A hardware problem was encounter while trying to initialize you modem
    Champion:
  • 232 Answers
UNINSTALL COMPONENT MAKE SURE IT WAS NOT DAMAGE DURNING INSTALLATION, PAY A CLOSE ATTENTION TO DETAIL TO THE BOARD AND THE MODEM ITSELF MAKE SURE IT WAS INSTALLED PROPERLY. THEN REINSTALL SOFTWARE
Posted on Aug 11, 2008
Internet connection error 734 extra initialization command does not work.it leads to another error 692.
692 - Hardware failure in port or attached device.
This behavior can occur if any of the following conditions exists:
  • The modem is turned off or malfunctioning.
  • If you have an external modem, the serial cable is incorrectly wired.
  • If you have an external modem, the serial cable is not securely connected or has open connections.
  • The serial port or multiport adapter on the RAS server or client is malfunctioning.
  • The handshaking options for the modem are incorrectly configured.
  • The modem is unsupported, or the chosen emulation may be incorrect.
  • The modem .inf files become corrupted or the modem driver becomes corrupte
To solve this problem, use the appropriate method:
  • Reset your modem. Consult the documentation for information about how to reset the modem.
  • If you have an external modem, make sure that you are using the correct serial cable. For more information about requirements for proper cabling, refer to the "Cabling Requirements" section in Dial-Up Networking Help.
  • If you have an external modem, make sure that the serial cable is connected securely.
  • If you are using a pin adapter to connect your external modem to your serial port, make sure that the pin adapter is wired properly for modem communication. For example, a 9- to 25-pin adapter for a mouse does not work properly with an RAS serial setup.
  • Test the serial port or multiport adapter, and replace the adapter if necessary.
  • Make sure that the handshaking options for the modem are configured properly. Consult the documentation for information about the different handshaking options that are available for your modem.
  • Contact the modem manufacturer to see if any setup and initialization information is available for your modem. Also, check the latest Windows hardware compatibility list (HCL) to make sure that your modem is supported.
  • Use Device Manager to remove the modem. You can do this in safe mode or in normal mode. Restart the computer in normal mode. Windows will redetect the modem and reinstall the correct drivers.
May 12, 2011 | Computers & Internet
Replaced modem and can't get it to work
Download the correct drivers here: http://www.conexant.com/support/md_winxpinfo.html
Uninstall the modem in device manager, then reboot. On the boot when the new hardware found initiates stop the installation do not let it complete. Now install the drivers...
Sep 22, 2009 | Conexant (RD01-D850) (RD01D850)
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Tata USB MODEM (Epivalley) locked. Need unlock code.
dear dreamskape
use given following tool and ENJOY
u can download from this link
http://www.4shared.com/file/108063568/33ce4d25/min_unlock_modem_sx1080.html
If any problem found u can mail me or call me.
Mar 28, 2009 | Computers & Internet
Pctv hardware failed to initialized
contact pinnacle as it is a driver conflict and download uniblue driver scanner from http://www.liutilities.com/products/driverscanner/
Jan 11, 2009 | Pinnacle VIDEO CAPTURE| PCTV PRO (PCTVPRO)
There is an Error 692 : There is hardware failure in your modem.
Dear!!!
Error : Hardware failure in port or attached device.
Solution :
1. Check to make sure the correct modem is selected in the dialer.
2. Make sure there are not multiple modems installed.
3. Uninstall and reinstall the modem.
4. Make sure that no other programs are using your modem. Fax software, Supervoice, etc...
5. Ctrl-Alt-Delete, if you see RNAAPP loaded,
6. Send to manufacturer?
Dec 14, 2008 | Multitech Systems MultiModem II MT2834BL...
Re initializing a data/Voice Modem
Go to start,control panel,hardware device and see if your moderm is still there. If so, right click on top of the moderm uninstalled. Turn the computer off and back on. At this time, it should come back on and look for the modem.Answer yes to found new modem and reinstall the modem. this should work
please check you modem setting. it could be that your setting also is not correct.good luck
john
May 27, 2008 | Computers & Internet
1800hg 2wire modem problem!
try to use another power adapter with the similar power output aside from what came with your 2wire modem if you have one, if it works fine that means the original power adapter is busted and i think it is also covered by the warranty, get a replacement from the store where you purchased it.
oh by the way, it's normal for all of the lights on your modem or router to blink when you initially power on the hardware, usually your hardware will perform a system check for several seconds to verify if there is any problem after that, several lights if not one should remain steady like the power light, the other lights on the other hand like the ethernet(LAN) or the wireless(WLAN) will most likely flicker from now and then because it indicates activity between the modem and the device/s attach to it.
Hope that answer your concern about your 2wire modem.
May 09, 2008 | 2wire HomePortal® 1800HW Router...
Can't get modem to work if I use the USB connection
Your computer is attempting to find the network connection through your LAN port. Your best bet is to reconfigure your network settings to seek its external network connection through USB, or better still, obtain a router(I personally recommend linksys wireless/basic routers due to stability), and simply use the ethernet connection through it. While this is bypassing the initial issue, it is also saving yourself a lot of hassle when it comes to retooling the PC's settings on the USB connection.
Jun 04, 2007 | RCA Thomson Digital Cable Modem (DCM305R)
Computers & Internet Logo
David Payne
David Payne
