Question about Bosch Washing Machines
How to remove motor from bosch wfo 2867 washing machine@?
  • Anonymous Mar 16, 2014
    bosch wfo 2063
Remove back panrl. Remove drive belt, remove 2 10mm motor bolts. Turn machine upside down. Remove bottom cover. Disconnect power lead to motor, disconnect earth lead, gently tap motor out with mallet. Brush mountings then accessible, remove and replace brushes.
Posted on Aug 12, 2008
THE MOTOR WILL NOT SPIN , IT'S NOT THE BELT
this is probly the motor carbon brushes remove motor and check brushes they should have a nice shine on on the face if not there needing replaced wear length is about 15mm new they are approxx 25mm long
Jun 08, 2011 | Bosch Classixx WFO 2466 Front Load Washer
Got a Bosch WFO 2460, drum stopped turning, replaced brushes and cleaned up the stator but it still wont work. When it stopped the first time it triped the Mains circuit breaker so i am wondering if there...
there is a thermal cut out located in the windings on the motor you may have o hunt for this it has a wire going in and n out, you could short it out as a quick test if motor running....
Apr 22, 2011 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch exxcel 1200 express spinning slowly
I would suggest that you remove the motor, and check the brushes for wear.
If they are less than 3 or 4mm long, then they need to be replaced.
Hope this helps.
Jan 07, 2010 | Bosch Exxcel WFO 2465 Front Load Washer
Keep getting error f17 on my bosch classixx 6 washing machine
My old Bosch only had a filter in the machine (where the hose attaches. My Exxcel has a filter IN THE HOSE at the tap end too. I removed that one and it made a big difference !
Dec 17, 2009 | Bosch Classixx WFO 2866 Front Load Washer
My Bosch Maxx 2000 WFO 2060 is leaking from the bottom. Could it be that a filter somewhere needs to be cleaned? If so where is the filter located?
The filter is usually located at the bottom right front of washer, sometimes behind a removeable cover, or a drop down flap.If you can locate it, then unscrew it anti-clockwise to remove and clean it.
There is also a possibility that there could be a hole or tear in the door seal so check the seal as well.
Hope this is of some help to you .
Dec 07, 2009 | Bosch Washing Machines
How to disable beeps in Bosch wfo 2442 oe
please tell me somebody how to turn off spin for bosch WFO 2442?
May 29, 2009 | Bosch Washing Machines
Replacing brushes
Remove rear panel of washer.
Undo 2 screws securing motor to tub.
Pull motor plug from terminal block.
With a screw driver, or similar, lever back motor, keeping hold of it , and remove motor.
Fit new brush.
Please rate my fixya solution.
Thankyou.
Jan 31, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Remove carbon brushes from bosch washing machine
u can sometimes tip the washer backwards and with a torch u should be able to see the carbon brushes and the 2 star screws which hold them in undue these screws and the carbon brushes will pop out very easily for u to change them m8
Feb 24, 2008 | Bosch Classixx WFO 2466 Front Load Washer
Washing Machines Logo
256 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
