We are in a two year-old home with a Tappan A-C/heating unit (A/C heat pump/w. electric boost). Within 6 months of moving into this new home, we began having problems with the unit. It has failed repeatedly, both as a heater and, especially, when in AC mode. In the past two months alone, it has tripped the (30A-220V) breaker supplying the unit at least once a day almost every day! (I even replaced the breaker at the installer / service provider's request on the possibility that the breaker had been "weakened" by its repeated tripping; it tripped again later that same day)! The compressor makes loud and mysterious noises repeatedly on both startup and shutdown. The serviceman added what he calls a "hard start" switch; if anything, the situation has gotten worse since then. The unit also suffered from slow leaks (recently - hopefully! - corrected, requiring numerous calls to replenish the refrigerant. I am now at wit's end: to me, it is becoming more apparent by the day, that SOMETHING is basically wrong with the compressor, and it needs to be replaced. The serviceman, on the other hand, keeps insisting that, no, that's not the problem. YOU tell ME. I need something done PRONTO. This time of year in SC, the house rapidly rises in temperature once the unit goes out, and frankly, both my wife and I are tired of having what amounts to a manually operated A/C system. The unit was installed by Piedmont heating and AC, proprieter David Gaskins, his Cell phone # is (704)400-0501. My home phone is (803)675-4441. My address is 1207 Canvasback Duck Drive, Clover, SC 29710. E mail at tblomstrom@carolina.rr.com HELP PLEASE!! Tom Blomstrom
I haven't, as yet, "solved" the problem; rather I have sent it back to the guy who installed my A/C in , let's say, rather "emphatic" language.
Frankly, when I got into your site, I THOUGHT I was actually communicating directly with Tappan, the unit's manufacturer. Asx I've already spilled many a bloody tear trying to get the problem resolved, I wasn't about to PAY for advice. End of story.
TPB
Posted on Aug 12, 2008
Tip
KNOWING ABOUT CONDENSER
What is a condenser?
Is a device or unit used to condense vapor into liquid. A condenser is simply one component of an air conditioner. Whether you have an outdoor air conditioner or a window unit air conditioner your air conditioner contains a condenser.
Condensers are used in outdoor air conditioning systems as well as heat pump systems. Condensers in an air conditioning unit have very few controls. They will have an on and off switch. Occasionally these air conditioners will also have a brown out option. This option shuts down the compressor when the electrical current is low.
A condenser is simply a heat exchanger. It compresses refrigerants into a hot gas to then condense them into a liquid. A condenser is a major component in a air conditioning or heat pump unit. It moves air across the coils to facilitate the transfer of heat.
In a heat pump unit the condenser has a few more features. It will have a reverse valve that allows the unit to switch back and forth between air conditioning and heating. Even when the unit is heating, it uses the condenser for defrosting the coils. If the coils become layered with frost it will effect the units effectiveness this is defrosted when the reverse valve switches to air conditioning mode to move the hot gases through the coils melting the built up ice. It will automatically switch back to heating mode once the ice is cleared to once again heat the home.
To keep your unit in good operating condition it is vital to keep the area around the condenser clear of all debris as well as keeping the filter clear of dust and dirt. A clean machine makes a happy machine. A happy machine will keep you cool during the summer months and warm during the cold months. It is suggested to change the units filters when they become dirty, depending on your area and conditions near your home this may be as often as once a month or as seldom as every 3 to 6 months. You will have to pay close attention to your units needs to decide the right time to change or clean your unit’s filters.
It is very important no matter what type of unit you have to prevent the blockage of the condenser. If the condenser becomes block it can effect the units efficiency or even cause the until to completely fail. For this reason it is one of the most important components of a cooling or heating system. A condenser allows the maximum airflow to the unit.
Keeping you condenser in good running condition will not only prolong the life of your heat or cooling system but also provide you with the most efficient heat and cooling system saving you money on heat and cooling.www.victorwod1234.blogspot.com
on Apr 08, 2010 | Heating & Cooling
Should we repair heat element, or buy a new oven?
It sounds like your element is electric. When food drips on that element it can cause a heat spot on the insulation around the electric element and eventually burns through. You can easily replace that element for about $50 - $60. It requires about three hand tools and 15 minutes to remove old one and install a new one. You should be in business for another 14 years if you clean any drippings on the element itself.
Mar 10, 2014 | GE Profile Spectra JBP95 Electric Kitchen...
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
I have a 6 year old Goodman "GPG10481151A" single
try turning the t-stat all the way down then kill electricity to unit wait ten min and turn everything back on, see if this helps. let me know.
Mar 02, 2011 | Amana Heating & Cooling
I puchased 5 year old home back in July and up until the last few months my electric bill has been any where from 800kwh to 1500kwh. It jumped in December to 3880 and 4500 in January. My home is 2400sq,...
You will need to have a HVAC tech to check your Heat Pump..... It is not working or not heating properly....And you are heating the house with the electric heat strips which will make your electric bill double The electric heat strips are there as back up if the heat pump is not working or keeping up with the heating demand.
Feb 12, 2011 | Heating & Cooling
Tappan electric range, brand new - top heats up
Call the manufacturer and ask them what to do, they can advise you as to what to expect when unit operates and possible cause. Most ranges on broiler will have some heat transfer to top, but this sounds extreme
Apr 25, 2009 | Tappan TEF242 Electric Kitchen Range
Temperature varies 13 degrees around setpoint on aux heat
I don't have the book for this particular unit but, check the sequencers that control the electric heat mode, as the regulator heat pump works good. The part may have a time or temperature delay that is too long for you. Also if it has a remote thermostat, check the heat anticipate setting. You will have to check the installation manuel, but its usually .6 to .8, but I don't think that is the problem.
Nov 28, 2007 | GE Zoneline AZ55H09D Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
