Question about Acer Computers & Internet
Recently bought a 1GB Memory Unit from Kingston Check compatablity in stuff-Uk.net and was confirm that this would be the correct unit i have been running the unit along side the existing Unit purchased within the laptop however a couple of days ago the memory in the secondary slot stopped working i removed the secondary stick and the machine runs on 1gb but this is no where near good enough the machine gets battered on a 1gb memory as it has Vista Home Basic. i have updated my Bios and checked all the drivers and i'm upto date. could the slot need cleaning after just 2 months?
  • Daniel Gash Aug 14, 2008
    Tried this yes both sets of ram work in the working slot but neither work in the other slot
  • 326 Answers
Have to tried to run both sticks in the slot thats working 1 at a time to check theres not a problem with the ram itself, try moving the 1 thats working now into the other slot and see if it works, then try the other stick of ram
Posted on Aug 11, 2008
I have a Biostar Motherboard K8M800-M7A and i just recently bought a kingston ram memory 1GB 400mhz KVR400X64C3A. Everywhere i look for on the internet says they are compatible but i dont get them to work....
You are correct, this motherboard can use either 333mhz DDR (PC2700) or 400mhz DDR (3200) chips.
You may have a bad chip. Also make sure you are not mixing this chip with another of another speed. Its not good practise to mix 333mhz and 400mhz though some motherboards will still work like that.
Your best bet for compatibility is crucial DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64 •
Personally I have had bad luck with kingston ram myself.
Chris
May 19, 2011 | Computers & Internet
My Averatec A3300 does not like the 1GB memory module which I used to replace the supplied 512MB unit. The computer becomes unstable and invariably ''hangs''. The 1GB module used was the one recommended by...
Sounds like the memory stick isn't compatable/wrong voltage or is faulty.A bios upgrade you can get at the Averatec website support but its unlikely it will help though.
Oct 07, 2009 | Computers & Internet
I have a Gigabyte-GA-8SIMLNF motherboard and recently bought 2gb (2*1gb)of pc2100 DDR and am getting the no ram beep,it is labeled ecc ramwill this not work?
Your motherboard does not support ECC RAM. You'll have to buy a PC2100 nonECC DDR RAM. Also, it supports a maximum of 2 GB RAM, i.e; 2 RAMs each of 1GB in each slot.
Hope this answers your query. Thanks.
Jul 22, 2009 | Intel Motherboard
Can't format sd card and keep being told to insert disc in unit
Dear,
Please check the same card on different PC with update antivirus. If the response is same, then the problem is in the card. You must visit the service centre or go for new card.
reply...
Regards,
Rakesh Kumar
Mar 07, 2009 | Kingston 1GB Secure Digital Memory Card
775i65G does not work when two 1GB DDR400 are installed.
I would venture to say one of the memory modules you have is bad..
Jan 25, 2009 | Asrock 775i65G Motherboard
SD card
I have the same camera, save the colour (black). As soon as I read your post, an alarm went off. I decided to re-check my User Guide (PDF Eng version, page16), for the Lumix DMC-FZ30:
•On this unit, you can use SD Memory Cards of the following capacity (from 8 MB to 2 GB). Please confirm the latest information on the following website:
http://panasonic.co.jp/pavc/global/cs
(This Site is English only.) • This unit supports SD Memory Cards formatted in FAT12 system and FAT16 system based on SD Memory Card Specifications. • This unit does not support MultiMediaCard for recording motion pictures. • The reading/writing speed of a MultiMediaCard is slower than an SD Memory Card. When a MultiMediaCard is used, the performance of certain features may be slightly slower than advertised. • After recording motion pictures using the MultiMediaCard, the card access indication may appear for a while, but this is not a malfunction. • Keep the Memory Card out of reach of children to prevent swallowing.
8MB, 16MB, 32MB, 64MB, 128MB, 256MB, 512MB, 1GB, 2GB (Maximum)
Oct 20, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Sandisk 1gb microsd problems
The music might not be in the correct format. Does your phone play MP3s? Another thing might be the DRM problem with the MP3s. I had this problem once and had to strip the DRM stuff out of the MP3 before my phone would recognize it.
Sep 19, 2008 | SanDisk 1GB microSD Memory Card
Warranty or exchange??
hi
as u have identified the problem, pls take the defective to point of purchase for replacement.
if still a problem than to kingston for replacement. kingston gives life time wty for memory and u are eligible for new replacment.
let me kow if still a problem
regards
Jun 26, 2008 | Kingston 1GB PC2700 DDR DIMM Memory
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Memory/RAM
you are probably not using the correct type of memory, if you just bought a 1 gb stick, Laptops are pretty picky about what memory they use, check the Kingston Memory configurator to find out the max installable mem and which mem is correct to use.  http://www.kingston.com/ukroot/default.asp  use the Memory search feature on the right of the page to get you started
Toshiba satellite is a seperate section in the configurator, so choose that line to get more choices
Oct 16, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
