Question about HP Photosmart 2575 All-In-One InkJet Printer
I can't print. The printer has a blue screen with an error message: Error:0xc1ab0001. In the front of the printer next to where the paper is loaded has a green flashing camera.
  • Anonymous Sep 11, 2008
    Same problem. It's been happening intermittently, but always resoved it by turning power off, then on again. The document was already in the que, so the printer would just spit it out. However, now it just completely stopped, showing the error code: Error: Oxc1ab0001, and will not print after several attempts. Is my printer shot now or what?
    Thanks!
Same problem, tried the power off and on and reset of cartridges, still the error message comes up...
Posted on Aug 18, 2009
  • 44 Answers
Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
Posted on Aug 11, 2008
2 Suggested Answers
SOURCE:
SOURCE: blue screen: error
I do have the same problem, help!!
Posted on Aug 03, 2008
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Error Code 0xc1ab0001 What do I do?
The "Oxc1ab" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Jul 05, 2010 | HP Photosmart 2575 All-In-One InkJet...
Error messages and printing problems
Paper mismatch errors occur because the printer scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the printer, the printer reports a 'Paper size error'.
Try to adjust the printer and envolopee settings..
Regards,
polysandy
Apr 06, 2010 | HP PSC 1610 All-In-One InkJet Printer
Error : Oxc1ab0001
All the best
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 11, 2010 | HP Photosmart 2575 All-In-One InkJet...
My LaserJet4250n Printer keeps printing a page recurrently. Except the former job is cancelled Manually, it prints the previous instead of the currently sent job. Moreover,it displays the following...
I think what is happening is when you get the error, the printer automaticaly reprints the page it was on when it got an error condition that makes it think it didn't print the page correctly. The clearing paper path message comes up after it thinks it had a jam. Displaying load plain paper could be because either the printer is not configed for the correct type of paper you have in the tray you are trying to prin form(push the green check button, arrow downt to paper handling and see what your trays are set for.) Also there is a blue switch on the tay(looking for front of tray it will be on the right hand side of tray rail) the switch says standard or custom. The switch should be in the standard position.
Are you getting any errors or jams, if so, tell me what they are.
Feb 25, 2009 | HP LaserJet 4250n Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Error message on 4050n printer "manually feed hp tough letter"
What error message is on the display?
To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
Jan 20, 2009 | HP LaserJet 4050n Printer
Blue screen: error
Apr 27, 2008 | HP Photosmart 2575 All-In-One InkJet...
HP Photosmart 2575 All-In-One InkJet Printer Logo
6,188 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
