Question about Watches
Putting back cover onto watch after fitting battery. Push on back only. What tool to use?
  • 109 Answers
You need a press or a vice, and (if the crystal is flat) a piece of hard plastic or wood for each side. Then slowly and carefully press down or tighten untill the back "snapps" on. If you have a domed crystal, you will have to find something that will go around the casing, but not hit the crystal and do the tightening. If your watch is different then what I discribed PLEASE let me know and we will think of something just for your watches dementions and crystal type.
Posted on Aug 11, 2008
How do i remove the back to replace the battery on this watch
Watch backs are usually either push-fit and simply need to be levered off, or are twist-fit and need to be rotated off. If there are a number of indentations around the rim of the back then it is likely to twist off. You need to get a suitable tool or tools to remove the cover or you will damage the back of the watch. Check on amazon or ebay for watch repair tools. Getting the cover back on is usually harder with push-fit and is more likely to lead to damage without the correct tools.
Or take it to a watch shop and they will replace the battery for you!
Jan 08, 2016 | Watches
How do I change the battery
Maybe someone might help you if you reformulate your question indicating tha brand and model of your watch
May 04, 2015 | Watches
How do i put the back on the watch after changing battery
Your watch has a snap-fit case; the back is simply pressed back into position with firm pressure. The problem is that modern snap-fit case backs are often very tightly fitted to increase their water-resistance--they're tough to get off, and even tougher to push back into position. I would not be surprised if you would need a jeweler's case press to get the back of this watch back into place.
A case press is just what it sounds like: a device for clamping watch cases back together. It's designed to provide an equal amount of force around the edges of the watch back without putting that same pressure on the watch crystal (which could cause it to crack or break). I'm aware of two basic styles. One style looks vaguely like a big pair of pliers, but with two swiveling plates instead plier jaws. The other style, which I prefer, sits on a table or workbench and uses a lever to push down the top plate. In both cases, nylon jigs are inserted to match the size of your watch.
You can find case presses and other watch repair tools at many jewelry supply stores, mail order supply houses like Otto Frei (http://www.ottofrei.com/store/home.php?cat=296 will take you right to the watch repair tools), and on eBay. However, if you're near a Harbor Freight store, they sell a "watch battery changing kit" and jeweler's press for a pretty reasonable price. These aren't the ultra-high quality tools that a professional jeweler would use, but they'll be perfectly fine for changing the occasional battery for many years. I've probably closed 100+ watches using the inexpensive press I got from there.
If you can't close the watch case with your bare hands and don't have access to a case press, your safest bet may be to go to a jewelry store or jewelry counter in a department store and ask if they could close the back for you with the proper tool. You may have to tip them a few dollars, but that is still far cheaper than the cost of replacing a broken watch crystal.
May 28, 2011 | Timex Indiglo Analog Watch
How to remove the back of a watch to replacae the battery
mcdevito75 here, A special tool may be needed to press the back cover back onto your watch, no one can tell until the back cover is removed, this could be the case with your watch, if so, you"ll have a problem. BEST BET, look for a small watch repair shop in your area, the cost will be the same if you need this mentioned tool and anyway, the battery change is once a year or even longer
Feb 11, 2011 | Watches
Battery replacement procedure for Casio 901 DW-5600?
hi, if the back plate on the watch the part that is against your wrist has four screws holding the silver back plate onto the actual watch then you need to undo these four screw, once undone you lift the back plate off and then this gives you access to the battery, the screws are small philips (cross head screw) so you will need a small screw driver, their is also a little bracket that holds the battery in place you can either push this over to allow the battery out or undo the small screw that holds this bracket in place this will then allow the battery to fall out,
If their are no screws in the back plate then all you need to do is get a very fine flat head screwdriver and look around the edge of the back plate and you should see a little bit on one of the edges that allows you to put a screwdriver into to allow you to lever the back plate off if it has no screws then its just a push fit so just pry the back off and this will give you access to the battery then like above the battery will be held in place by small bracket undo this then remove the battery.
when fitting the new battery make sure you dont touch the top and bottom of the battery as this will flatten it really quick so just push it in place then refit the bracket then either push the back plate back on or screw it back on depending on the type of back plate once this is done you watch will be working again
Aug 14, 2010 | Casio DW-5600E-1VCT Wrist Watch
How do you put the back, back onto this fs1? The band keeps getting in the way! Back came off easily enough, popped off after unscrewed. Band is still on watch, have tried to slide back into grooves but...
You have to remove band in order to fit caseback back onto the watch. Insert pocket knife blade between band and case lug and pry inwards. This motion should release the band. It will be a lot more difficult to fit the band back on and you will probably need to buy springbar tool. Rate me plz.
Mar 03, 2010 | Polar FS1 Unisex Heart Rate Monitor Watch
Can't get the back off the watch to change the battery. No indentation to suggest where to open. What do I use to open the watch--how do I go about doing it?
Take your watch to a dealer in that brand. I'm guessing that your watch has square notches around the underside. The dealer has a special tool that will fit into these notches and the back will twist off as it is threaded onto the watch, not pressure fitted into it.
Jul 04, 2009 | Timex 27191 Wristwatch
SEKONDA: HOW DO YOU REPLACE THE SNAP ON BACK COVER?
Sorry, but your hands (especialy fingers) aren't strong enough. Nothing personal- just confirming the fact. My hands can handle 50 ATM casebacks, but I would say this is more expierence than strength.
OK, back to business: align the winder groove first and make sure this side of caseback sits in properly in case. Then use your thumbs to push the opposite side of caseback in, supporting the watch by your palms and knees. Do not try to push the caseback in bit by bit going all around the caseback. This sort of action will never work.
So, align the groove, support your palms by the knee(s) and push the opposite (to the groove) side of the caseback in to the watch case by one, but strong attempt with your thumbs. It should snap in.
If this doesn't work, you will need to ask the watchmaker to close the watch.
NB: Watchmakers are using specialized press for closing watch cases wich do not require any strength at all.
Rate me, please.
Mar 24, 2009 | Seiko Watches
My watch needs a new battery.
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
Nov 10, 2008 | Swiss Army Wenger Sportedge Bracelet Watch
Fossil red degrade flame battery replacement
http://www.wikihow.com/Pry-off-a-Watch-Backing-Without-Proper-Tools
Oct 28, 2007 | Fossil Degrade Flame Animation JR8215...
Watches Logo
541 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
