Question about Cameras
Nmgagnon 13 we just cannot get to " Press OK"
    Genius:
  • 3,422 Answers
HI,
What is the make and model no. of your camera?
Posted on Aug 11, 2008
How do i access my reject list samsung GT-E1270
try this: (A complete guide on how to block/unblock a number)
1. From the home screen, press Menu.
2. Scroll to Settings, then press Select.
3. Scroll to Applications, then press Select.
4. Scroll to Call, then press Select.
5. Scroll to All calls, then press Select.
6. Scroll to Auto reject, then press Select.
7. Press Options.
8. Scroll to Create, then press Select.
9. Press OK.
10. Scroll to the required option (e.g. Contact list), then press Select.
11. Scroll to the required number, then press OK.
12. Press Options.
13. Scroll to Save, then press Select.
14. The number has now been blocked. Click Next to continue.
15. To unblock a number scroll to the required number, then press OK.
16. Press Options.
17. Scroll to Save, then press Select.
18. The number has now been unblocked.
Aug 18, 2016 | Samsung Cell Phones
How to calculate fractions in hp 50g
For such a sophisticated calculator (computer) a simple thing like entering a fraction seems too difficult to explain. There are a great number of scientific calculators that handle fractions easily.
Anyway, to manipulate fraction without their being calculated numerically, you must use the CAS.
Press MODE then F3 CAS.
In the CAS screen, move cursor to the _numeric option. If it is cheked, uncheck it by pressing F3:Check.
Press OK to exit the CAS configuration screen. Press OK again to exit the MODE screen.
You can know enter fractions using the division key (Z)
If you type 1/5 + 13/7 you will see 72/35
Now if you enter 1/5 then press the ENTER key you will see 1/5. But if you add to that 13/7 you will see 1/5+13/7 and the result will not be calculated. To calculate the resulting fraction you must press EVAL (Green Left Shift ANS) ENTER.
As you can see, this is not the most efficient way to handle fractions.
Aug 29, 2012 | HP50G Graphing Calculator
How to set time on canan fax l220
on the printer,press function,press data registration,press OK 3 times,Use the numeric buttons to enter the correct day, month, year, and time in this order.* • Enter only the last two digits of the year. • Use the 24hour format for the time (e.g. 1:00 p.m. as 13:00), and precede single digits with a zero. • If you make a mistake, press C and re-enter the date and time. press OK. Press stop to return to standby mode
Jul 28, 2011 | Canon Office Equipment & Supplies
I refill the cartridge of my canon mp496 printer.I print images and everithing is ok but the ink lamps are orange .I don't know what to do ! Please ,help me !!
One of these reset methods should fix the problem
This is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
1. Disconnect the power cable.
2. Hold down "On/Off" button.
3. Reconnect the power cable.
4. With the power button still down, press the "Stop/Reset" button twice.
5. Release the "On/Off" button.
6. The printer is now in "factory mode".
- wait until "idle" is displayed.
7. Press the right arrow button (next to the "OK" button) repeatedly until "Shipping Mode 3" is displayed.
8. Press the "OK" Button
9. Wait until "Without Cleaning" is displayed and then presss the "Stop/Reset" button once. (I pressed the ok button after Stop/Reset button on my MP470).
10. A test page should print.
11. Open the cover.
- the cartridges should position themselves at the far left - the cartridge removal location.
12. Disconnect the power cable.
13. Remove both cartridges.
14. Close the cover.
15. Reconnect the power cable.
16. Press the "On/Off" button once.
17. Wait until a "Replace Cartridges" message is displayed.
- insert cartridges.
18. Wait until the printer is operating in its normal mode. The display shows the normal start menu (ie: Copy).
The ink levels have been reset.
- check by going to printer>properties>maintenance>view printer status
this is what i had to do to get it to work with canon mp460
2. Hold down power button
4. With the power button still down, press twice the "Cancel/Stop" red button
5. Release the power button
6. The printer is now in factory mode...(wait about 30 seconds until it says "idle")
7. Press the down arrow (next to the "OK" button) until it says "Shipping Mode 1"
9. Now with it displaying "Without Cleaning" press the power button
11. Now open cover
12. Disconnect the power again
13. Take both cartridges out like normal
14. Close cover
15. Reconnect power cable
16. Press power button
17. Replace cartridges
MP-160 is different from MX300 so I tried my best with it...
The main solution is to reset the entire printer:
2. Connect it while holding down the power button
3. With the power button still down, press twice the "Cancel/Stop" red button
4. Release the power button
5. The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
6. Press the ">" (next to the "OK" button) once."Shipping Mode 3"
7. Press the "OK" button.
8. Press "OK" again for "Without cleaning"
9. A test page will print..
10. Open the cover, like you are about to change the cartridges.
11. Disconnect the power cable again.
12. Take out both cartridges.
13. Close the cover.
14. Connect the power cable once again.
15. Turn the printer on.
16. Now just put the cartridges back...
Jul 01, 2011 | Office Equipment & Supplies
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
Please help me for Code 21:13
21:13 says that the Service Station failed to move.
Power down and unplug it from the wall. Wait a little bit and plug it in and power up.
Make sure that the Service Station path is clear.
Run the Service Station diagnostic test.
In the Diagnostic Menu, scroll to 8. Service Station and press OK
The front panel will show the 8. Service Station submenu.
In the 8 submenu scroll to Service Station and press OK to start the test.
Could have bad Service Station or Print Mech.
There could also be something impeding the movement of the Service Station.
Apr 11, 2011 | HP Designjet T1100ps Printer
Replaced ink compatable cartridges in my cannon pixma 350 and now its telling me to replace them cause the ink is empty Help
This will reset your cartridges to full settings. I have found these resets to work on many Canon models. Try the top one first.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon PIXMA MX350 Wireless All-in-One...
Canon np258 cant operate after refill
You may need to reset the ink counter. Try one of the following solutions.
THis is the procedure I used for an MP470. It is basically a modified version of that previously posted for the MP460.
11. Open the cover.
11. Now open cover
14. Close cover
Mar 27, 2011 | Canon Office Equipment & Supplies
Storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Aug 18, 2008 | Office Equipment & Supplies
Fax Confirmation on a Canon MP830
To print a TX (transmission) report after each fax sent:
1. Press the Copy button if that light is not already lit
2. Press the Menu button
3. Press the Right arrow to get to "Maintenance / settings"
4. Press the OK button
5. Press the Right arrow to get to "Device settings"
6. Press the OK button
7. (You should be at FAX SETTINGS) Press the OK button again
8. Press the down arrow to get to "TX settings"
9. Press the OK button
10. Press the down arrow to get to "TX report"
11. Press the OK button
11. Press the down arrow to get to "Print for each TX"
12. Press the OK button
(You can have the machine print the first page of the fax with the report if desired)
13. Press Stop / Reset
Apr 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
