This would be an issue either with the compressor or with the power board I dont see the model number to your unit so im not able to look for a schematic on this unit you would first check that the compressor is running and turning on if its not then you would look at the start relay and the overload located on the compressor if the compressor was running then you would most likely have a sealed system situation in which you would have to call a compressor techncian to diagnose your issue at hand if you have any further questions or happen to have the model number for this freezer message me back Thanks I await your reply Rick
The first thing I would check is condition of the condenser coil. If it's blocked with lint, the compressor will overheat and would not perform properly. In most cases cleaning could help to eliminate the problem. Remove the front and the rear panels and clean the condenser coil from any lint and dust. Wait about 24 hours to see if it works.
If this is not an issue then the cooling system could be low on Freon or the compressor has low capacity. To fix it you have to call a certified technician and it is going to be pretty expensive.
If your fridge is very old it is probably not efficient and it's not worth to fix it. It is possible your local utility company has a reimbursement program to utilize such old refrigerator.
Keep us updated.
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.----------------
If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual
defrost reset procedure. The procedure is as follows: ----
First unplug the unit from main power outlet. Then empty whole unit
completely. Then keep both the doors open. Wait for 24 hours. All the ice collected
on the coils and in the freezer section will get melted. Clean the
water from the sections. Then Connect the power cord of the unit to main power
outlet after 24 hours/.Then set the temperature to normal in both fridge and
freezer section. It will take near to 4 hours to get run in its proper cooling
cycle. Then check, if the problem returns again. Then its defrost board problem. -------------------------
BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------
So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get
required parts from from online sites like:
--- www.repairclinic.com or from searspartsdirect online site. --------- This
should help.Thanks.Helpmech.
The Artic Air Freezer is a commercial freezer. it does not have a refrigerator compartment. The fan is blowing warm air. I don't know how to check the compressor or the freon level.
Are you familier with the Artic Air freezer. The only panel on the back is a vertical plate that is about 3" wide and goes the lenth of the freezer. At the very top and inside where the air comes out there is a stainless plate. I don't see the condensor coil. Is it behind the inside-top plate or under the freezer there is a rectancular 1' X 2' x 1 1/2 " deep pan. I can't see inside it but it feels like there might be a coil in there?
