Watt 19V 4.74A
Nov 12, 2012 | Acer Aspire 6930 6930g 6930z 6930zg Laptop...
2 ac adaptors have stopped working on acer laptop
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.
If it still can't work, perhaps the charger you bought is a dead one, just contact the seller to get a replacement one after all you have used it for about a few minutes. If you don't believe in that seller, just contact them for the refund and go to other vendor for a new adapter. I recommend the following one for you:
http://www.chargerbuy.com/replacement-acer-aspire-5739g-ac-adapter-19v-4-74a.html
http://www.chargerbuy.com/replacement-acer-aspire-5738-ac-adapter-19v-3-42a.html
Oct 26, 2012 | Lifetime Acer Aspire 5738PG Replacement...
Acer aspire 5332 plugged in but not charging
it sounds like one of three things:
1. Battery itself no longer functions
2. Laptop Charger has inadequate amperage
3. The motherboard is defective (most likely).
If you have another battery, or a friend with the same battery, you can try that first (and someone else's laptop charger).
Take the battery out. Unplug the charger from the computer. Press the On button for 30 seconds. Then plug the charger in. If it works, then put the battery back in and you're in business again.If it doesn't work, the most likely cause is the laptop charger. Use a new one to confirm:
Replacement Acer Aspire 5332 AC Adapter 65Watt 19V 3.42A
Oct 23, 2012 | Acer Aspire 5241 5251 5332 5334 5338 5516...
My acer 5735 won't hold a charge. Seems to charge (green light)
if it doesnt hold a charge its degraded and will need to be replaced . people dont realise that keeping a laptop plugged in damages the battery
Jan 10, 2010 | Acer Aspire 5735 Notebook
Acer Aspire 5570z
don't worry about it! A lot of chargers blink. Mine does, it just means its charging, and no not having a battery won't affect it
May 08, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5050 Charger Recepticle broken
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 05, 2008 | Acer Aspire 5050-3242 Notebook
ACER ASPIRE 3690
That's happened to mine today, I had to lift the left plastic square and just tap the spare metal bit to select things, I think you can buy replacement parts, but a friend of mine thinks you have to buy the whole touchpad.
Aug 20, 2008 | Acer Aspire 3690-2196 Notebook
Acer Aspire 5610-4648 Notebook Logo
130 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
