Question about Tally Line Matrix T6215 Printer
Cant print from pc
Power went out and now cant print from pc . I can run self test from printer. any reset thanks
I was using a parralell port i ended up removing the network card and that solved my problem
Posted on Aug 12, 2008
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
How to reset passbook printer ibm 9068
When you turn on the power, the microcode version and then the release level of the microcode are presented on the LED display, and the device runs the basic assurance test and then resets the hardware.
If you need configuration changes done such as how the printer communicates and such, then you need to know all the functions and codes for configuration changes.
The self-test runs only in the self-test state. To place the printer in this state and start the self test:
1. Make sure the printer is turned off.
2. Press and hold either Start 1 or Start 2 on the operator panel; then turn on the printer. Keep holding the button at least until "00" is displayed on the LED.
Note: The left 0 blinks, and the right 0 stays on.
3. When 00 appears on the LED, the self-test "00" is ready to run. Insert an 8.5x11 Letter sized piece of paper into printer.
4. Press Start 2 to run the self-test "00". This will print the Configuration of your printer.
Feb 28, 2013 | IBM 9068 A01 Passbook Business Printer...
My HP C3180 printer has unprinted data stored in it. How can I delete all this data without printing it ?? Thanks,
What i would suggest would be to reset your printer:
***Perform a hard reset***
Follow these steps to reset the product.
-Turn the power off.
-Unplug the power cord and the data cable from the product.
-Unplug the power cord from the wall outlet.
-Reconnect the power cord to the product and wall outlet, and then turn the power on.
-Print a self-test page again and check the print speed.
-If the test page prints in about 30 seconds, the reset has corrected the issue. If that does not resolve your problem, check the link below and follow it as per your issue.
Good luck,
Rodrick
Apr 22, 2011 | HP Photosmart C3180 All-In-One InkJet...
How to test the MD 1300 , also look on how to get error codes...
One test you can run is the self print test. Discount the printer from your computer. Load a single sheet of paper and the CMYK cartridges. Turn on the printer. Press and hold the "reset" button until the lights begin to flash. Release the "reset" button and the printer should do a self print test.
Dec 26, 2010 | Alps MD 1300 Thermal Printer
My hp Photosmart 8250 printers black color doesn work but other colors working great.. What is wrong with my printer .. when I try print some text or something where is black color I cant do it.. And my...
first make sure that there is no issue with the black cartridge, but how..?
just print a self test page, using the steps provided in the weblink below... if it printing black color, there is no issue, we follow 2 steps to resolve it..
first print the self test using this link..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00024690&cc=us&lc=en&dlc=en&product=443024#N1809
if the self test does have the back color,
power cycle the unit and use the following link to reset the printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00391891&cc=us&lc=en&dlc=en&product=443024
hope this resolves the issue..
Narendra Tirunahari
May 22, 2010 | HP - HP Photosmart 8250 printer
Cant i run a stand alone self test on my deskjet
o check printing capabilities, print a Self Test Report. In order to print such a test follow the next steps:
  1. Turn the printer on and place media in the tray.Set the width adjusters to fit tightly against the sides of the paper in the tray.
    1. Press Power button while opening and closing the printer access door four times.
    2. Release the Power button.Your printer will print a test report.
Oct 28, 2009 | HP DeskJet 3740 InkJet Printer
My X1240 will not scan copy or print even with the computer.The only thing it will do is that the power light will come on....
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself.
Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault. The issue may be a communication problem, or perhaps a software conflict.
Oct 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
I see the printer when i hit print...paper won't feed...the printer will not pront
It seems there is a possibility of a problem with the printer itself, or perhaps the cartridges. You should first self-test the printer. Since we are unsure where the problem exists, we must do eliminative troubleshooting to rule out parts of the printing system. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
However, let us know the operating system that is installed on your computer.
Apr 16, 2009 | Office Equipment & Supplies
Good-morning.... I have a HP 5610 All-In_one. I am getting a background shadow or hue (like a double print, if you will. I have cleaned print heads through the on-board service. Went through these steps...
Hello
First of all disconnect your USB Cable from the PC
which will make your Printer as a stand alone PC
Then try to Print Printer Self Test Page on a fresh page without any folds or wrinkels
this will print one self test page
and then put this page on the top of the printer i.e on Scanner Belt
and that will alifn your cartridges after the scan
After this connect your Printer to PC
go to
Start >> Printers and Faxes >> choose your printer and
Right click and Properties and Click "Print Test Page"
I hope this will resolve your query
all the best
Do rate the Solution, so we can help others accordingly
Thank you in advance
Jan 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Tally Line Matrix T6215 Printer Logo
54 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
