Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water leaking from bottom right-rear near valve. Changed inside filter.
Water leaking. Changed inside filter but problem persist. Is there another filter?
You might have a clogged drain in the bottom back of the freezer. When the freezer defrosts the water has no where to go and comes out the front.
Posted on Aug 15, 2008
I just changed the filter and flushed the water for a few minutes, however, it's still dripping
Was it leaking before changing the filter? It could be that the water valve in back is leaking a bit. Sometimes the valve gets a very small bit of grit in it and doesn't completely shut off. The way to tell is to remove the hose from the valve and see if water is dripping from it at the valve. If it isn't then maybe the water reservoir is partially frozen and causing a pressure build up in the reservoir. If this is the case the dripping should stop after a couple minutes. I would look at the valve.
Sep 12, 2014 | Samsung RF265AA Bottom Freezer French Door...
How do I install new water filter and where do I pour water in the refrigerator
Usually a water line & valve to turn it on/off are required & connect at the bottom rear of the fridge. Our filter is mount inside near the rear of the fresh food side & allows the water to flow through it until you push it upwards to turn & remove & change it & then allows the water to again flow after you have turned the new filter back in place. If you have a water line connected I would turn the water off while doing this the first time just in case it runs out at a pressure all over.
Dec 12, 2013 | Samsung Refrigerators
My Amana french door/bottom freezer is leaking water. Did the procedure with hot water the drain in back of the freezer, although it seemed clear of ice. That didn't help. The leaking stops when I...
Two possibilities:
1. A cracked plastic tube. These will leak whenever there's a call for water - either the chilled water dispenser, or re-filling the icemaker tray (two seperate tubes). Pay particular attention to anywhere the tubes are clamped to the chassis; anywhere they're routed near or under the refrigeration unit; and near the solenoid valve - especially if there's a tight loop in the tube there.
2. A bad (leaking) connection where one of the tubes exits the water valve. Again, these will leak whenever the valve is activated.
Those plastic tubes don't last forever. I've replaced many of them for the same symptoms. They're known to simply deteriorate with age.
Manuf's make good money selling replacement tubing kits.
Aug 15, 2011 | Amana AFB2534DE Bottom Freezer French Door...
Cannot afford a plumbing or to replace the
F8 would indicate a water level failure.
Check that the drain hose hasn't dropped down too low and also check that the water isn't siphoning out because the drain hose is too far into the stand pipe.
Check that the filters, especially the fine mesh one, is clean and clear.
If neither of the above, take the filters out, clean out the black grid on the right side of the sump.. Pour a kettle of boiling water into the sump getting as much as possible into the black grid. Select the hottest wash and try the machine again.
You could also look at the below points :-
Dishwasher Leaking
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Let me know, if the problem persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Kenmore 15129 Built-in Dishwasher
Where is the water inlet valve located on this model>>>I thought it would be back side, lower left near water hook up
Follow the water line from the wall to the frig, it normally goes to water filter first, from there to water valve located on right rear (in most cases) of frig. Just follow the plastic lines. Another way to find it is to follow the line from the ice maker back to the water valve.
Oct 17, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
I had the valve cover gasket changed on my 1996
on a v6 ? Low on oil? rear cam plugs leaking? The lifters are on the end of the rocker arms and may get clogged. I have had some luck running 0w30 mobil synthetic for about a week or so with a new oil filter [Not a fram filter] and after that put 10w30 synthetic oil back in and a new filter. Check for oil leaking at other locations. If the noise is at the front of engine near water pump it may be the hydraulic timing belt tensioner.
Oct 06, 2009 | 1996 Isuzu Rodeo
Kenmore 24632 leaks water from right rear corner
The problem may be attributed to either a leaking water inlet valve, or the associated internal hoses that run from the valve to the dispenser. The following link explains how to access the inside of the washer and/or replace the valve (if required):
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
If parts are required, you can purchase from any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop all of them for the best deals.
If you have any questions abou this repair, or require additional assistance, please let me know. I hope you find this helpful.
Jul 30, 2009 | Kenmore 24632 Top Load Washer
Washing machine has f05 flashing on a hotpoint machine it wont pump out and cant get door open
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Good Luck!!
Thanks
Jul 19, 2009 | Hotpoint Ariston AS65VXSNA Electric Dryer
Our maytag side by side refrigerator is leaking from the freezer
Check the filter. See if its connected right. Sometimes the old (BAD-need replacement) filter back pressure the water and if the seal or gasket is not good enough, you will have water leak. But in this case you will notice the water path inside the fridge too.
Jun 18, 2009 | Maytag MSD2656G Side by Side Refrigerator
GE refrigerator, leaking water filter
The area above my water filter in my refrigerator is leaking. I doesn't leak until we run the water in the front of the door or the icemaker runs.I have changed the filer and the problem persists. Is there a part above the filter that needs replaced? The model # is GE TFX26ZPDABB. Thanks.
May 19, 2008 | Refrigerators
Frigidaire FRS26R4A Side by Side Refrigerator Logo
163 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
