Question about Lexmark E232 Laser Printer
Lexmark E232 blue light constant, no printing
Hi, The blue light (top) remains on, not flashing, and even when I press continue, my printer will not print. ┬áDo you have any advice for me? Thanks! [email protected] Mary Gerritsma
  • joegrandmont Nov 15, 2008
    flashing blue light
HI, I solved it by applying my best problem solving skills, relying on some information on various websites, and not giving up! Mary Gerritsma
Posted on Aug 12, 2008
SOURCE:
When putting it on all lights are flashing one way ,at the same time as a results the printer doesnot want to print because one light should be on to show that it can print.
All service errors are indicated by all lights flashing as the primary notification or code. Please press the continue button to display the secondary error message or code. The secondary code indicates an area or function which has the error.
For further assistance, please contact Lexmark Technical Support.
Jan 30, 2012 | Lexmark E232 Laser Printer
All the alarm lights on printere is flickering.The printer is not printing, no paper jam
If you see that all lights on the printer are flashing, that indicates an error on the printer. Please press the continue button to see the secondary error code. The secondary code will indicate the another light sequence indicating specific problem on the printer.
Apr 30, 2011 | Lexmark E232 Laser Printer
Hi, My Lexmark E232 printer is on but will not print. The light second from the bottom is orange. Help!!
That second from the bottom orange light indicates a paper jam. Press Continue to resume printing once all the jammed pages are cleared from the paper path. Press Continue twice quickly to see the secondary error code. See "Secondary error codes" on page 69 of the user manual for more information.
Here's a link to the manual: http://www.lexmark.com/publications/pdfs/e230/eng/ug.pdf
Mar 21, 2011 | Lexmark E232 Laser Printer
Why are all the lights flashing on my e232
If all lights are flashing,it indicates an error on the printer. Please press the continue button to seethe secondary error code. The secondary code will indicate the another lightsequence indicating specific problem on the printer.
Feb 11, 2011 | Lexmark E232 Laser Printer
All of the lights are blinking in unisom and the printer ill not print
If all lights are flashing, it indicates an error on the printer. Please press the continue button to see the secondary error code. The secondary code will indicate the another light sequence indicating specific problem on the printer.
Jan 12, 2011 | Lexmark E232 Laser Printer
Toner is changed but toner led flashingr
The flashing toner light indicates that the photoconductor kit needs to be replaced.
Use this Lexmark Part# : 12A8302 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door (press button on left side).
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter to enable continued printing.
Jul 21, 2010 | Lexmark E232 Laser Printer
Hi There Lexmark E232. Cartridge more than half full, but top blue Led is on, and yellow (second from top)is flashing! Not printing. Can you assist please?
Do a test print directly from the printer, just press the blue lit button.
Look for the Toner AND Photoconductor bar graphs.
The Photoconductor may well be at the end of its life.
Apr 10, 2010 | Lexmark E232 Laser Printer
Page Count Report for a Lexmark E232
Print test page direct from a printer - press Continue ("Diamond button").
Nov 23, 2009 | Lexmark E232 Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
E232
I have the same problem. At least not it's printing but the lights still on. But while researching on the Lexmark Website I see that this printer has a recall. Check the website for additional details.
Sep 30, 2008 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
545 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
