Question about Canon Cameras
The lens cover on my Canon PowerShot A620 does not open all the way when I press the shutter button.I have put freshly charged batteries in the camera.
  • jenksj Aug 11, 2008
    I have been able to open the lens cover by pressing on it but I shouldn't have to do this; it should open automatically. What will correct this problem?
    The suggested solution was helpful and I appreciate how quickly you responded to my question.
  • Canon Master
  • 13,433 Answers
So the lens cover is stuck..
carefully press the edges so the cover snaps open.
Posted on Aug 11, 2008
  • 2 more comments
  • Ekse Aug 11, 2008
    I had the same problem with my camera and when I pressed a little on the side of the cover it snaped all open.
  • Ekse Aug 11, 2008
    Im not sure if I missunderstood the problem but what I mean is, and I assummed you mean this
    The lens cover
  • Ekse Aug 11, 2008
    I would recommend geting a professional to look at it. These camera are fragile things.
    www.advancecamera.com/repair
    You can try placeing the camera on a table, turn it off and on, so the cover closes and opens, do this a few times and see if it improves. But to really correct the issue, the lens cover needs to be inspected. If you open it, you might not get it back together, so I really recommend you get someone to look at it. local camera dealer or repair professional.
  • Ekse Aug 11, 2008
    Thank you
Canon a620. no image on display and pictures turn out black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 24, 2010 | Canon PowerShot A620 Digital Camera
Canon A620 is taking black images/ Can't see images on screen
First try pressing the DISP or DISPLAY button on the back of your camera. If that didn't fix it... A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 28, 2010 | Canon PowerShot A620 Digital Camera
My Canon PowerShot A620 has a black screen, any ideas on how I can fix this? I can't even take pictures, all of them come out black
My A620 JUST started doing the same exact thing last night. LCD works, lens works... but something possibly wrong w/the shutter so it won't open.. everything black.
Jan 05, 2010 | Canon PowerShot A620 Digital Camera
Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Dec 30, 2009 | Canon PowerShot A620 Digital Camera
Black screen
Simply right click on the track itself and select send to/DVD-RW or CR-RW depending on the type Compact disc drive you have. Then you will see a notification, "you files to be written to CD." Simply click on it or go to your Compact disc drive on My Computer and click “write these files to CD.” Then follow the screen instructions. IT is that simple. All you need to do is press and release the display button until the screen displays. Usually Canon Powershot cameras have 3 display modes:- colour, black & white, blank. Your camera is set to blank that is why you cannot see any image/screen displays no image. Just press and release the display button until the screen displays. That should do it.
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Lens Shutter Don't Close
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. The A620 is more complex, but still similar enough. As recommended in the post, try the simpler fixes first before attempting:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Dec 26, 2008 | Canon PowerShot A620 Digital Camera
Canon powershot A620 black screen can't take pictures
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2008 | Canon PowerShot A620 Digital Camera
SHUTTERS AREN'T FUNCTIONING PROPERLY
Repair costing close to half the price of new camera is uneconomical. And unfortunately if it is the shutter ( which seems questionable and sounds like the lens unit has sand inside and canon want to replace it ) you will not be able to do this yourself. Buy a new camera.
May 09, 2007 | Canon PowerShot A620 Digital Camera
Cameras Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
