Question about Philips Magnavox MWR10D6 DVD Recorder
Recording from directv
Yesterday I was able to record from my directv dvr to a disc using the MWR10D6. Today an error is saying this program cannot be recorded. This error is a copyright message. Why the change? Can it be fixed?
  • Old Folky Aug 19, 2008
    I get the same message intermittently when I'm recording from tapes
    made on my own camcorder. It goes away after a few seconds and doesn't
    appear to affect the final recording in any way.
  • fushia6 Aug 21, 2008
    I have the same problem as well! Up to this point I had no problem recording from my camcorder to the DVR but now I get the same messge. What can we do?
Well I don't have that problem anymore since I unplugged the thing for about a minute. It's working fine now.
Posted on Aug 21, 2008
Won't record in HD. DVR shows to be recording, but when you click on the programmed HD channel (the one that's supposedly recording) it's blank and says "searching for satellite". Just started recently.
Have you tried rebooting the DVR and removing the card that came with the DVR if its one that was provided to by one of the satellite company's such as Directv or Dish.
Nov 30, 2009 | Directv HR22 500-Hours HD DVR
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
DVD+RW playback problem(s)
same prob with the shows freezing up
with a DVD+/- RW disc the amout of time keeps dropping because with every recording process the disc loses a life you can burn those disc 200 times before they become useless so the disc might be beyond the life peroid or bad
my prob is with the DVD-/+R disc tho and i figured it out the disc was bad
for the grinding noise if its hi piched its normal thats the disc spinning up to read or write speed
if that not the case something is rubbing in there and that might explaine the writting errors
**DISCLAMER**
the disc manurfacture dose not take resposnablity for defective disc and any loss they have caused(if the data is lost)
Aug 23, 2008 | Philips Magnavox MWR10D6 DVD Recorder
DVR recording problems
i am not terribly familiar with these systems but there are probably two sattelite in ports on the back of the receiver, one is a line for watching one program or recording, the other strictly for recording, one of these inputs is probably no longer receiving signal
Jul 08, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Error recording
It is the disc type that your using or the lens of the disc. Although this unit can use x16, dont. Use x8 and make sure it just says x8. I can assure you it will work hands down. I have this unit. It runs strong since jan 06
Jan 14, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Philips Magnavox MWR10D6 DVD Recorder Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
