Question about Dirt Devil Vacuums
My Vacuum keeps cutting off after just a few minutes of use
    Novelist:
  • 97 Answers
You probably have a clog that is overheating your motor and tripping the thermal cutout. Check all air hoses and inlets for clogs. If all of your air pathways are clear, you most likely have a bad motor bearing, also indicated by a high-pitched squealing sound. If that's the case, it would require a motor replacement; which is not usually economically feasible.
-R
Posted on Aug 11, 2008
I have the same model, and the switch is faulty, keeps cutting out. Replace the handle assy, 2LW4010000
Posted on Oct 22, 2013
2 Suggested Answers
6ya staff
SOURCE:
silver top
  • 566 Answers
SOURCE: dyson vacuum cuts off
hi this sound like a familiar problem of the motor o/heating due to lack of ventilation ? check the filters ok? remove the cover concealing the roller brush/beater and check for clogging at the underneath and housing clear it out properly easier to remove/lift out roller ? also clear out the clear bucket dust collector and most important the cone that fits into this canister has a cylindrical honeycombed/small holes(looks like hundreds? ) use a small pointed impliment to poke out all!!these holes as these are relative to vacuum within cylinder so if not clear ? motor no vent and result is no/poor vac and o/heat then thermo switch kicks in and shuts down till motor cools hope this helps best wishes from uk
Posted on Oct 31, 2008
Dyson Vacuum cleaner cuts out after a few minutes use
sounds like you have a blockage in one of the hoses and it's making your machine to over heat and cut out,check for blockages
Nov 06, 2012 | Vacuums
My vacuum cleaner will run for a few minutes and then shuts off. The plug light on the panel blinks. I thought the motor was shut, but after a long time it will turn on again, but again, only for a few...
I know nothing about your particular vacuum, but many vacuum cleaners these days have
safety cut out's, which causes the motor to do exactly what you describe. Sadly blockages, faulty switches, over stretched cables, carbon brushes etc could also give similar symptoms, so sounds like a job for the repairer on this occasion. Get a quote first if you can.
Feb 06, 2011 | Electrolux Epic 6500 Vacuum
Dyson dc07 keeps cutting out after few minutes
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 15, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
After a few minutes the hoover stops. After waiting a few minutes it runs again but the problem keeps repeating
You haven't stated the exact make and model but in general what you're experiencing is a safety feature: your machine is overheating and cuts out to prevent a fire.
Check that the bag isn't full and also check the moving parts for anything which is preventing proper operation. I can't give you specifics as you haven't even said whether it's a cylinder or an upright cleaner.
DO NOT continue to use your vacuum cleaner until you know what the problem is. In it's present state it's a fire risk.
Oct 05, 2009 | Electrolux Vacuums
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
CUTTING OFF
Ok What is probably causing the problem is an internal error inside the vacuum. What I recomend you to do is take it back where you bought it and tell them what ever is wrong with it.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Hope it works! Tell me if you have any questions later on!
Jun 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Vacuums Logo
1,117 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
gggg
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
