Question about Cameras
S600 : Beeps 3 times when i try to turn on - Cameras
  • 4 more comments
  • Anonymous Sep 30, 2008
    Beeps three times and then turns off gain...
  • Anonymous Oct 19, 2008
    same issue, camera beeps 3 times and shuts off
  • kelzd Oct 22, 2008
    My shutter is slightly open and when i try and turn it on it just beeps 3 times and does nothing
  • Anonymous Dec 16, 2008
    when i want to put my S600 on, it works for 5 seconds and than it beeps 3 times.
    so weird!
  • SANCHO PANZO Feb 01, 2009
    I have the same issue. Was working fine a few days ago. Now... beep beep beep and turns off.
  • Anonymous Mar 04, 2009
    wont even turn on properly, start up screen then bleeps 3 times.
I had the same prob. the shutter was stuck out. all i did was put slight pressure on the shutter (dont touch the lense) and it clicked back into place. no more beeps
Posted on Apr 27, 2009
Hey Jack, we currently have 3 Zebra s600's, 2 in use and 1 spare. I've recently added some zp550 printers on the 2 computers that have the s600's and screwed up the drivers for the s600s. I...
1. Reset the printer - to return the printer configuration to factory default values,pressFEED and PAUSE at the same time while turning the power On (l).
2. Download this Maintenance Manual for Zebra S600 and follow the troubleshooting steps from page # 66.(table 3-2) Printer stops, pause and paper/ribbon LEDs both on / Printer stops, pause LED on and paper/ribbon LED flashing.
3.Uninstall / Re-install the zebra printer driver .Use this revouninstaller to remove the driverClick here to download the driver for Zebra S600 .
Oct 14, 2011 | Zebra Stripe S600 Thermal Label Printer
When turned on camera beeps 3 times & the zoom
Does it take standard disposable batteries or a rechargeable pack?
If the first, check they are inserted correctly as per the illustration in the battery compartment or instruction manual section on inserting batteries.
If the second type, recharge the pack.
If problem continues check Troubleshooting section of manual or online at Samsung's website.
Sep 20, 2011 | Samsung Digimax S600 / Kenox S600 / Cyber...
I have a EX-S600 Casio. When I turn it on the lens pops out, I get 3 audible beeps, hear some grinding and then the lens retracts and the camera shuts off, it all takes about about 6 to 7 seconds. I've...
If you hear a grinding then it's toast. Any issue with the mechanism would cost more to have repaired than replaced. This usually happens as a result of the lens being bumped while open or opened in a bag. Or, a contaminate such as sand inside the body of the camera.
Mar 28, 2011 | Casio Exilim EX-S600 Digital Camera
Put new batteries in and it does not power up anymore. Beeps 3 times and nothing happens.
Are the batteries fully charged?
Does it work with the old batteries?
Chances are that the batteries are faulty. If they are in warranty it shouldn't be a problem replacing them with new ones.
Apr 03, 2010 | Samsung Digimax S600 Digital Camera
When it is turned on it beeps 3 times and then turns off
Problem could be a bad battery. The beeps you're hearing could be a signal that power is low or almost dead. Assuming that your charger and the power/outlet in your house is fine, you could take a chance by buying a generic battery on the web. E-bay.com is a great source and usually they are pretty cheap. Try going to E-bay and type in your brand and model along with the word battery. By the way, I do not endorse E-bay nor am I affiliated in any way with the site or any of it's vendors. I just know they have many items such as the one you might need.
I Can Fix it
Aug 14, 2009 | Samsung Digimax S600 Digital Camera
Lens,not close properly
If it is your camera's time to go, there is no helping that. Most likely a grain of sand has found it's way into your camera mech. You can turn your camera on and off while banging it on the counter gently, but it is unlikely you will succeed, due to most lens parts use a sticky lithium grease for lubricant.
Nov 13, 2008 | Samsung Digimax S600 Digital Camera
Samsung Digimax S600 is stucked in off position
I've had this with a diff model of Samsumg (V10). The problem with mine was that the lens wasn't opening, which was causing the beeping. I held the camera with lens facing down and when I pressed the power button I lightly tapped the camera against the palm of my other hand. The lens extracted.
I have more problems with the lens now but that may have something to do with me dropping it later:(
Aug 12, 2008 | Samsung Digimax S600 Digital Camera
I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
May 20, 2007 | Samsung Digimax S600 Digital Camera
Cameras Logo
571 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
