Trying to upgrade the memory on my Acer Ferarri 3400 Notebook but can't find the location of the second memory module. The user guide says that there are two memory slots but there is only one under the memory cover.
    Champion:
  • 232 Answers
THERES ONE MEMORY LOCATION R U UPGRADING BOTH CHIPS OR JUST ONE, MOST SYSTEM ONLY COME WITH ONE CHIP U HAVE TO ADD ONE IN THE SAME LOCATION TO UPGRADE OR GET THE HIGHEST SINGLE SLOT CHIP U CAN GET UR HANDS ON,I WOULD SAY CALL TIGERDIRECT AND TALK TO SOME OF THERE SELLS ASSOCIATES THAT WILL PROBABLY BE THE BEST SOURCE OF INFORMATION ON HOW THE SYSTEM IS CONFIHURED
Posted on Aug 11, 2008
    Master:
  • 397 Answers
Some times the factory fitted memory is under the keyboard or somewhere similarly inaccessible to the average user. If the memory slot you have found is empty just use that one for your upgrade.
Make sure you but compatible memory by using the memory cofigurator at crucial.com
http://www.crucial.com/store/listparts.aspx?model=Ferrari%203000%20Series
Try using the system scanner to confirm what is in your machine.
How to upgrade RAM for compaq nx9010
Upgrading memory helps improve system performance. By following the step-by-step instructions in this document, you can successfully upgrade random-access memory (RAM) for all HP and Compaq notebook computers. While the graphics might not match your specific computer model, the steps will work. Read all instructions carefully before attempting memory installation. NOTE:Do not purchase memory modules until you know the type of memory used by the computer, the maximum amount of memory the computer can use, and the memory slot configuration. How to find the product number of your HP notebook PC To order replacement internal components such as memory, you must know the exact product number of the computer. For many HP notebook PCs, the product number and serial number are printed on a label on the bottom of the computer. Also, the product number and serial number are printed on the outside of the shipping box that you received when you purchased the computer. Product number locations can vary, and there are numerous methods to find the product number of your notebook. NOTE:A general family name may be imprinted on the case near the keyboard or on the frame around the display screen, but this does NOT provide sufficient information for ordering replacement parts. Finding memory information for your computer model (amount installed, maximum supported, and type of memory) Important memory upgrade information is in the specifications document for your HP computer. To find product specifications, browse to the Product Information category on the support page for your computer model. Refer to the Memory section within the product specifications document for memory information specific to your computer. Among the information listed, take note of the following items. It will be useful when purchasing memory and when performing the next steps. Amount of memory installed - The current amount of memory installed on your computer. Go to Verifying how much memory can be added to verify the amount of memory currently installed. Maximum memory supported - Subtract the amount of memory already installed from the maximum amount supported by the system to determine how much memory to get. You can also buy the maximum amount allowed and replace the currently installed memory. Once you know the maximum for your system, check Maximum memory supported by operating system to see how much memory your version of Windows will support. Use the lower of these two numbers as your maximum memory. Type of memory (including speed) - It is recommended to get the same type of memory (same size, same speed, same manufacturer) for each slot. For best performance, get the fastest memory that the motherboard supports. CAUTION: Due to the variety of possible configurations, some motherboards might not be able to properly configure memory if the array of small outline dual in-line memory modules (SO-DIMMs) contains a SO-DIMM that is not from the same manufacturer, has a different CAS latency value, or has a different density value (high and low used together). Make sure all SO-DIMMs meet the requirements of for the motherboard (the information listed in product specifications), have the same part number, are from the same manufacturer, and meet the basic memory requirements for your motherboard. If not, make sure that you can return the memory if it is not recognized by the system after you install the new memory. Determining where your memory is located Memory is installed inside of the memory module compartment, which is located on the bottom of the computer on most HP notebook PCs. Some HP notebooks are designed with the memory module compartment under the keyboard. If the memory module compartment for your particular notebook is located under the keyboard, HP recommends that you contact an HP-authorized support or repair facility for assistance in ordering and replacing the memory. Verifying how much memory can be added Prior to upgrading memory, you need to verify how much memory you currently have installed to determine how much memory can be added. Using your User Guide for memory installation instructions The User Guide contains helpful information and pictures showing how to remove and install memory in your specific notebook model. A copy of the User Guide is stored on the hard drive, and it is also available for download from the HP Web site. Installing memory Notebooks are designed so that additional memory can be added using a Phillips screwdriver. Use the following steps to install memory in an HP or Compaq notebook computer. After reviewing the following steps, if you are not confident in performing the installation yourself, contact an HP authorized distributor for technical assistance. NOTE: If someone other than HP installs or upgrades the memory, any damage caused by the memory and/or by a person trying to install or upgrade the memory is excluded from coverage under the product warranty. The customer assumes all risk and liability for damages for any such installation or upgrade. NOTE: Important! You might find that your HP or Compaq computer is able to support a physical installation of 4 GB or more memory. However, this maximum memory might be further limited by the operating system not being able to address the full range of physical memory. 32-bit operating systems, such as 32-bit types of Windows 7, Vista, and XP, can address approximately 3.3 GB. This limitation is present on all 32-bit hardware and 32-bit operating systems and is not limited to HP and Compaq PC systems or Microsoft software operating systems. Verify the computer is turned off, not simply in sleep or hibernate mode. Disconnect the A/C power adapter. Turn the notebook over and place it on a firm surface. Remove the battery. Use a Phillips screwdriver to remove the cover on the memory module compartment. (See the User Guide for instructions on how to remove the memory for the specific computer. If you need help finding the User Guide, refer to the section Locating your User Guide for memory installation instructions .) With the cover removed, and before you touch the memory, ground yourself to discharge any static electricity. NOTE: To ground yourself, and discharge any static electricity, place one hand on the case of the computer and touch the other hand to a metal surface or grounded object, such as the metal part of a lamp. To release the memory, use a small wooden tool, or fingernail, to spread the clips holding the ends of the memory in place. One side of the memory will rise when the clips are released. Remove the memory and place it in an anti-static bag. Remove the new memory from the protective anti-static bag and hold the memory by the ends. Place the gold contacts into the connector (bracket) and gently, but firmly, press the memory into place. The clips will click when the memory is properly seated. Replace the cover and tighten the restraining screw. Replace the battery and A/C power. Turn on the computer and allow it to reconfigure and recognize the additional memory and improve performance. Buying memory HP recommends purchasing memory directly from HP, an authorized HP dealer, or from a reputable computer parts supplier. You can buy computer memory from most local electronic stores and online shopping sites (such as www.crucial.com or HP , for example). Many of the online sites partner with HP to automatically suggest the correct type of memory based on the model of your computer. Before purchasing memory, make sure you know how much memory you need and what type of memory is compatible with your computer.
Aug 05, 2012 | HP Compaq Business Notebook NX9010
How do I access the memory boards in the Acer Aspire 5315 Notebook pc?
1) Remove ALL electrical power to the laptop. The AC adapter (Charger) and Battery.
2) Open the laptop, press the Power On button, and hold it in for a count of 5 seconds. (Removes residual power)
3) Close the laptop, turn it over. Remove the 'Thermal Door'. This is a large panel on the back of the laptop. There are several Philips head screws to remove, going around the outer perimeter of the panel.
http://members.aceweb.com/gregg1/acer/Inside_Acer_Aspire_5315.html
Here you will see the panel removed, and the ram memory compartment marked.
Handle a Ram Memory module ('Stick') by the body, and refrain from touching the gold plated contact pins on the bottom.
The body is coated with a see-through protective plastic.
Your body carries Static electricity, and Static will fry out (Short Circuit) the hardware components inside a computer.
There are two ram memory slots.
There are two metal clips that hold a ram memory module in place.
One on each side of the ram memory module. Look at the sides of the ram memory module, where the metal clips press against.
Each metal clip has a rounded 'knob' that fits inside a Notch, on the sides of the ram memory module.
Use the fingernails of one hand, to ease out on the 'knob' of one clip, while doing the same to the other clip, with the other hand.
(Ease the clips out away from the ram memory module)
Once the clip's knob is free from the notch of the ram memory module, the ram memory module should slightly pop up on one side.
Lift the side that comes up, to a slight angle, then keeping it at that angle, remove it.
NOTE*
DO NOT lift straight up on the ram memory module, or you'll damage the connecting pins in the ram slot.
(And the gold plated contact pins on the ram memory module)
To replace line the ram memory module up at the angle you removed the old one.
Slide it down in the ram slot.
Then gently spread the metal clips, and ensure they are seated in the notches at each end of the ram memory module.
For further questions please state in a Comment.
Regards,
joecoolvette
Nov 03, 2010 | Acer Aspire 5315 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I would like to add memory to my acer 5315 notebook. I have taken the panel off the back, but I don't know where to put the new RAM in. I can only find how to replace memory, not to add more.
The ram location is right where you are looking. There are two memory slots available for ram. They are staggered one on top of the other. Release the side pins and the module will pop up at a 45 degree angle . Pull the module out in the direction and replace at that angle, then push the module down in place. You may only have one memory slot filled at this time, Therefore there would be an empty slot to fill.
Jun 01, 2010 | Acer Aspire 5315 Notebook
My acer ferarri 1100 is overheating extreamly. Even cant touch the surface. This is happening only if I I change power profile to high preformance
You can get a USB cooling fan for laptop that will help with overheating.
Also to avoid laptop overheating, follow the information from this link.
May 19, 2010 | Acer Ferrari 1100 Notebook
Location of memory slots
Hi.There are a set of instructions that we need to follow for the upgrade process.You can increase the amount of RAM (random access memory) in the notebook with an optional memory module approved by Compaq.The notebook contains 2 memory slots, one of which is accessible for an optional memory module upgrade.Please refer to think link and select the Hardware Upgrade option in the list in the file which will guide you thru picturised views for helping in the memory upgrade.Link is : http://h10032.www1.hp.com/ctg/Manual/c00090108.pdf.
Please let us know whether this help or whether you need more help
Mar 16, 2009 | Compaq Presario R3000 Notebook
Trying to add memory
Here is a link that gives step by step with pictures. Be sure to properly ground yourself by either wearing a wrist strap or touching metal surface when handling the module
http://www.crunchgear.com/2008/08/28/how-to-add-ram-to-the-acer-aspire-one-netbook/
Feb 27, 2009 | Acer Aspire One AOA150-1029 Notebook PC
Memory upgrade
First thin you have to remember is if you want to have to memories in parallel...Then the new one should be of the same size and frequency(ex:133Mhz,533Mhz..etc.,)Then folow these steps:
  1. Turn off the computer and remove all power cords from the computer system.
  2. Locate the panel used for access to the memory modules. This is generally located on the bottom of the laptop computer. Refer to your laptop instruction manuals for locating the panel.
  3. Remove any screws that the panel in place and place somewhere safe to prevent losing it.
  4. Remove the panel from the laptop and set aside.
  5. If replacing or upgrading an existing memory module, remove the memory modules by undoing and module clamps and gently lifting the edge of the module to a 45-degree angle and then pulling the module out of the slot.
  6. Align the notch of the memory module with that of the memory slot and gently insert the module into the slot at a 45-degree angle.
  7. Once all the pins are in the slot, gently rotate the module down flat until the clamps lock into the module into place.
  8. Replace the memory access panel onto the laptop computer.
  9. Replace any screws or fasteners that hold the panel in place.
  10. Replace the power cord and power up your computer system.
Oct 13, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
