Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
How do you change a chuck on a DW995. I took the center screwn left handed screw out. How do you back the old chuck out? how do you remove the chuck there is no allen key in the center of the chuck
    Champion:
  • 313 Answers
Position the drill to speed one & drill mode.u need a allen key then clamp it the chuck jaw close & tight. hit the allen key with hammer counter clockwise until its loosen. may have to do it any several times.
Posted on Aug 12, 2008
SOURCE:
How to remove a drill chuck from an Hitachi corded drill
How to Remove Drill Chuck
If there is screw in inside center of chuck remove it, it is probably left hand threads so pretend you are tightening it and it will come free. open chuck fully and insert chuck key into holes and hit it with a hammer to remove it.
Oct 07, 2017 | Hitachi Drills
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
Psb18li-2 chuck removal
There should be a screw inside the center of the chuck. It could be a left hand thread. Remove the screw then pull the chuck off.
Mar 11, 2015 | Bosch Drills
I have a Magnetic Drill Press DW 151, and I am trying to replace the chuck. I can not figure out how to remove the chuck. Any help would be nice thank you.
WARNING !! SOLUTION # 1 BY dleemacc_0.jpgDarryel Hubbard
IS WRONG . FOR THE DEWALT
Magnetic Drill Press DW 151I ALMOST DESTROYED A $500.-!,000 DRILL READING HIS ADVICE
THE ABOVE DRILL HAS A 1/2" X 20 THREAD THAT THE CHUCK
THREADS ONTO. LEFT TO REMOVE AND RIGHT HAND TO REPLACE YOUR NEW CHUCK . YOU CAN TAKE A PIPE WRENCH AND AFTER PLACING THE DRILL ON THE SIDE PUT THE PIPE WRENCH AT/ON THE END OF THE OLD CHUCK AT ABOUT 2 o'clock. Once set up slap
the pipe wrench very hard/fast with a suitable hammer . It took about three times to knock the chuck loose and then I removed it with my hands. A little crude but it worked. Have a good one.
Dave Shelby
Jul 15, 2011 | Dewalt DW151 magnetic drill presses
We need to replace the chuck on our Bosch corded drill 1005VSR. We need detailed instructions on how to remove the chuck . Also, how can we order a new chuck?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench 1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 15, 2011 | Bosch Drills
How do you remove the chuck from a dewalt 12 volt dw953 drill
Apr 12, 2011 | Garden
HOW DO YOU PULL THE CHUCK OFF TO GET TO THE GEARS INSIDE SEEMS TO BE STRIPPED OUT WANT TO TRY AND REBUILD MYSELF ITS A DW995 TYPE 4 MOTOR RUNS FINE JUST WANT GRAB.
if its a reversible drill,you open the jaws wide,and undo the left hand threaded screw inside the chuck,then put the the chuck tool in,and use that to unscrew chuck off the thread,right hand thread
Jun 29, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Removing the chuck on a dewalt DC925 cordless drill.
I just changed the chuck on my 18 volt xrp half inch hammer drill,yes first you must remove the torx screw with #15 torx bit,note this is a left handed thread screw,knowing the bad chuck was bad I added some heat from a propane torch to the chuck then making sure it was in 1st gear i took some vise grips and the chuck is screwed on with normal right handed threads,it broke loose (was stubborn but needs a lot of torque )ahhhhhh wat a pain.
Oct 18, 2008 | Dewalt 18 Volt Compact Drill Kit
u need allen key that fit to the chuck. insert the short end to the chuck. tighten the chuck if u can. hold the drill at the edge of the table & smack the allen key counter clockwise. do it again if needed. but before u do it set the speed to #1 position & drill mode.thanx good luck
Jul 17, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
262 people viewed this question
Top Dewalt Drills Experts
Marvin
Marvin
Lance Guthrie
Lance Guthrie
Level 1 Expert
Spud Howell
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
