Question about Samsung SF-330 Plain Paper Inkjet Fax
Sf330 samsung won't print faxes
I receive only a blank page on the fax machine, Please help. I do however manage to transmit from the same fax.
big ple....................ase
  • faircapeza Aug 12, 2008
    thanks for the speedy response. There is toner but still the fax won't print. any further help will be appreciated. Thank you
    Brenda
    thank you for the manual. I will test on Wednesday to see if it works. you are marvelous.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Samsung Master
  • 1,362 Answers
RX and TX are 2 different things.
start with the basics
1- is there toner in the machine
2-if it is ink the cartridges may be dry
Posted on Aug 11, 2008
  • CheckitRight
    CheckitRight Aug 12, 2008
    1-do an internal test print----all machines have a self test page
    this will tellyou if it's internal or external
    2-if it gives you a blank page with the self test then
    a) does it do the back and forth motionas if it's printing?
    check the cartridges by putting a tissue on it to see if the ink comes out.
    take out cartridges and clean contacts
    look at chapter 7
    http://www.retrevo.com/search/v2/jsp/dow...
SOURCE:
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
BLANK PAPER
If you receive a fax with blank pages , nine times out of 10 the answer is that the sender fed one or more of the sheets into the fax machine upside down or backward. You can confirm that this is what happened by noting whether the header (lines of sender information) is present.
You could also be experiencing a technical or mechanical problem, such as a need to fix or change parts. You can test whether your machine can print at all by using its “copy” function, or print an activity report. If all is well on your end, the problem must be with the sender’s machine.
If, by any chance, you’re using an old thermal fax machine, check to see if the roll of paper has been put in backward, because if that’s the case the heads won’t print on the side that isn’t heat-sensitive.
Thanks for using Fixya.
Apr 16, 2009 | Office Equipment & Supplies
LCD SAYS PAPERJAMMED
try to clean and oil the print head sharf. and clean the miler strip. this is the plastick pease with the black lins on. at the back of the print head carige
Feb 10, 2009 | Samsung SF-330 Plain Paper Inkjet Fax
Samsung MFC-SF560 fax not printing complete page
If you have already try another image unit, you should try to make a copy or print a report. If the prints came out ok, the problem could be the telephone line. GOOD LUCK.
Nov 21, 2008 | Samsung SF-560 Plain Paper Laser Fax
Receiving a fax
It will be a problem with the other ends fax when it sends its stretches out the fax too much and it transmits accross two pages. The other fax is telling your machine to print out accross two pages in the transmission. Older faxes are the worst for it.
Feb 18, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Paper feeding when printing recieved faxes
If this is primarily happening with receipts from one sending fax machine, the most likely cause is that the sending machine is transmitting an end code that causes this page to print.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Oct 26, 2007 | Canon FAX-JX200
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Samsung SF-330 Plain Paper Inkjet Fax Logo
243 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
