Question about CDA CI592 Front Load All-in-One Washer / Dryer
Trying to find instruction manual for a CDA Ci 592 washer dryer
    Brigadier General:
  • 6,277 Answers
I'm sorry if you are the person who has previously been unsuccessful finding a CDA washer manual on the web because this solution will not assist you ;-0(
However if you are NOT that person you will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on May 01, 2011
Testimonial: "Thank you. Will try your suggestion"
SOURCE:
Want to just use the dryer but can't find the programme. Manual doesn't make sense to me.
Can you be a bit more specific in your question please? Not sure what you are trying to accomplish with your dryer. Are you trying to just do a timed dry instead of a using a setting?
Oct 19, 2013 | CDA CI592 Front Load All-in-One Washer /...
Which make of washer dryer is CI 592 WH
Clearly you do not have a manual- and possibly need to obtain one?
Have a look at the manufacturer's panel, probably on the back- it might give you an indication there.
Now a bit of FixYa/John C added value!
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Oct 08, 2011 | Washing Machines
I have a CDA ci992 with no instruction manual. I cannot get it to JUST dry. I just need to know which setting to put it on. Any chance you can help? I've tried searching for an instruction manual...
Lisa set the time required on the Drying time control right hand side for high temperature up to 130 mins max and left hand side for low temperature up to 90 mins max. Now set the washer timed dial to the drying emblem (3 vertical wavy lines) next to position 8, then finally you need to push in all 4 control buttons on the left of the thermostat. It should now work according to my wife. Dave
Sep 02, 2011 | CDA CI592 Front Load All-in-One Washer /...
Hi, I have a CDA I992 washer dryer in my flat but no instruction manual. Do you Know where I could get one from?
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Mar 26, 2011 | CDA Washing Machines
User manual for cda CI992
Got a cda CI992 with my apartment no instruction manual
can i have one please :-)
Jul 23, 2009 | CDA CI592 Front Load All-in-One Washer /...
I am getting "CI" on the display even with an empty load cycle?
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Kenmore 20172 Top Load Washer
CDA CI592 Front Load All-in-One Washer / Dryer Logo
1,043 people viewed this question
Top CDA Washing Machines Experts
Poppa Maddo
Poppa Maddo
Marvin
Marvin
NOEL
NOEL
Are you a CDA Washing Machine Expert? Answer questions, earn points and help others
