After using Word (Office 2007) for a time, when I type quatation marks I end up with E (accent grave) nstead of the quotation marks as if the computer has switched from English (Canadian) t French - how do I fix this so I remain ONLY on English?
  • fleming834 Aug 11, 2008
    Hopefully your idea will work. thanks you rmf
  • 326 Answers
Go to your control panel and then go to your regional and language and make sure all the setting are set to english, on the languages tab then details make sure you only have 1 keyboard setup in there, delete any others
Posted on Aug 11, 2008
Timing marks on cam for timing chain 2007 Hyundai accent
right it a twin cam engine
the cam chain between the two cams
depends what cams are there
do these help
May 18, 2016 | 2007 Hyundai Accent 1.6
Can you supply the user manual for this player?
You will need to supply the brand name and model number. My suggestion is to use a search engine with (using quotation marks, but leave out parentheses) "(brand name)"+"DVD player"+"(model number)"+manual+pdf.
Be sure to use that exact wording and the plus signs and quatation marks. If the manual is available, you should be able to download and print it. Please DO print out your manual in case you need it again or give the DVD player to someone else who will need the manual.
Also, isn't this a good lesson about NOT throwing your owner's manual away with the packaging?
Aug 29, 2015 | Televison & Video
How can i turn off the green characters on my asus keyboard?
ust press the CTRL+SHIFT keys and you will switch from French to English
Aug 23, 2014 | ASUS Computers & Internet
I deleted my Microsoft Office Activation Wizard
try this :
1. Quit all running programs.
2. Download and install the Windows Installer Cleanup Utility.
http://download.microsoft.com/download/E/9/D/E9D80355-7AB4-45B8-80E8-983A48D5E1BD/msicuu2.exe
3. After you have installed the Windows Installer CleanUp Utility, click
Start>All Programs>Windows Install Clean Up.
4. Highlight Microsoft Office 2007 entry in the list and then click
Remove. Click OK and wait for the process to end. If any other stand alone
Office applications (such as Visio and Project) appear on the list, please
also remove them. Then, click Exit to close the Windows Installer Cleanup
utility.
5. Click Start>Run, type "regedit" (without the quotation marks) in the
Open box and press Enter.
6. Locate the registry keys below and click Delete from the Edit menu.
Click OK on the following warning dialog box.
Note: Please go to File>Export and backup all the registry first.
HKEY_CURRENT_USER\Software\Microsoft\Office
HKEY_LOCAL_MACHINE\Software\Microsoft\Office
Quit Registry Editor.
7. Delete or rename the following folders or files if they exist:
C:\Program Files\Microsoft Office
C:\Program Files\Common Files\Microsoft Shared\OFFICE12
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Excel
Data\Microsoft\Office
Data\Microsoft\Outlook
Data\Microsoft\Publisher
Data\Microsoft\Templates\Normal.dot
C:\Documents and Settings\<UserName>\Application Data\Microsoft\Word
C:\Documents and Settings\All Users\Application Data\Microsoft\Office
C:\Program Files\OfficeUpdate12
8. Click Start>Run, type "%Temp%" (without the quotation marks) in the
Open box and press Enter. Delete all the files and folders within it. If
there are some files which cannot be deleted, just leave them alone and
this will not affect the result.
9. Empty the Recycle Bin.
10. To remove Mapi, search for and rename the following folders/files if
they exist:
C:\Windows\system32\mapi32.dll
C:\Windows\system32\mapisvc.inf
C:\Program Files\Common Files\System\Msmapi
C:\Program Files\Common Files\System\Mapi
11. Restart your computer and install Office 2007 again.
May 12, 2011 | Computers & Internet
Apostropy and quotation mark keys change
The only time that I have this problem is when I've accidentally hit SHIFT and CTRL at the same time. Do it again and you should go back to your old way of typing characters.
Jul 14, 2010 | Acer NSK8458AN Keyboard
How do i add a website icon to my desktop to eliminate typing my way there each time? .
Another way to do this is a little more complicated, but works just as well - if not better.
Select the icon for your internet browser already on your desktop. Copy the icon and paste it onto your desktop.
Now right-click on this new icon and click "Properties"
Click on the "Target" field, there will text in quotation marks in this field. At the end of the quotation mark, add a space after the last mark and then type in the internet address you want your new shortcut to go to (i.e. "C:Program FilesMozilla Firefox irefox.exe" www.examplesite.com), when Firefox is your browser. Now click "OK" in the dialog box.
Go ahead and change the name of this new shortcut to whatever you want. When you double-click this link, it will open up your website!
Jul 13, 2010 | Dell Inspiron 1501 Notebook
Misworking Keys
In the control panel, you should be able to find Language settings. And while I have no idea what language you are describing, I'm guessing that your computer keyboard is set to a different language.
Good luck
tony
May 19, 2009 | Acer NSK8458AN Keyboard
I do not obtain to type accents
This probably has more to do with the settings in the computer than directly with the keyboard.
Assuming you're running Windows, you need to make sure you have your language settings right.
The machine I'm using here is running XP Home - on that, I do Start_Settings_Control Panel, then I open "Regional & Language Options", then select my own language there.
To get accents, you may have to do combinations of keypresses - look up "accents" or "international characters" in the help file for your word processor software for ideas. (For instance, in Word, to get a grave accent, you need to do <ctrl>+` before you type the letter you want accented).
A.
Nov 08, 2008 | Labtec 967318-0403 Keyboard
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
