About Multimedia Audio Controller
When i tried to make the system volume higher it said that you have no audio device.What should ido now.
  • Anonymous Dec 15, 2008
    I need a driver for creative labs multimedia sound controller.
  • Anonymous Jan 29, 2009
    i need acer 97 driver
Sound card
Posted on Aug 13, 2008
I cannot find correct driver multi media audio controller using windows7
You can download the device drivers from MSI WEB support site, select your model motherboard Windowa 7 drivers to download :- http://www.msi.com/index.php?func=downloadindex
Mar 02, 2013 | MSI : K8N NEO4 Platinum SLI/S939/nForce4...
Multimedia audio controller
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
if you dont have a motherboard disk
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name audio driver you might have to try a few times to get it right
hope this helps
Jun 29, 2012 | Computers & Internet
Lost Multimedia audio controller,Multimedia controller,multimedia controller andMultimedia video controller. Please if you can help?
Try this, go to control pnel, select sound, audio and make sure your audio device is displayed in the Sound playback and Sound recording field, if it is not listed in the drop down you will need to reinstall the driver.
You can go into the device manager to reinstall the driver for your audio device or from the CD that came with your system or from the manufacturer web site.
I hope this helps.
Good luck and have a fantastic day.
May 24, 2011 | Computers & Internet
Yellow question mark symbol on multimedia audio controller in device manager, there is no audio output in my laptop. sound ana volume control windows looks in hiding conditions
the question mark means the device is without support right click on the mark and remove it from your system allow your operating system to re-install it and see if that solves your problem.You can also choose re-install driver if you would rather try that first
Jan 28, 2011 | Computers & Internet
My problem here is.. my computer wont produce music..and i thnk its because of the multimedia audio controller.. can smeone send me a link on it?? motherboard is... p4vmm2
May be your audio device and speaker problem,do all the steep
Check from task menu bar bottom right side corner check the volume icon at (bottom right corner)task menu bar. Ensure that check off onthe mute, or
. Volume is MUTE / Low (in Volume Controller).
. Audio drivers have installed.
To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers).
6. If not, insert the motherboard CD, browse>select audio driver>install with audio driver.After completion, restart computer and check. If same ,i will give the sugetin to purchase to purchase usb audio drive shibuda_26.jpg
Hope it will help you.
Dec 29, 2010 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
Missing multimedia audio controller
what do mean of missing multimedia audio controller? the one that speaker icon on the lower right of the monitor or driver for the multimedia? Go to control panel then sounds and audio devices then on the volume check the Place volume icon on the task bar... hope this will help
Nov 03, 2010 | Computers & Internet
hi try to remove all drivers in program files and in device manager then try to install all drivers again
Sep 01, 2008 | EliteGroup P4VMM2 Motherboard
No Sound... Multimedia Audio Controller Issue
i have a dell dimension 8100 no audio device the multimedia audio controllers has a yellow question mark ive try fixing but cant
May 09, 2008 | Dell Dimension 8100 PC Desktop
Multimedia audio controller device driver
hi,
i install audio driver but not able to control volume and saw in taskmanager that a yellow mark is on multimedia audio controller .then i install this HD audio drver from realtek at it is working.
thank you for appropriate informaton
ranjan
Apr 20, 2008 | Acer Aspire 5610 Notebook
I have a problem with multimedia audio controller
please help me i need to download multimedia audio controller for free can you help me solve my problem
Feb 24, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
