Question about Saeco Royal Professional Espresso Machine
Bean Grinder Turned my Royal Prof. on this morning and the grinder started up all by itself. It turned for about 1 second then stopped, then 4 seconds later it turned for another 1 second then stopped. It went on like this until I turned it off 2 minutes later. I turned it on again 30 minutes later and the same thing happened. Any assistance gratefully received.
  • 515 Answers
Hard to say when i´m not have the machine in front of me, i think it can be the printed circuit card.
Posted on Aug 11, 2008
Hdo i remove the grinder on asaeco royal
How to remove the grinder in a Saeco Royal Professional fully automatic cappuccino machine. Of course make sure the machine is fully off and unplugged before servicing it. Taking a lot of pictures as you disassemble it will make it easier to reassemble it when you are done.
1. Remove the water tank, driptray, dregdrawer, cappuccinatore., and the bean hopper. There are two Phillips head screws in the bean hopper; you put some tissue in the hole to prevent those from falling into the machine when they come out. Once the hopper is off, remove the grind adjustment lever. It can be pried off, but try to be gentle. I broke it slightly when I did this, though it still works fine. Also, make a mark on the lever and grinder before removing it, so you can put it back together easily at the end.
2. Remove the screws holding the upper housing to the base. There are two under the water tank, one in the compartment under the bean hopper, one in the front corner above where the dregdrawer goes, and one behind the front panel under the steamer wand. They are all Phillips head screws except for the two under the water tank which are T-10 (Torx, or star) screws.
3. Remove the upper housing. This can be a little tricky, because you have to get the steam wand and cappuccinatore plug through their corresponding holes. Just start by gently prying up the front edge of the housing, under the steam wand and the control panel. Pull the housing back, bending it over the cappuccinatore plug, up over the rest of the unit, making sure the steam wand goes through smoothly. Then you'll be able to lift it off the rest of the way. Note that the hose from the water tank will still be attached to the housing, but there should be enough slack to set it out of the way.
4. At this point you can see the grinder. Remove the rubber gasket that sits between the grinder and hopper, and the felt noise dampener. The grinder is held in place by three rubber rivets. They can be tricky to dislodge, but you just have to pull firmly on the grinder to take them out one by one. You can also grab the bottom of the rivet with needle nosed pliers if you need to. To reinsert the rivets, you can push the tip through the corresponding hole and pull on the end with pliers. Try not to move the grind adjustment ring without marking where it was originally, or you may end up throwing off the grind calibration.
5. You should be able to unplug the wires from the grinder. You may need to cut the zip tie holding the wires in place.
6. Follow these steps backward to reassemble the unit once the grinder is replaced. Good luck!
Jun 09, 2015 | Saeco Royal Professional Espresso Machine
How do you change the blade? I bought a new one but can't get the old one off. Thanks
Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.
    • 1 Unplug your Krups grinder from the wall.
    • 2 Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.
    • 3 Put your safety gloves on and then grasp the blade of the grinder with your channel locks.
    • 4 Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.
    • 5 Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut.
Things You'll Need
  • Cloth
  • Safety gloves
  • Channel locks
  • Pliers
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 02, 2011 | Krups 203 Grinder
The grinder grinds too long, then stops and then the bean refill light goes on, ---there are plenty of beans but no coffee being made. I think the grinder is not working somehow. Its a 5 year old Saeco...
The lever under the bean hopper is set to low. Push it all the way to the back.
There is a leverbehind the door in the middle top. Pull it to the minus and try again.
If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 05, 2011 | Saeco Royal Cappuccino Espresso Machine
Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Nov 03, 2009 | Saeco Incanto Sirius Fully Automatic...
Ginding problems, all clogged up
Follow these instructions to put grinder back together...
Items needed to clean grinder
1- #2 Phillips head screw driver
1 Cleaning brush
Prep:
Remove all beans from the bean hopper, vacuum out any
beans that cannot be scooped out by hand.
Remove the front and back screws and pull off bean hopper
container from the machine. (Note: The rear screw is longer
than the front screw.)
Note: Doser adjustment knob is available only on Vienna
Digital and Vienna Deluxe Rapid Steam.
Place screws in a safe place so that they will not be lost.
Cleaning the Grinder Viennas
back screw
front screw
grinder
knob
doser
knob
Before beginning to clean the grinder please be sure to turn the machine off and unplug it from the wall
socket. Grinder Tip: Using an oily bean will cause the coffee to build up quickly and clog the grinder.
Saeco recommends using a medium to dark colored bean that is not oily.
After cleaning the grinder and then brewing a cup of coffee it may take 2-3 grinding cycles for the machine
to dispense coffee.
Step 1:
Remove the black rubber gasket, then vacuum additional beans or grinds from the grinder area (Fig. 1).
Rotate the outer ring of the grinder counter-clockwise until the red line is at the 12 o'clock position (as
viewed from the front of the machine) or until the red line on the outer ring is 180º from the opposite red
line on inner burr ring (Fig. 2).
Lift the inner burr ring out of the assembly (Fig. 3).
Figure 1 Figure 2 Figure 3
Step 2:
Vacuum out any residual grinds from inside the grinder and clean the grinder burrs using the cleaning
brush (Fig. 5). Clean out the grinder coffee chute using the end of the cleaning brush (Fig. 5).
Remove the drip tray, open the service door, remove the dregdrawer and brew group. Gently pull
down the coffee doser door and brush out any ground coffee that may be inside the chute (Fig. 6).
Reassembly:
Be sure that the red line on the outer ring is still in the 12 o'clock position. Place the inner burr ring back
into the grinder making sure the red line on the inner burr is at the 6 o'clock position or 180º opposite from
the red line on the outer ring (Fig. 2). Once the inner burr ring is in place, rotate the outer ring clockwise
until it will not turn any further. At this time the two red lines should be aligned. The grinder is now at the
"0" position. Replace black round rubber gasket (Fig. 7).
Take the bean hopper container and rotate the grinder adjustment wheel to zero (0) (Fig. 8) and the doser
adjustment knob to the minus symbol (-) (Fig. 9). Slide the doser adjustment gear toward the left of the
machine until it stops. (Note: The Vienna Black does not have a doser adjustment knob. Only the Vienna
Digital & Vienna Deluxe Rapid Steam have a doser adjustment wheel.)
Reinstall the bean hopper container being sure to use the LONG screw in the back, then replace the finger
guard using the short screw in the front of the container. Once the bean hopper container has been
reinstalled, rotate each knob through the full range of motion. The grinder knob should rotate from (0) to
(18) and back, and the doser knob from the minus symbol (-) to plus symbol (+) and back.
Place the grinder adjustment knob at the eight (8) position and place the doser knob at the halfway
point between the plus symbol (+) and the minus symbol (-) symbol, or to your preferred settings.
For questions or concerns please contact Saeco Customer Service
at 800.933.7876 or email at support@saeco-usa.com.
Figure 4 Figure 5 Figure 6
Figure 7 Figure 8 Figure 9
Jan 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Grinder setting stops at drip. Can't turn further to espresso.
Another suggestion is while the grinder is off, turn it up side down and rotate the bean hopper from coarse to fine a couple of times. This will clean out grounds that have gotten into the threads and it will prevent the bean hopper from not turning to a finer grind.
If you start to get a clog in your grinder, open it up to a coarse grind for a few seconds. The coarser grind will clean out the chute and then you can turn it down again while it is still grinding.
Dec 15, 2008 | Solis Maestro Electric Burr Grinder
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Grinder is slipping.
  1. take out bean container
  2. disassemble 3 philips screws and take plastic out
  3. rotate the knob to try to get out the upper holder of burr. if it does not rotate than disasemble the knob and the gears(plastic big one is attached to upper holder of grinder, the other is together with knob.
  4. tru to rotate it manualy, with help of extra srews puted in gear holder holes.
  5. when you get it out, carefuly clean it, look for metal parts and stones(wich sometime comes with coffee)
  1. turn on the grinder and attach gently one marker to lower burr during spining. after you stop grinder, look if it is perfect circle marked in burr. if it is not than marked side is higher. you should consider getting it ok by putting adhesive paper under lower burr and check it again.
good luck and carefuly.
Aug 02, 2008 | Gaggia MDF Coffee Grinder
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Saeco Royal Professional Espresso Machine Logo
60 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
