After clicking user name on Windows XP welcome screen error message appears: C:\Windows\System32\command.com parameter is incorrect. Clicking OK does not close the error message. Desktop does not appear, no icons, no task bar, no start button. I can remove error message from Windows task manager. Then, I can open any other application by clicking on "new task". How can I fix the system32 command error?
  • 3 more comments
  • frankmj Aug 11, 2008
    My Dell Dimension 3000 came preloaded with Windows XP Home Edition. There are no software disks. Is there another way to do Kevin000's suggestion without having software disks?
  • frankmj Aug 12, 2008
    After restart the computer booted up exactly the same as before. In other words, this solution did not work.
    Solution from Jigsaw007 did not work. Got the same error message on boot up.
    To: Bestdarngood.....I do not have a windows CD. Windows came preloaded on this Dell Dimension when I bought it new about 3 years ago. Any other solutions?
    To Coss71- When the restore prompt appeared there was a caution: all data on the computer will be lost. I couldn't afford to let that happen so I clicked on cancel. Then, like magic, my desktop opened just like normal.
    Problem fixed.
    Genius:
  • 2,028 Answers
Just a little advice, while the computer is up and running, back up everything you want to save. This problem generally doesn't just cure itself miraculously. So don't be surprised when it comes back. Eventually you will need an operating system disc to correct it.
Posted on Aug 13, 2008
    Genius:
  • Computers & ... Master
  • 1,056 Answers
Dell was doing an onboard disk image on the computer that went out without disks.
At startup you hold down CTRL and press F11
Release both keys at the same time
You should get the restore prompts at that point.
Posted on Aug 12, 2008
  • Coss Aug 13, 2008
    Yes, the system restore will put it back to original, and you would have lsot anything added to it since then. that is part of what system restore will do (it formats and reloads the system).
    But that does tell me that it still might have an underlaying problem.
    I would suggest backing up all of your data ASAP on to an external drive, or CD or a pen drive.
    And since this did fix your problem, it would have been nice if you could have at least accepted the solution, rather then rejecting....
    Once it was rejected, no one that offered any assistance here was paid for any of the input that we offered.
    Guru:
  • 1,894 Answers
The error message because command.com is most probably a virus
Please go here :-
http://virusscan.jotti.org/
Upload this file from your computer :-
c:windowssystem32command.com
copy & paste the above bold line into the "File to upload and scan" box...
or click the browse button and browse to the file on your computer...
Then click the submit button
Post back the results
cheers
  • 1,879 Answers
Try creating a NEW user account then reboot & log in using the new account.
Issue persists? You need to re-install the Operating System
  • monk3ybidzness
    monk3ybidzness Aug 12, 2008
    can't resist:
    i love how Ekse utilize images, helps askers a lot.
  • 3,037 Answers
To check the system files, you need your Windows CD. Insert it into the CD/DVD drive, close the start-up window that opens, then go to Start > Run > and type in > sfc /scannow (there is a space between sfc and /scannow)
Hit the enter key and wait for the process to finish. It will replace all bad files. Reboot and all should be back to normal.
Let me know how this goes and whether you have any questions with it
  • Benjamin Patri
    Benjamin Patri Aug 12, 2008
    Well another option is to do a system restore back to before you had this problem
    Go to Start > Control Panel > Performance and Maintenance > System Restore and pick a date that the computer was running fine without this error and set the computer back to this date
    This is reversible if it doesn't work and will not delete any documents. Let me know if you have any questions about it and let me know how it works out
  • 157 Answers
Restart the computer and press F8 as it turns on, go to the advanced menu, select "windows last known good configuration" and let the system start.
Problem solved
Cheers
JigSaw
XoXO
  • 13,433 Answers
Try starting up in safe mode keep tapping f8 untill the advanced start menu comes up
login as administrator
press start -> run -> type in the run menu: msconfig and press enter
in msconfig open the startup tab and click disable all, apply and ok, restart normal mode. should work fine.
Posted on Aug 11, 2008
  • 1 more comment
  • Ekse Aug 11, 2008
    forgot to say, start up in safe mode, as it shows in the picture
  • Ekse Aug 12, 2008
    Im sorry you did something wrong.
    -Start up in safe mode
    -Login as administrator
    -Start -> control panel -> user accounts -> change the user account password
    -restart
    -problem solved.
  • Ekse Aug 12, 2008
    I confused your problem with another one, in other words I wrote into the wrong page.
    start up the safe mode again, login the same way as before.
    i recommend you run ccleaner in safe mode on the computer.. how will you get it on the computer? burn a cd or disk / usb memory.
    www.ccleaner.com
    also, see if you can remove the command.com from startup generally its not supposed to be there
    so:
    start -> run -> type in: Regedit
    go to hkey local machine \ software \ microsoft \ windows \ current version \ run
    do you see the command.com there? Right click and delete it.
    Genius:
  • 1,847 Answers
You need to run the windows repair.
  • Legin Varghese
    Legin Varghese Aug 11, 2008
    Configure your computer to start from the CD-ROM drive. For more
    information about how to do this, refer to your computer's
    documentation or contact your computer manufacturer. Then insert your
    Windows XP Setup CD, and restart your computer.
    1.
    When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
    2.
    Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
    3.
    Do not choose the option to press R to use the Recovery Console.
    4.
    In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
    5.
    Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
    6.
    Follow the instructions on the screen to complete Setup.
Why am I continually receiving error message 0x800CC92 when trying to access emails.
Hi Angela,
The first step is to check your Outlook Express settings, making sure that the POP3 and SMTP servers are as in the screenshots, and that your full user name and password are correct.
Then test your connection by following this procedure.
Click the Start button then RUN type in cmd on (Windows NT/2000/XP) or Command (Windows 95/98/ME). This will open a new command prompt window, with white text on a black screen.
Type in the following exactly as it appears. You will not see what you are entering so take it slowly, and if you make a mistake, start again.
telnet pop.tiscali.co.uk 110 and then click the Enter key on your keyboard. You will then be connected to the email server.
Type in USER followed by your email address e.g. USER jo_blog@tiscali.co.uk and then click the Enter key. You will then get a message +OK Please enter your pass, with the PASS command
Type in PASS followed by your password e.g. PASS joblog0370 and click the Enter key. If it is correct, you will get an OK Well done message.
If you can do this, you have connected to the Tiscali server and so the problem lies somewhere with Outlook Express.
If you can't get in this way either, it could be that your password has somehow become corrupted. Try changing it in My Account. Try again.
If this doesn't work, it may be that TCP/IP has somehow become corrupted within Windows. So try reinstalling TCP/IP. To do this
Click Start
Settings
Control Panel
Network connections
Right click your connection and click Properties
Click Internet Protocol (TCP/IP) and then click Uninstall
Then close down your PC and open it up again.
Follow the same steps as above, but instead of clicking Uninstall click Install.
On the screen which appears, click Protocol and then Add
Click Internet Protocol (TCP/IP) and then OK (You may be prompted for your Windows installation disk at this point.
If you run Windows XP, the process is slight different. You need to
Click Start
Run
Then type in Command
In the screen which appears, type in netsh int ip reset c:\resetlog.txt
Oct 24, 2014 | Dell Computers & Internet
Tip
How To Reset Your XP, Vista, or Windows 7 Password
You can log in to the Administrator account, but not your personal account:
  1. Logon to the Administrator account, or another administrator's account.
  2. Reset or Change the forgotten password for the user account.
For resetting your password by using a password reset disk:
  1. First on the Windows 7 Welcome screen, you have to enter a blank password into the password text box, and then you have to press the Enter key or you have to click on the Go button.
  2. The Windows 7 operating system will provide you the information you that the user account name or password you entered is incorrect.
  3. After this click on OK, for coming back to the Welcome screen,
  4. Then, click on the Reset password link that appears below the password text box. After which the Password Reset wizard will start.
  5. On the Welcome page, click on Next.
  6. You then have to click on the Insert the Password Reset Disk page, and have to choose the USB flash drive or floppy disk drive, which you want to use.
  7. Now insert the password reset disk into the drive, and click on Next.
  8. Enter a new password and password hint, which you want to set as your password and hint on reset the user account password page, and then click on Next.
  9. Click on Finish.
You cannot log in to the Administrator account, or your personal account:
Offline NT Password Disk is a very simple and very fast command line Linux tool to reset your forgotten Windows administrator password. At the time of this writing the site was down, hence the Google Cache link.
  1. Download the bootable CD image by clicking on the link, and scrolling down until you see Download.
  2. Burn the ISO to a CD using Free ISO Burner, ImgBrn, Active@ ISO Burner, etc.
  3. Boot up your PC with the bootable CD.
  4. Drivers for both SATA and IDE drivers typically load automatically.
  5. Select the location of your Windows Operating System.
  6. Select windows/system32/config as your directory.
  7. Select “Password Reset” as your option.
  8. Choose to reset as a ‘blank password’.
  9. Once blanked, type ‘q’ to quit and write the values to the registry.
on Jul 12, 2010 | Computers & Internet
Gateway login
What sort of problem at log in >>?????
Forgot password ?
A "setup password" is a password that you must enter to log into a user account on your Gateway laptop.
This can be beneficial if you have a number of people using the same computer and don't want just anyone having access to your personal files.
But if you are the sole user of your Gateway laptop, then it can be more of a hindrance.
As all Gateway laptop computers run a version of the Windows operating system, you can remove the setup password by accessing the Windows Control Panel.
Click on the "Start" menu.
Select the option that reads "Control Panel." If you're running Windows Vista or Windows 7, this will have its own listing in the "Start" menu.
If you're running Windows 95, Windows 98, Windows ME or Windows XP, this will be found under the "Settings" sub menu.
Double click on the icon that reads "User Accounts."
Click on the name of the account that has a setup password that you want to remove.
Click on the "Remove my Password" option.
Enter your current password into the appropriately labeled box.
Click the "Remove Password" option.
Click "OK" to save your changes and exit the "User Accounts" utility.
The setup password will have been removed from your account, and you will be no longer prompted to enter it when you boot up your computer.
Unlock a Gateway Computer
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both. Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer." Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear. Log on as usual. Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool.
This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer.
Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page. Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make. Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 26, 2013 | Computers & Internet
Gateway login
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Nov 18, 2013 | Computers & Internet
Can't get logged in on windows 8
Follow the steps:
Requirements:
1 ) Windows Vista or 7 DVD
1. Insert the Windows Vista DVD into the DVD drive and then restart the computer.
2. Change Boot Options 1st Priority to Optical Drive.
3. When system booting up, if the message "Press any key to boot from cd" appears, immediately press Enter.
4. On Language Settings, Time and Currency and Keyboard Layout screen, just choose the correct settings then click Next.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer's startup options.
6. On the System Recovery Options screen, under Operating System, click Windows Vista then click Next. Then select Command Prompt.
7. At the command prompt windows, type the following command then press Enter after typing each command:
c:
cd windows\system32
echo ~takeown /f %1 /r /d y > TakeControlOf.cmd
echo ~icacls %1 /grant administrators:F /t
ren Magnify.exe Magnify.old
ren cmd.exe Magnify.exe
8. Restart the computer.
9. On the Welcome Screen, click the Ease button.
10. Check Make items on the screen larger then click OK.
11. At the prompt, type the command then press Enter.
net user Administrator /active:yes
exit
12. Restart the computer.
13.
At the welcome screen, logon using the local administrator account.
14. Access Control Panel then click User Accounts. Select the username of the account you can't login to then remove the password.
15. Log off on the current local administrator account your are logon to.
16. Check if you can logon to your user account now.
17. Open c:\windows\system32.
18. Right click on Magnify.exe, select Properties -> Security -> Advanced -> Owner -> Edit -> Administrators then click OK.
19. Select Edit -> Administrators -> Full Control then click Apply then OK.
20. Rename Magnify.old to Magnify.exe
21. Open command prompt then type the command then press Enter.
net user Administrator /active: no
To create a new user :
Net user username/add
Windows XP/2003, Vista and Windows 7.
To add a new user account to the local computer from command line:
net user username password /ADD
Example: To add a new user account with the loginid John and with password fadf24as
net user John fadf24as /ADD
To add a new user account to the domain:
>net user username password /ADD /DOMAIN
Note that we do not need to specify the domain name here.
Example:
net user John fadf24as /ADD /DOMAIN
Rename a user account from windows command line
We can use below wmic command to rename a user account from command line.
wmic useraccount where "name='username' " rename new_username
Ex: To rename the user account techblogger as win7techblogger
wmic useraccount where "name='techblogger' " rename win7techblogger
Net use command does not have any switches to rename a user account.
Few more Advanced uses of net user command.
To specify user full name while creating the user account
net user username userpasswd /ADD /FULLNAME:"User_Fullname"
To specify that the user is allowed to change the password
net user username userpasswd /ADD /PASSWORDCHG:Yes
To restrict user not to change the password:
net user username userpasswd /ADD /PASSWORDCHG:NO
To specify when the account expires we can use /EXPIRES switch.
To specify if the user must have a password set we can use /PASSWORDREQ switch.
How to create a new administrator account from command line?
An administrator account can't be created directly from command line. We first need to create a user account and then add the user to the administrators group.
Errors:
If you don't have privileges to add new user account to the system, you would get an error like below.C:\>net user John /add
System error 5 has occurred.
Access is denied.
C: \>
if cant able underatand send me your mail id..
Nov 10, 2013 | Computers & Internet
In Windows XP Pro, when I turn on the computer the welcome screen doesn't appear, but i want it to. It straight loads to the desktop, and I dont want it to. I want the Welcome screen to load so i can...
  • A recently installed program has disabled the Welcome Screen and Fast User switching. To restore these features, you must uninstall the program.
    The following file name might help you identify the program that made the change:
    C:\Windows\System32\Awgina.dll.
  • User interface failure.
    The login user interface dll C:\Windows\System32\Awgina.dll failed to load. Contact your system administrator to replace the dll or restore the original dll.U can try do this in case u find any problems u can let me know...
    Thanks for using fixya
Oct 30, 2011 | Microsoft Windows XP Professional
A message appearing"you may be
Windows Genuine Advantage Notifications for Windows XP notifies you if a copy of Windows XP is not genuine. The notification messages only appear on computers that have failed the WGA validation process and that are running a copy of Windows XP that is not genuine. If you are running a validated, genuine copy of Windows XP, you will not receive notification messages.
Removing WGA Via The Command Line Restart your PC and boot into Safe Mode, usually by pressing F8 whilst your computer boots. Once your PC has booted open a command prompt by clicking Start then Run and typing cmd into the box before clicking OK.
Change directory to your System32 folder with the following command:
cd \windows\system32
Next you're going to need to copy the following lines to the clipboard, in order to paste them into the command prompt quickly. This is necessary to kill the WgaTray.exe process and delete the file before Windows has a chance to launch it again:
taskkill -IM wgatray.exe
del wgatray.exe
del wgalogon.old
If all the commands executed correctly you should have killed and deleted WgaTray.exe as well as WgaLogon.dll. You might also want to have a look for any WGA-related files (WgaTray.exe, WgaLogon.dll, WgaSetup.exe etc...) in \Windows\System32\dllcache and delete them, just in case.
Restart your PC to see if the changes have taken effect, if the WGA notifications are still there then you'll want to continue reading this next bit, otherwise you're done.
Jan 02, 2011 | Microsoft Windows XP Home Edition
Keyboard stops working after password has been entered in Vista
Please follow steps below to reset your Windows Vista Password in 10 minutes.
Steps :
3. When system booting up, if the message “Press any key to boot from cd” appears, immediately press Enter.
5. On Install Now screen, click Repair. Note: Click No just in case you get the message: Windows found problems with your computer’s startup options.
c:
cd windows\system32
exit
Sep 27, 2009 | HP Compaq Presario CQ50-110US Laptop
Forgot password
Steps :
c:
cd windows\system32
exit
When you log in sign in to name with password that was forgotten and change to one that is known.
Sep 27, 2009 | Toshiba Satellite L305D-S5934 Notebook
No rights to run control panel requires new instal need media
1. to gain rights do the following.
The built-in Administrator account is hidden from Welcome Screen when a user account with Administrator privileges exists and enabled. In Windows XP Home Edition, you can login as built-in Administrator in Safe Mode only. For XP Professional, press CTRL + ALT + DEL twice at the Welcome Screen and input your Administrator password in the classic logon window that appears.
To have the Administrator account displayed in the Welcome Screen, try one of these methods:
Method 1: Using TweakUI Power Toy for Windows XP Download TweakUI from here: v2.00 for Windows XP | v2.10 for XP SP1 and above
Open TweakUI and click "Logon" option in the left pane. Put a checkmark against the option "Show Administrator on Welcome Screen". Click OK to close TweakUI. Logoff and see if Welcome Screen lists Administrator login. Changes are immediate and you can use the Winkey + L to switch back to Welcome Screen to see Administrator account is listed.
Use this procedure to hide/unhide any user account from the Welcome Screen. Please remember, you can still login to a hidden account using CTRL+ALT+DEL classic logon method, but cannot Fast User Switch to a hidden user account.
Method 2 - Manual registry edit
  • Click Start, Run and type Regedit.exe
  • Navigate to the following key:
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \ UserList
  • Use the File, Export option to backup the key
  • Create a new DWORD Value named Administrator
  • Double-click Administrator, and set 1 as its data
  • Exit the Registry Editor.
For Windows XP Home Edition While you can configure Windows XP Home Edition to show Administrator account in the Welcome Screen, you cannot login as Administrator in Normal mode. Visit the following link for more information:
Error Message: Unable to Log You on Because of an Account Restriction
Sep 17, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
