My asus eee harddrive has corrupted how can i get it to work again
  • 326 Answers
You could try a system restore to the point before the files became corrupt, if you dont have a point saved your gonna have to backup what you can and reinstall your operating system
Posted on Aug 11, 2008
Remove asus eee harddrive 1005h
here is a place that will give you step by step directions
http://www.cesgeekbook.com/2009/12/asus-eee-pc-1005hab-tear-down.html
Feb 15, 2013 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
Which mass storage device asus eee1005ha is?
The harddrive
(A USB thumbdrive is a removable mass storage device.
An external harddrive is a removable mass storage device.
A harddrive is a mass storage device that is installed IN the netbook.
NOT considered removable, therefor the one mass storage device)
Regards,
joecoolvette
Dec 17, 2012 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Replacing harddrive Asus Eee PC 1225B-SU17-BK
Please make sure to turn off your unit first, make sure it is unplugged and remove the battery. If you have a screw driver try and find the harddrive bay and remove the cover. You should be able to find your harddrive now but remove it from its place carefully. You know that if you remove your harddrive you have to reinstall your OS and I'm guessing you knew.
Oct 02, 2012 | Asus Notebooks Asus Eee PC 1225B-SU17-BK...
I have a asus Eee pc notebook,when i turn it on the message REBOOT AND SELECT PROPER BOOT DEVICE appears how do i do that?
check if there is any fashdrive or memory card plugged in. if it shows that message it might mean your pc cant detect a bootable harddrive. was it working before? was it dropped or bumped maybe the harddrive got loose. at the bootup screen do you see your harddrive? if your pc can still detect your harddrive try installing a fresh copy or your operating system. hope this helps.
Aug 24, 2011 | ASUS Eee PC 1000HE Netbook
I cant get passed the first screen is says loading os image. con you help?
Sounds as though your harddrive might be virused up...a corrupt registry command preventing it from booting...or your harddrive may be faulty..
Try chk disk command to scan the surface of your harddrive just incase you may have any bad segments...if its all clear,take out your harddrive and virus scan it with another computer...
All else fails...you may have to reformat and try a clean install.....
Apr 03, 2011 | ASUS Eee PC 1000HE Netbook
A new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Mar 29, 2010 | ASUS Eee PC 1000HE Netbook
Is it possible to up grade a asus eee fizz book
Yes it is possible to upgrade the ram and the harddrive, there will be little blanking plates on the back of the laptop, they are held in by small screws, undo the screws and you will have access to the memory and the harddrive. If you are unsure take it to a pc store and ask if they could find out what type of memory and harddrive is needed to upgrade. hope this helps.
Mar 24, 2010 | ASUS Eee PC 900 Notebook
Bios version for asus eee pc 10005ha touchpad screen freezes
Its not the Bos,just dont corrupt the boot procedure with unnecessary key presses.
Or reinstall factory settings properly--it has very little to do with the bios
Dec 18, 2009 | ASUS Eee PC 1000H Laptop
Eee pc linux properties not working
the harddrive is the problem. 4 GB's is a small drive, most programs need space for performance. think about an other larger harddrive.
Mar 18, 2009 | ASUS Eee 4G Notebook
How to install the webcam Eee pc computer?
there is a CD that came with the webcam or the notebook software itself. But, you may have problem with the installation, because of the size of the harddrive. try it anyway. 4Gb's is not a large harddrive. you may need to get a larger one to make it work.
enjoy
Mar 15, 2009 | ASUS Eee 4G Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
