Question about HP Office Equipment & Supplies
I have a designated fax line with the machine hooked up to it but it still keeps answering the other phone calls that come in.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
If it is the same line but with a different number then you need to set up the number in the fax machine.
If it is supposed to be a different line there is a cross connection somwhere other wise how can it pick up the other calls???/
Posted on Aug 11, 2008
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Tip
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
How to you hook up an answering machine to a Samsung all in one printer
there should be two phone jacks in the back one says phone plug your answering machine into it
Aug 28, 2009 | Samsung SCX 4521F All-In-One Laser Printer
How could I switch the fax, to receive
do you mean the fax line is shared with the phone line, and you want the machine to pick up faxes when necessary, and let phone calls go? If that's the case, this mahcine is designed to be on a dedicated line. In other words, there is not setting for "distinctive ring", or to set the # of rings to pick up. It will answer any call coming in. The only thing you can do is set it to "manual receive", under "user tools", "fax features", and then you could use it for sending faxes, but it will not receive unless you switch it to fax, and press the "on hook" button.
Jun 12, 2009 | Ricoh Aficio 1232C Color Copier
Why is my fax machine saying phone off hook when its really not. All tests passed except the fax line condition. It says its weak.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Replace the phone line cable.
Remove the handsetn or at least unplug it.
Hope this is of some help.
ED
Apr 23, 2009 | Xerox WorkCentre Pro 555 Plain Paper Laser...
Fax one phone/fax line but always answered by fax
You can change the number of rings before the fax machine can pick up. Three is usually a good number. You would have to pickup the phone on the first two rings.
They make devices that do that but everytime I have used them I would end up getting the fax tone when I'm trying to make a voice. The boxes are great at dealing with incomming phone calls from pstn or land line based calls, but if you are getting cell phone calls or voice calls comming in from digital, DSL, or VOIP lines, it has a hard time sensing voice from fax when people are using phones like that. There designed for analog phone line installation but if you're on a DSL they won't work.
Sep 15, 2008 | Samsung CLX 3160fn All-In-One Printer
Will not send faxes
Make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to add a telephone to the fax. If it is connected properly, try calling your fax from a cell phone and see if it answers. If the fax answers, hang up and press the HOOK button on your fax and use the fax keypad to call your cell. If the cell rings, answer the call and listen for the fax machine tones. If you hear the fax on the cell, you may have to change your machines TRANSMIT or DIALING settings.
Jul 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Sending faxes
You can hook a fax to any standard phone line. That is what they are designed for. The only issue is if you share the fax with your telephone, you will need to set the machine up to receive the fax before you answer the phone.
Jun 13, 2008 | Lexmark Office Equipment & Supplies
Weboughta 1040 fax machine. our phone system is bell canada. the answering system and call waiting will not work when fax is hooked up
Fax machines are designed to have their own dedicated analog phone line.
Any other condition is a **** shoot.
Apr 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
