Question about Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint tumble dryer ctd40g
Just beeps when you switch it on
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Hotpoint tcym 750c tumble dryer serial number tcym750c6p. The wires attached to the timer control and start button have disconnected does anyone know how they go back on?
images for Hotpoint tcym 750c tumble dryer wiring
Hotpoint TCYM 750C Style - YouTube
? 3:07
https://www.youtube.com/watch?v=RjQMN6U4PdE
Oct 8, 2012 - Uploaded by Missing Sleep
Hotpoint TCYM 750C Style. Missing Sleep ... How to replacetumble dryer belt Hotpoint, Indesit, Ariston, Creda, Proline etc - Duration: 9:36. by ...
Hotpoint tcym 750c tumble dryer serial number tcym750c6p ...
www.fixya.com/.../t25992053-hotpoint_tcym_750c_tumble_dryer_seria...
48 mins ago - SOURCE: Reconnect wiring on a Hotpoint VTD00 tumble dryer. most electric dryers have a wiring schematic on the back or inside on the back ...
Dec 03, 2015 | Hotpoint Dryers
How to replace drum belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 04, 2012 | Hotpoint TVF770 Tumble Dryer
Need to replace belt on vtd20g hotpoint tumble dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
I have an Hotpoint CTD40G, if I load it with a full load it strugles to rotate and stops.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Hotpoint TDC32 Electric Dryer
Hotpoint Tumble Dryer CTD40G At the end of a cycle the on/off light was flashing plus Time Delay and High Heat lights were illuminated. The drum rotates but the clothes remained wet. There is no obvious...
that isn't a good model number open the door,look around the opening where you put the clothes in and you'll see the model number,you could have a bad thermal fuse or another t-stat is bad,you have to get in there with a meter and check out the parts for continuity
Dec 16, 2017 | Hotpoint Dryers
My ctd40g tumble dryer has recently started smoking and the drum is no longer spinning, can you help?
Your dryer motor might been short circuited and the motor needs to be rewind or replaced.
Nov 11, 2010 | Hotpoint TDC32 Electric Dryer
Need to take apart a hotpoint tumble dryer vtd00t
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Sep 21, 2010 | Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
I don't have any heat from my hotpoint aquarius ctd40G Tumble Dryer. I have cleared all the fluff from the condenser unit and unplugged the mains and tryed it all again but we still do not have any heat...
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint ctd40g tumble dryer
If you are located in the u/k, then you should be covered by Hotpoint 5 year guarantee, all parts are free you pay for labour and call out.
It might be worth you checking the heater at the rear of the m/c located behind a removable panel. disconnect one of the wires going to the thermostat and try it , if it does not trip, then it could be heater, also you might have damp where heater is ,use hair dryer to dry it all, and make sure all your filters are clean, and that the water tank is empty.
Plz rate this solution.
Thanks.
Dec 16, 2008 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
130 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
