Question about Samsung CLP-510 Laser Printer
Pink stream of dots running half way across page left to right
Hi hope you can help me i have changed the transfer belt and the drum but i still keep getting the stream of pnk dots running across the first halh of the page.
Does not look too bad on a picture but look very bad on a letter.
Hope someone can help, hear from you soon
Gary
  • 446 Answers
The pink spot you have seen is a residual magenta toner drops from the developing assy, either ther is too much toner accumulated in the drum unit, or within the viccinity.
removed the magenta u nit, and clean all toner, removed the drum if you can and vacuum the cleaning unit that scrape off toner from the drum, chances are this area is full of toner that has stucked, carefully install the drum unit and test
so as far as your transfer unit, very rare cases that this would contribute to that prob, but ensure that you put all connectors tightly and if there is any electrical connectivity that you recently seen, secure this parts correctly..
hope this helps and remember to mark this pls
Posted on Aug 16, 2008
Letters in Black have a faint light blue "ghost" to the left of each letter but only on the right side of the page.
registration is slightly off. I'd try re-setting the drums (take out and put in again). If you have another cyan drum, would also try that. Transfer belt would be next
May 06, 2015 | Xante Ilumina Digital Color Press Printer
I have just collected a second hand HP 1600 printer and there is a 2cm green vertical line down the left side of the page and a 3mm line down the centre and 2 thin lines down the right side, help!
Dots, Lines and smudges on the printouts are due to deteriorating cartridges and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines. (corresponding to the location where you are having a green line on the paper)
Also, make sure that the visible inside of the printer and the Black belt are clean and there is no spilled toner inside, which sometimes results in dots.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Replace the Cartridge or get the PCR Roller changed by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet 1600 Printer
Hi Everytning I print has a very narrow pink line straight down the centre of the page, also every so often the print has a black/yellow/blue/pink thick line running across the page. Thanks
The narrow pink line is coming from your magenta toner/drum cartridge. You may be able to open the from cover and look at the 4 toners. If you look at the magenta (like pink) cartridge, you might see the thin line on the drum surface.
The multicolored band that sometimes shows up on your prints is most likely the transfer belt unit. This is caused by an area of the belt that is not being cleaned very well. This probably tends to show up when you are running mutilple prints of a page.
So it looks like to may need to replace your magenta toner and look at getting a transfer belt unit.
May 13, 2010 | HP Color LaserJet 2600n Printer
Dull colors on half the page
I would replace the transfer belt see if that makes a diffrence hope this helps
Nov 20, 2009 | HP Color LaserJet 2600n Printer
Faint red line across page when making color copies or printing in color from computer
Some possibilities are:
1) Dirt on the glass, dirt on the glass strip for the doc feeder, or dust on the mirrors. This would be the case if the line only showed when copying and not printing.
2) Toner dropped onto the charge sawtooth.
This may be possible if the line is intermittent and only showed up for 1 or 2 colors.
Open the front door and remove the waste toner box. To the left of each drum there is a green organ-stop type stem. Pull and reinsert each stem. You will hear a zipping noise. These are your charge scrubbers.
This may be not as likely if the line shows up in the same place on all 4 colors
3) Toner or dust on the lens
In the area where the waste toner box goes, look for a grey stick with a white cushion on the end. This is your lens scrubber. Look in the area under the charge scrubber on each drum cartridge for a gap. Insert the scrubber cushion side down into the gap and run it forward and back to clean the lens.
4) Transfer belt blade not cleaning
This is best handled by a service tech since the mylar belt is very fragile. The squeegee blade that cleans the transfer belt between copies is missing a spot. The blade needs to be taken off the belt, cleaned and repowdered. Recently, Sharp made changes to the composition and thickness of the mylar in the transfer belts. Overpowdering the blade or belt when it was changed may cause improper cleaning of the belt creating lines across the copies. Often the condition clears up after a couple of days as the gap between the blade and belt is sealed.
This is most likely the cause as the line shows up in the same area for more than 1 color.
5) Transfer belt and/or blade is worn out
If the belt is worn the blade must be replaced but not vice versa.
6) Clogged waste augers in the drum cartridges.
Waste toner may cake up in the drum cartridge and knock loose on the drum.
It may be time for full maintenance on the machine.
Jun 02, 2009 | Sharp MX-2700N Color Copier
Hp 4550n color laserjet printer prints blank pages nonstop.
Hi, I notice you have ruled out the transfer belt as asolution because it has 59% life left. Not to be rude but this does not exclude the transfer belt as the problem. I am 98%-100% sure that if you change the trasnsfer belt you will solve your problem.
I was doing work for a large corp. that sent a guy from Ohio to Colorado twice for this problem before he asked my opinion I told him tranfer belt. He was a Hero.
Hope this helps.
Mar 06, 2009 | HP Color LaserJet 4550n Printer
Brother HL 2070N Drum Unit changed but printing with dots on the left hand side
If toner leaked into the machine and got on the fuser that could cause this, but the dots would go away after a few prints. Try another drum unit.
Oct 28, 2008 | Brother HL-2070N Laser Printer
Poor color quality
find out where are the streaks come from, from PC drum, or transfer belt, fusin unit or from toner cartridges. does the trasferbelt and PC drum look okey. finally if nothing is helping, try firmware upgrade and replace printer drivers, sometimes help.
Feb 02, 2008 | Konica Minolta magicolor 2430 DL Laser...
White line across printed page
Hi Alms, Is there any chance you can post a scan of one of your faulty pages. This would help to assess the fault. If you print several pages, does the image move further and further down the page with each copy? Is the white band repeated down the page? If so measure the distance between each band - this will help identify the faulty component.
May 21, 2007 | Minolta magicolor 2200 DeskLaser Printer
Samsung CLP-510 Laser Printer Logo
305 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
