Question about Jeep Yellow Sports Outdoor Power Wheels vehicle
12v battery powered barbie jeep
I have a battery powered barbie jeep but can not use it as i have lost the battery charger lead to charge it up. do you know where i can get a new lead from plz?
  • Anonymous Mar 28, 2014
    broken Barbie doll nrckr
  • 3 Answers
If you are comfortable with wires then go to walmart and get a schumaker battery charger from the automotive department. either the Maintainer or the next one up I think ist is model 600 They are much better than the stock chargers because when the battery is full they automatically switch over to float mode so the battery doesn't get cooked. www.modifiedpowerwheels.com has lots of info on exactly what you would need to do. The chargers are 20 and 30 I believe and they can be used for other things like lawnmowers and car batteries if needed.
Posted on Dec 18, 2008
    New Friend:
    Problem Solver:
  • 17 Answers
EBay is a possibility for savings.
Make sure the description says that it is good/working
Buy from a seller with a lot of good feedback!
eBay now has buyer protection
You can use a credit card there
Posted on May 29, 2012
  • 89 Answers
800-348-0751 customer service for power wheels division should be able to help you good luck
Posted on Aug 23, 2008
SOURCE:
How to charge 12v battery
Just hook these up to a car battery charger. If you need to buy one you can get these at Walmart, Target, CARQUEST, Sears, Napa and many other places similar.
Apr 13, 2014 | Powersonic Power-Sonic - UPG UB1290 12V...
My grandaughter's Fisher Price Barbie jeep is running slow. I have charged the battery twice and it doesn't make a difference. How can I check to make sure it isn't a bad charger before
Test the charger with a ohm meter, or you could take the vehicle to a Power Wheels service station, they can test the battery for you to see if it is good.
You can find your closest service center here: http://service.mattel.com/us/powerwheels_info.asp
If you end up needing a replacement battery or charger they can be found here: http://www.mendingshed.com/powwheelbat.html
Let us know if you need any more help.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Mar 20, 2013 | Fisher Price Power Wheels Cadillac...
Where can I purchase a battery charger for the 12V Surfer Girl Pink Jeep
www.powerwheelsbattery.us
Look for:
NPL2 12V Charger Playmind FUMWZ0565-2020
$33.95
Jul 18, 2012 | Princess International Surfer Girl 12v...
After a year in storage, jeep won't work.
the radio runs off of a seperate battery source, so that wouldn't have any effect on this, i would first of all check the battery and charger with a multimeter and make sure that they are showing the correct voltage, if its a 12v battery make sure that they are showing at least 12 volts, if its a 6v battery make sure that its showing at least 6v
Jun 06, 2012 | Fisher Price Power Wheels Barbie Jeep
HOW DO I CHARGE THE BATTERY ?
In the hood of the jeep there is the battery. The jeep should of came with a plug-in quick charger that fits in a general outlet. Simply unplug the battery, and plug it into your wall in the house, etc.
Sep 04, 2011 | Fisher Price Power Wheels Barbie Jammin'...
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
Lost directions to charge battery
you need to charge the specific power wheels charger into your battery.
I have a power wheels jeep and a peg perego gator but had to get 2 different chargers for them.
I charge my batteries up for about 18 hrs at a time and they seem to run fine.
Apr 25, 2009 | Jeep Yellow Sports Outdoor Power Wheels...
No power supply to gearbox
It has a thermal fuse. Depress the gas pedal for 25 seconds and try it then
Jan 02, 2009 | Jeep Yellow Sports Outdoor Power Wheels...
Jeep Yellow Sports Outdoor Power Wheels vehicle Logo
4,118 people viewed this question
Top Jeep Toys Experts
Glenn Smart
Glenn Smart
 Brian Main
Brian Main
Are you a Jeep Toy Expert? Answer questions, earn points and help others
