Question about Garmin GPS
How do you open a nuvi 350 - Garmin GPS
Lift the antenna and remove the two screws on the back.Carefully remove the antenna cover and with a small jewellers screwdriver move the left spring loaded hinge of the antenna support toward the centre of the support.Carefully remove the support paying attention to the spring loaded hinge as this will jump out and you are likely to lose the spring or the mobile end.Carefully remove the antenna support extending the ribbon connecting cable so the you can now access the two screws holding the case closed.After removing the screws pry open the case paying attention to the two ribbon cables connecting the display to the main board.Flip the securing flaps on the ribbon connectors and remove the ribbon cables. the unit is now open and you can carry on with whatever you needed to do.
Posted on Aug 12, 2008
I need owners manual for my Garmin nuvi 350 NA. I
Connect your Nuvi 350 to computer with USB and look in Garmin folder for owners manual. It should be in the Nuvi's internal memory in PDF format.
Other: Go to www.garmin.com/products/nuvi and click Manuals link to download to computer.
Feb 14, 2010 | Garmin Nuvi 350 Car GPS Receiver
How do i open the gps garmin nuvi 350 to see inside?
Is there a problem with it?? If not, don't. You'll void the warranty and cause a load of heartache if you need to use it.. Either way, if it ain't broke, don't fix it..
Oct 06, 2009 | Garmin nuvi 350 GPS Receiver
I forget my pin number and i can't open the screen
Go to your secure location (safe zone),
the pin will not be on it then.
or if you didn't set it or don't know it,
Garmin Repair's only.
Regards.
Jun 26, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 System Software Missing
If you have a nuvi 350 download the software to your computer and then load the software onto a formatted sd card. Insert the sd card and bootup the Nuvi 350. The sofware will then load onto the Nuvi 350. If you have a Nuvi 200 I would think it works the same but I have not tried it.
Hope this helps
May 12, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 350 displays "enabling Bluetooth" and will not move . What should I do
A Nuvi 350 does not have bluetooth capability. Do you mean Nuvi 360? If it is a 350, then the firmware is corrupted or was flashed with the wrong firmware.
- Jim
SHARCNET-USA
Jan 17, 2009 | Garmin Nuvi 350 Car GPS Receiver
Nuvi 350 will come on but will not stay on
The internal batteries are not user replaceable. Please don't try to do this yourself. I've received numerous emails from people who have destroyed the Nuvi attempting to do this. I have replaced numerous Nuvi batteries. The life of the battery depends on how many cycles its gone through.
- Jim
Nov 29, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin nuvi 660
Thanks Jim, but problem solved.it was a loose flat cable cable connection from main pcb to screen.
Jul 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
On button doesn't work
I sent you the instructions. Please rate my solution to close this thread. Thanks!
Jul 02, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin Nuvi 350 GPS is off
you also need to open the antena
Jan 05, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
113 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
