Question about Sony KP-53S65 53" Rear Projection Television
KP-53S65 Blue Ghosting
The rear projection Sony KP-53S65 television that I have now has a blue "ghosting" affect to the picture after a short period of burning wire smell. I got down behind the TV and in the center of the back I could smell a distinct burning wire smell and then it eventually went away. After this the picture now how a blue "ghost" image around items in the picture and the picture is not crisp as it used to be. I am the original owner of the TV and it has been taken very good care of since I purchased it in December 1998.
  • Anonymous Aug 31, 2008
    KP-53S65 Blue Ghosting problem
  • Sony Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerKP-53S65 Blue Ghosting - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
Sony kp 51ws510 rear projection has blue ghosting lines
Have you tried calibrating the colour guns , as this usualy cures the ghosting
Aug 04, 2012 | Sony KP-51WS510 51" Rear Projection...
Sony KP-53S75 blue convergence problem...
what about settings cool med warm ? did sumone chage those
Jan 18, 2008 | Sony KP-53S75 53" Rear Projection...
Blue and yellow convergence? problem...power light blinks 6 times
This is a common problem. Its called a convergence failure. You can get all the parts from www.TvRepairKits.com
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
Jan 28, 2010 | Sony KP-51WS510 51" Rear Projection...
My sony projection xbr 57 in hd is ghosting
if it's red, blue, or green ghosts, then you need new convergence chips, stk 392-570, have to be soldered in.
Sep 19, 2009 | Sony KP-57WS500 57" Rear Projection...
My colors wont stay converged
put a convergence repair kit in the set that will usually repair the Issue. You can get the Sony convergence repair kit which works with your model at the following link. The kits contain the replacement parts and complete instructions www.tvrepairkits.net
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Sony kp-48s75, shadow or ghosting picture
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
Jan 07, 2009 | Sony KP-48S75 48" Rear Projection...
Blue convergeance
Can you use a meter and solder? If you I can help you fix it. If not you will need to call a repairman. let me know what you would like to do!
Tim Nolan
Sep 13, 2008 | Sony KP-53S65 53" Rear Projection...
Blue Ghost
You need new convergence ICs . They cost about 10.00 each you will need two. They are located on a large aluminum heat sink with an STK number stamped on them. They will have to be soldered in. If you can solder you will be able to do this repair yourself. Let me know if you need ay additional Info.
Nov 14, 2007 | Sony KP-53S65 53" Rear Projection...
Good Day, Martin Ping;
Picture won't merge? It sounds like your TV has had a failure in the CONVERGENCE CIRCUIT by replacing those IC's should correct your TV's problem.
Good Night and Luck, big IRISH.
Oct 25, 2007 | Sony KP-53S75 53" Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Sony KP-53S65 53" Rear Projection Television Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
