Question about Sharp AR-5316 Advanced Digital Imager Copier
Developer sign hi Flopez,i have a problem with my sharp ar-5316.I replaced developer but i dont know how to clear the developer.thank you
  • 2 more comments
  • moftech2002 Aug 13, 2008
    hi,i did not replace the drum.by the way how do i reset the drum
  • moftech2002 Aug 28, 2008
    please how do i get into service mode.thank you
  • reddah ilyes
    reddah ilyes Nov 30, 2013
    get into SIM mode by pressing "#" key then "interrupt" key then "C" key then "interrupt" key again. enter 41 then press start - enter 01 then press start.
  • reddah ilyes
    get into SIM mode by pressing "#" key then "interrupt" key then "C" key then "interrupt" key again. enter 42 then press start - enter 01 then press start.
  • Sharp Master
  • 2,794 Answers
The developer doesn't need to be reset on AR series machines. Toner and developer are in one cartridge. There is a drum reset. That is service code 24-07.
Did you replace the drum as well?
Posted on Aug 11, 2008
  • Tim Babcock
    Tim Babcock Aug 13, 2008
    Once you get into the service mode press 24. Hit the green button. Press 07. Hit the green button.
    Do you know how to get int service mode?
  • Tim Babcock
    Tim Babcock Aug 28, 2008
    Press the follow keys:
    #*C*
    To canel test command mode hit the CA key.
    This should work with most Shap digital copiers.
How to remove code f2 from a Sharp AR-5316
What is the next after f2- or if f2-64 check development un or connect the connector chip.Replace development unit.
Jun 10, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
How i will enter in Sharp Ar 5316 photocopier machine programing and how i will remove maintenance sing
Hallow there, it is always good to understand a specific code and what it means because not all codes are cleared using simulations. Maintenance sign means that the copier needs to be well serviced and checked if something is to be replaced. Consumables such as drum, blade, fuser rollers and developer are changed at such times. If you are sure that you have replaced the correct part or nothing is to be replaced, then you can proceed to clear the sign.
Follow this procedure to clear maintenance sign; Press #, Interrupt, C, Interrupt. keys in that order. Enter 20 and press copy key then enter 01 and press copy key again then press CA key twice to return to normal mode. Wish you success.
Aug 04, 2010 | Sharp AR-5316 Advanced Digital Imager...
How to remove service man from copier sharp ar5320
hi the service man means yours copier have complet the pm cycle if u dont want to replace drum and devolper u can clear the pm counter with sim 24-4
thanks
May 12, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp reset developer on ar-122en
I do not understand What is step by step help?
Focus me clearly.This machine setup code is: # interrupt C interrupt.
Dec 10, 2009 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
I want code to reset the developer ccounter
After you replace developer, press #, interrupt, c , interrupt keys in that order. Display will go off, press 42 print 01 print for developer reset. Press Interrupt key twice and press 20 print 01 print for serviceman reset. Press CA key .
Apr 19, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to chande the developer
you take the drum out, then unscrew the developer (it should be a greenish screw), it should slide out, empty the developer out, take bag of new developer shake it up real good... then pour evenly into developer unit, while turning the mag roller... reinstall..
Nov 19, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code
Hi Sorry cant send manual U have to buy like every one else.But here are the codes you require It is service code 24 sub code 04 to reset PM counter and sub code 07 to rest drum sub code 09 to reset print count and sub code 11 to reset developer. Hope this helps
Aug 18, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
741 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
