Question about Sharp AL-1642CS Copier
Weird noise no copies
My sharp AL-1642CS works perfect
buy now it has stopped copying and it makes a weird noise i never heard before.
  • 6 more comments
  • rramanand Aug 11, 2008
    No it odes nit intake the paper.
    When I press the copy button it just keeps blinking
    The copier is not feeding any paper.
    The copy button (green one) just keeps blinking
    The problem is still there
    Even after taking of plug and plugging back on.
    I opened and checked all doors and parts but Don't see anything foreign or jammed!
    The noise is a grinding noise
    I already checked the owners manual but it has nothing about my problem
    Manual did not help
  • rramanand Aug 12, 2008
    Okay guys I finally found the problem!
    The problem was my toner cartridge!
    I replace the cartridge and it works perfectly now!
    Thanks for all your help!
    Strange the toner light didn't come up though!
  • rramanand Aug 13, 2008
    The problem was simply the toner cartridge!
    Thanks for all the help!
    Genius:
  • 1,665 Answers
It sounds like moving gears worn or misaligned. Cover must be removed to see their condition and if it is repairable or spare parts needed.
Posted on Aug 12, 2008
  • 157 Answers
Replace the Toner cartridge. That will fix it. The most common cause of this problem is a bad toner.
Cheers
JIgSaw
XoXO
  • 876 Answers
I was ready to give you some suggestions, when I ran into this little review from an unhappy customer with your same machine:
"My unit didn't hold up well at all. Makes a horrible grinding sound. Did some checking and learned this is a "very common problem with this model" and it's an issue they don't suggest you self-repair. I read that as a design flaw. The main drive gear that powers the fuser strips out. Can't get to it easily. Nice features but the copier gave out quickly. "
If the machine is not under warranty, I would do a little research on copier repair. You might find someone who has experience and parts of other machines and can help you. Be careful here, but it's worth a try. Sometimes a vbendor sells and repairs the copier brands he sells.Otherwise, perhaps you can take it into the company's service center and save your self some money on a service call.
Here is their information on obtaining service:
http://www.sharpusa.com/products/FunctionGetService/1,1286,5,00.html
Good luck to you.
  • Sharp Master
  • 2,794 Answers
Do you a clicking noise or a grinding noise when you start it up?
That noise could be your scanner locked up.
Make sure the scanner unlock mechanism is in the unlock position underneath the left side of the scanner section.
Make sure the ribbon cable isn't binding up underneath the scanner. They tend to shift from their positions and can be secured by using scotch tape.
  • 1 more comment
  • Tim Babcock
    Tim Babcock Aug 12, 2008
    That is strange. Sometimes the gears in the auger of the cartridge can bind up.
  • Tim Babcock
    Tim Babcock Aug 13, 2008
    Grinding is common on the machine. It happens in three areas, the scanner section, the fusing section, and the cartridge from time to time. As far as the latter one is concerned, that can happen from using off brand toner cartridges or refilled ones. If you get a cartridge that is genuine Sharp, it is exhanged for free within the six month window.
    Service calls are not necessary for the cartridge.
    If you are making more than 500 copies a day on this machine, that exceeds the recommended daily usage of this machine and will cause the gears to go out faster. Especially in the fuser section due to heat fluctuations.
  • Tim Babcock
    Sharp has been aquiring dealerships throughout the US. This just happened recently in Seattle when the took over a major dealership. There taking over all sales and service on their line in the area. If you check with Sharp USA they can put you in touch with them.
    Sergeant:
    Champion:
  • 248 Answers
A very technical issue...
you can find solution by downloading the manual at this address...
http://www.devicemanuals.com/guide/Copier/Sharp/Sharp-Copier-AL-1642CS-Operation-Manual-TWpVMk5UTT.html
Thanks!
Posted on Aug 11, 2008
  • 594 Answers
Is your machine the multi function system? for like an office?
if so i will give you the link to your owners manual that has a trouble shooting section.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
1-open paper tray, check tto make sure the paper is set correctly, if using letter paper and the tray is in legal it willmake a loud clacking noisse
2-the button is green and there is no message? where is the noise coming from and what type of noise? squeaking, grinding?
  • Sharp Master
  • 19,396 Answers
Try first unplugging power cable for 5 minutes, this often clears the error. Also open all doors and inspect the copier for small pieces of paper or foreign objects stuck inside.
    Guru:
  • 1,894 Answers
Does it intake the paper at least??
in some kind of problems paper alone rolls in and out with out copying.
is that the problem.
please clarify
SOURCE:
I have a sharp AL 1642cs and every time I make copies from the top of the printer my copy comes out with line/strips. What can I do not to get those lines anymore.
The machine that you have is digital the scanglass has somethind on it clean it with windex or alchohol that should take care of it
Jan 27, 2011 | Sharp AL-1642CS Copier
I have a sharp al-1642cs that will not work it just keep flashing L1 can you help
www.cyberscholar.com/sharp/resources/cop_man_soho_AL1642CS.pdf
http://www.service-docs.com/store/catalogue.php?cat=281&exp=0&resultpage=10 L1 00 Feeding is not completed L1 00 Feeding is not completed
within the specified time
after starting feeding.
(The scan head locking
switch is locked)
1.unlock Scanner unit
2. chang connecter
Scanner unit
May 09, 2010 | Sharp AL-1642CS Copier
I have a Sharp AL- 1642CS - broken transfer wire
so does that mean that you were getting blank copies and the transfer wire is broken?
Jun 25, 2009 | Sharp AL-1642CS Copier
Sharp copier makes grinding noise
Contact your dealer for service. You may need to have mechanical parts replaced.
May 05, 2009 | Sharp AL-1642CS Copier
My Sharp Al-1642cs is leaving a black stripe on the paper when coping.
Does the line appear when you copy from the glass? Or is it Just the document feeder. If it is just throught the doc feeder then you have to clean the **** glass next to the main glass. It only takes a small dot to make a line. Hope this helps. Have a nice day.
Apr 29, 2009 | Sharp AL-1642CS Copier
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Nov 23, 2008 | Sharp AL-1642CS Copier
Sharp AL-1642CS Copier, the scanner is jammed
Not familiar with that model but what I would try is to turn off the copier remove the glass and try moving it by hand, then turn it on and see what happens it may have a bad motor
Oct 29, 2008 | Sharp AL-1642CS Copier
Grinding noise
my suggestion is replace the fusing gear and the rachet gear.
Mar 22, 2008 | Sharp AL-1642CS Copier
Sharp al-1642cs
if scanner is not going all the way back you need to ck the home posinson senser it may be dirty.
Feb 05, 2008 | Sharp AL-1642CS Copier
172 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
