Question about Symbol LS2208 Handheld
Symbol handheld scanner problems
My name is Yusuf Ebrahim From Orient Islamic School
I have a Symbol LS1902T Handheld scanner. It scans but does not pick up the barcodes. Do i need a driver or software or so? How do i activate my scanner. Please Held urgenly
[email protected]
  • huggermugger Sep 17, 2008
    yes i have the same problem BUT i tried it in another PC it work good and when i back to the prev PC it dos not ,, it work in some pc's and the other not and when i try to pick a code it gives me a green aleet and after seconds give's me red alert with sound and not pick the code>
    Problem Solver:
  • 5 Answers
Scanners are just plug and play.. be sure the scanner is programmed to read the type of bar code you are scanning.. Check the symbol to make sure it is not defaced. Try scanning test symbols of the same barcode type. and last tip, move the scanner closer to or further from the bar code.
Posted on Aug 15, 2008
SOURCE:
Symbol ls1902t-1000 scans extra characters when scanning a barcode
Download the quick start guide from support.symbol.com and reset to default by scanning the code from the PDF manual. This could either be a programmed ASCII prefix, or an error in the codes you are scanning. Have you seen the same problem with more than one scanner?
Oct 29, 2012 | Symbol LS1902T-1000 Handheld Laser Barcode...
Add carraiage return after scanning
The Motorola support site has an FAQ (ADC-01589) that contains the barcodes to get the LS1902 to add a CRLF after the barcode: Scan Options, Data Suffix, Enter. If the article is no longer there just download the LS1902 or LS1900 series Product Reference Guide to print the barcodes from there. They are usually in the Miscellaneous section.
Jan 28, 2011 | Symbol LS1902T Handheld
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
Need instructions
it depends on the configuration of your host and scanner. Usually there it works like this:
Connect the scanner to USB or per Keyboard Wedge Select the correct language set for your Scanner Try to scan your barcode if this will not work - enable the barcode you need to scan with the programming barcode from Manual
The Barcodes needed to set up the device are listed in the Reference Guide at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf
Jan 14, 2008 | Symbol LS1902T Handheld
Programing
What kind of programming do you need to do? I've got most Symbol Manuals.
Jan 07, 2008 | Symbol Cobra LS1902 Handheld
Symbol LS2208 Handheld Logo
825 people viewed this question
Top Symbol Computers & Internet Experts
Ekse
Vish Iyer
Vish Iyer
Thomas F. Schneider
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
