Question about Vcomm Recovery Commander (804526023624)
Removing the program
Every time I try to install a new program, recovery commander appears and immediately freezes the whole computer. The program is not installed on my computer and I cannot find any trace of it anywhere!! - except if I conduct a search. I deleted every example shown in the window and subsequently cleared the recycle bin but it still appears
  • Anonymous Feb 05, 2009
    my computer will not download anything because of the recovery commander how can i delete this off of my computer
I have the same problem but have tied mine down to Fix It Utilities which were downloaded. If you have Fix It the solution appears to be run Fix it, at the top select 'settings' then on the left 'recovery', then 'recovery commander' on lower top toolbar. Uncheck 'Detect when a set up program is launched....' and that should cure it.
Posted on Jan 20, 2009
  • tjh2233 Aug 18, 2011
    Your the man this was a very good detailed explanation of how to fix the problem thanks a million
  • 34 Answers
Delete the program through.......
Start > control panel > add remove programs > ...... wait and look for the programs installed... remove it from there
Posted on Oct 28, 2008
  • awriterpaul Jan 27, 2011
    Sorry, Mr. Ulysis, but that is the simplistic answer! Recovery commander does not appear in the program lists, so your solution does not work. Any other thoughts? If you look around, you will see this seems to be vexing a lot of people.
Add/Remove Window components
Im not sure which file you are referring to but you could just a repair of the installation
this is fot the master boot record
if there are any other files , settings or programs during the repair process options for these should be available
Insert your Windows XP installation CD or recovery disc, and restart the computer.
Instead of attempting to boot Windows as it normally would, the computer will give you an option to boot from the CD.
Press a key when prompted, then wait for the setup program to load.
Press the "R" key on the "Welcome to Setup" screen.
This will cause the CD to launch the Recovery Console instead of attempting to install Windows XP on your computer.
If you have an administrator password on your copy of XP, then you will need to enter it in order to log in to the Recovery Console.
Choose the installation of Windows XP that you want to repair (generally the only option). Wait for the command prompt to appear, then enter "fixmbr." Press "y" when prompted to let the FixMBR utility overwrite the corrupted bootloader with a new copy.
Remove your XP disc or recovery disc, then type "exit" into the command prompt.
The exit command should cause the computer to reboot, allowing the computer to load the new bootloader file and then continue Windows XP startup as normal.
Hope this helps
Oct 30, 2012 | Microsoft Windows XP Professional
My computer will sometimes get stuck on MicrosoftUpdates-show
Updates immediately take over if you boot in safe mode?
Try turning the machine off in the middle by just hitting the power button to see if it will go to the Startup Repair screen so you can get to the Recovery Console. Let the startup repair run, then if it says it couldn't fix it, get to the Recovery Screen and see if you can run a System Restore and select a Restore Point (date and time) before the update was downloaded. System Restore does not delete your data, documents, music, pictures, videos or programs (unless the program was installed after the restore point you selected). System Recovery on the other hand Deletes Everything and sets your system back to when you first purchased it.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If after the check disk utility you are still having problems then you might have to reinstall your operating system.
May 16, 2012 | Dell Inspiron 530 -Intel® Pentium®...
My computer fails to boot several times and when it does finally get to the desktop, it freezes and then goes off into power saver mode. how do I fix that?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 04, 2012 | Dell OptiPlex 360 Desktop Computer
Can't remove Recovery Commander on VISTA notebook. Does not appear in control panel add/remove programs list. No listing for Vcoomm. No listing under Avanquest. Thanks, Microweb
There is an application called Revo Uninstaller (Freeware). Install it on your PC and then uninstall recovery commander.
Hope this helps.
Dec 08, 2010 | Vcomm Recovery Commander (804526023624)
Recovery Commander
Revo Uninstaller is a very very good uninstaller for removing unwanted programs simply point the program to the file you want to uninstall and it will remove all traces of the program. you can get a free 30 day trial which can be used to uninstall Recovery Comander thanks
Steven
http://www.revouninstaller.com/
Apr 24, 2010 | Vcomm Recovery Commander (804526023624)
I need to uninstall recovery commender
GO to control panel and then go to add or remove programe and then uninstall it.
Nov 05, 2009 | Vcomm Recovery Commander (804526023624)
I am having the same difficulties as you!
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&docname=c00220758&product=12455
If you have compressed the hard disk drive using the Compress drive to save disk space option under the Properties menu for your hard disk drive and have performed a non-destructive recovery or a system recovery, the following error message may appear: NTLDR is compressed. Press CRTL-ALT-DEL to restart. This error message is resolved by following these steps:
  1. Insert the HP Recovery Tools CD or Compaq Recovery Tools CD into the CD drive on the computer and restart the computer.Wait for the HP Recovery Tools CD or Compaq Recovery Tools CD window to open.
  2. Select Run Microsoft Recovery Console , click Next , and then follow the onscreen instructions. NOTE: If you are unable to open a recovery console, follow the Alternate steps .
  3. Press R to repair the Windows XP installation using Recovery Console.
  4. Enter the appropriate number for the WINDOWS installation, for example, the WINDOWS installation could be listed as 3: C:\WINDOWS or 3: D:\WINDOWS .
  5. If prompted, enter your Administrator password and press Enter . If there is no password, just press Enter .
  6. At the prompt, if the WINDOWS installation you selected in Step 4 was C:\WINDOWS, type: cd c:\Or, if the WINDOWS installation you selected in Step 4 was D:\WINDOWS, type: cd d:\
  7. At the prompt, type: attrib -c ntldr and then press Enter .
  8. At the prompt, type: exit
  9. Press the Enter key and immediately remove all discs or diskettes from the computer to allow the computer to restart.The error message should be resolved.
Alternate steps NOTE: These alternate steps work for HP and Compaq desktop PCs with Windows XP and a recovery partition. (M0st HP and Compaq PCs with Windows XP have a recovery partition on the hard disk drive.) These steps do not work if you have replaced the hard disk drive, replaced Windows with another operating system, or repartitioned the recovery partition.You can use the following steps if you are unable to open a recovery console:
  1. Turn on the computer. When the initial logo screen appears, press the F10 key repeatedly until a message about starting recovery appears.
  2. At the Recovery screen, click Advanced Options and then press the Alt and D keys at the same time to go to a command prompt.
  3. At the command prompt, enter the following: diskpart
  4. At the command prompt, enter the following: list volume
  5. Remember the drive letter next to line for the main hard drive; HP_PAVILION or PRESARIO.
  6. To close Diskpart, enter the following: exit
  7. At the command prompt, enter the drive letter followed by a colon (:). For example, H:
  8. At the command prompt, enter the following: cd \windows\system32
  9. At the command prompt, type the following: compact ntldr /u <the drive letter>:\ntldr For example if the drive letter was H, you would type: compact ntldr /u h:\ntldr
  10. Type exit and press Enter .
  11. Click Quit .The error message should be resolved.
Sep 06, 2009 | E-Machines eMachines Desktop PC
Removin progaramme
It sounds like malware. Run a virus scan and a spyware scan.
Sep 10, 2008 | Vcomm Recovery Commander (804526023624)
Vcomm Recovery Commander (804526023624) Logo
2,923 people viewed this question
Top Vcomm Computers & Internet Experts
David Payne
David Payne
Are you a Vcomm Computer and Internet Expert? Answer questions, earn points and help others
