HP Pavilion ze2000 Monitor is dim
HP Pavilion ze2000 PC Notebook has a dim monitor. I can barely see the screen activity. I have attached a CRT monitor and it works fine. My cat slept on the keyboard last night, no moisture problem though (that would have been yecht!...).
Also, if I push the monitor lid closed switch nothing happens, no blanking of LCD or CRT. If I set it to go into standby when lid closes, -that works. So, if it were a switch problem would not the monitor be blank, not dim? AND, why would it work for standby?
So I figure it's an inverter problem or a backlight problem. I am about to open it up and check connections, etc. What is the difference between the inverter and the backlight?
Any help would be appreciated.
  • bazmin Aug 11, 2008
    my laptop monitor is very dim but works ok ihave to hold a torch to the screen to see my mouse pointer. i bought it brand new only 4 months ago so it should still be under guarantee. i have also changed my desktop picture a few times but still no better can you help.
  • Chazz Lavely Aug 11, 2008
    I checked the inverter connection, it seemed good. I did not go so far as to open the LCD panel further to check the backlight. That seemed more complicated. (Your link is very helpful).
    However, how can I tell for sure it's the backlight and not the inverter? From what I'm reading the symptoms are the same.
    Scholar:
  • 101 Answers
Yes, this is what happens when the backlight goes out.
This will give you an idea of what is involved in replacing the backlight. You can find a replacement backlight here, or on ebay, just take your current backlight(s) out, measure it or them, and buy replacements of the same measurements. It doesn't have to be for the same model laptop as long as the CCFLs (cold cathode florescent lamp) are the same size.
Posted on Aug 11, 2008
6ya staff
SOURCE:
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
Hp dv6 - 1030us. very dim screen. can barely see. external monitor works fine.
Look are a key that says "fn" on it. Hold that key and press F8 to turn up the screen brightness.
Aug 03, 2011 | HP Pavilion dv6-1030us Notebook
I have a hp pavilion ze 2000 and when I turn it on the two lights by the scroll and caps lock key blink and the screen stays blank. Please help me!
Hello, I'd start by hooking up another external monitor, that way you can rule out if your video/graphics card is working. If the new monitor works that means your video card is fine and you'll need to look at replacing your current monitor Good luck, mpawlak908
Oct 18, 2009 | HP Pavilion ze2000 Notebook
"no signal" message when laptop is plugged into projector
There is a key on the keyboard that has blue text on it. Something to the effect of LCD or CRT. With the monitor connected and turned on, press and hold the FCN KEY as well as the LCD/CRT key. While holding the FCN key keep hitting the CRT key until the image transfers to the external monitor
Apr 17, 2009 | HP Pavilion ze2000 Notebook
The Backkight on laptop monitor doesn't work HP ze2000
That is the inverter, you just need to get the exact numbers off of that, and search on Google to find a new one.
Here is a little more on the inverter
http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/
Paul
Apr 13, 2009 | HP Pavilion ze2000 Notebook
Screen problem inquiry
Yes You can use the Monitor From your PC,
Just need to find the port where you would connect the Monitor on a Notebook
Give me the Model number of you Notebook Ill Give you the Details...
Jul 18, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion
plug the monitor to the port, then press Fn+F4 few times.
Apr 08, 2008 | HP Pavilion ze2000 Notebook
Computers & Internet Logo
1,177 people viewed this question
Ekse
Marvin
Marvin
