Cyberhome DVD320 DVD Player Logo
Posted on May 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its says wrong region! - Cyberhome DVD320 DVD Player
Nolan Brunsdon
Level 2:
  • Expert 124 Answers
  • Posted on May 11, 2011
Nolan Brunsdon
Expert
Level 2:
Answers
124
Questions
0
Helped
26663
Points
249
  1. Turn on the player (without a disc inserted)
  2. Close the disc tray
  3. Press MENU, 1, 9
  4. Selection menu will be displayed
  5. Press ENTER
  6. Select region
  7. Press ENTER
  8. Press OPEN/CLOSE
1helpful
2answers
4helpful
2answers
DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
1helpful
Region problem
HELLO!
TRY THIS!
Turn on the player
Make sure disc tray is Open.
Press 9 9 9 9 on the remote, do it slowly.
Press what region you then require.
Press 0 (zero) for multi-region/region free playback.
When you are trying to play back a disc other than the region the machine is set up for, you will get a Wrong Region message.
ENJOY! (:-)
2answers
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
2answers
Wrong region
check with another dvd you know the region.
check same dvd on another (not region 2) player and see if itsn't working.
find if you have to follow special instruction to activate the "all region"feature.
find on line instructions do remove the region lock.
confirm make /model/ sn where you bought it and I can help to find instruction.
2helpful
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Coby 224 wrong disc
you can reset the settings through the menu, its under the advanced option in the menu. however, its not a regional error, if it was in the wrong region, it would say wrong region and not wrong disk, try putting the region back to 1 or 0 or 9, 1 is USA, 9 and 0 are all regions.
Hi there
Check your DVD or Video player manual for regional setting, you may simply be set to the wrong region. Some players have a regional button on the remote control.
Regional settings allow DVD's or Videos to be played on the same player by simply selecting the correct regional setting.
If you are on the wrong regional setting, your picture will most likely appear in black and white.
Wrong Region
I'm living in Brazil.
I have a Home Theather Systems Philips Model HTS3565D and when i put on a DVDs show me in display Wrong Region.
Here in Brazil the DVDs are 4 Region.
Can you help me to modify in Remote Control the Region for 4?
Thank you very mych!
Elaine
2answers
Nexxtech N600 D wrong regional code
I have nexxt tech dvd 161-1000, I have the same prblem " Wrong Disc", I cleaned the lense, still same...Pls advice
Top Cyberhome Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
