Question about HP Pavilion dv6000z Notebook
Not powering up
My laptop won't start. I got a low battery signal yesterday, plugged it in right away and the screen just went black! It won't power up plugged in, what can I do?
  • 326 Answers
Sounds like a problem with the charger or the battery on the laptop, if the battery is no good you should still be able to use it with it being pluged in, is there a led indicator on the adapter? if its not on try a fuse to start off with, after that id try a different power supply
Posted on Aug 11, 2008
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Laptop is plugged in. Notice on screen that battery was low, even with it plugged in, and now no power lights on. Adapter light is still on indicating outside power supply on. Removed and reinserted...
The batteries do go bad overtime and will no longer hold a charge but the laptop should still work as long as the power cord is connected. If it still does not work with the power cord connected then it is most likely the power cord, these can go bad, but make sure that the power is securely connected and that if it is plugged into a power strip that it has not been turned off, try another outlet just to rule it out as well.
Jan 22, 2010 | Dell Inspiron B130 Notebook
Ok i have a HP Compaq Presario CQ60 Notebook PC AMD Athlon Dual-Core QL-62 2.00GHz 64 bit. So yesterday 9/23/09 i plugged my laptop into charge shortly later my screen went black. I closed the lid opened...
this might be some problem with ur power settings for ur laptop...
Better change it to default in order to reset every power settings..
Go to control Panel,
Go to Power Options,
Now Select the power scheme as ALWAYS ON
Then apply it & click ok..
Its done..
This wud be simple power scheme problem that generally comes...
Hope this works u out...
Sep 24, 2009 | HP Computers & Internet
Advent 8315 Screen blank when powered up
did you check to see if that was the correct serial number of the laptop that you got back from the repair center
Aug 21, 2009 | Computers & Internet
Screen went black,but still on...turned it off...now won't start up.
All Dell laptops have a similar design flaw (in my opinion). The socket where the power cord plugs in to the laptop is probably loose. Use a toothpick or something to check it. Don't use anything metalic. If the socket moves easily then it has probably come loose from the motherboard. You may want to take the laptop to a computer repair shop to have the power socket soldered back to the motherboard. If you have the knowledge you can do this yourself but I don't suggest it. Laptops have a LOT of small parts. Hope this helps! Thanks!
Jun 01, 2009 | Dell Vostro 1510 Laptop
Toshiba satellite M55 not turning on
Either the battery is faulty, or the charger is faulty.
Check the fuse in the mains plug, or even the power point you are using could have a bad connection.
Test using a lamp that you know works or a radio or something and try the charger in another outlet to find the fault.
May 24, 2009 | Toshiba Satellite M55-S135 Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Insprion 600m Reddish Tint when on Battery Power
hi there,
you are probably not getting enough power source from the battery or the battery is getting old and not charging fully or holding its charge ,is my guess good luck..try a new battery...
Jan 22, 2009 | Dell Inspiron 600M Notebook
My Ibm T22 wont boot up
Try removing the battery and unplugging the computer. Then put the battery back in and plug the computer in and turn it on.
Jan 08, 2009 | IBM ThinkPad R51 Notebook
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion dv6000z Notebook Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
