Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Message on display says ventilate machine will not allow any functions to work
  • Anonymous Oct 05, 2008
    Your suggested solution worked for me, thanks!
  • 515 Answers
Try to push on the button for hot water and make a cup of water.
Posted on Aug 11, 2008
My Gaggia Titanium has an ventilate problem when it is stil cold. After starting up, autotest and running pump, it appears whit message ventilate. It takes a long time steaming or hot water after the
The ventilate sign appears as an error message to tell operator that the flow of water is reduced. I can tell that the machine has not been descaled or was descaled using unscrupulous products that are labeled as descaler but they are not.
Because the sign disappears at this time after flushing water through the steam pipe, the flow restores the sensing that water is flowing normal. This "apparent restoration" of water flow is without any back pressure. The espresso function is restored for limited use.
This error code if not corrected immediately, it will not disappear and not allow any function even after flushing water manually.
The flow meter registers the quantitative flow of water as programmed for espresso.
Please descale the machine as soon as possible. before the 'Ventilate' error message stops all functions.
This is a well designed machine. Needs more attention to maintenance.
You may use the link to order our Best descaler.
Services Unlimited Inc Parts Guru
Oct 19, 2014 | Gaggia Titanium Espresso Machine
We are getting a "ventilate"
Hi.
When you get ventilate the machine functions are locked. Try following the indications here:The following procedure works when you get the ventilate error: The Ventilate sign can...
Regards.
Ginko
Mar 03, 2011 | Gaggia Titanium Espresso Machine
Ventilate problem on gaggia titanium coffee
You need to push the hot water button on the machines panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
May 27, 2010 | Gaggia Titanium Espresso Machine
Machine wont make coffeee, m,essage says ventilate...
May 20, 2010 | Saeco Stratos Coffee Maker, Espresso...
My gaggia titanium keeps coming up with ventilate in the display have cleaned the whole machine out made no difference
You need to push the hot water button on the machine panel to allow water to run out of the steam wand. After a few seconds the machines ventilate message should clear.
Apr 19, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Ventilate message
Press the hot water button and allow water to flow from the steam arm until ventilate disappears and warming up appears on the display.
Ventilate after descale is normal.
Feb 22, 2010 | Gaggia Titanium Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
Saeco Magic comfort
turn the hot water / steam knob on to 'ventilate' the pressure from the machine. The ventilate /overtemperature message will disappear when ready (few seconds usually)
Oct 26, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco royal espresso machine
Ventilate just means that the system has senced a lack of water flow and shut down. Push the button to have water come out the wand and that should reprime the unit. If however no water comes out and the message stays on then you have another problem If water does come out but the message stays on then you have another problem. If in either of these cases you should google "saeco repair" and send it to an authorized saeco repair center to have it fixed.
Aug 26, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
162 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
