Question about Microsoft Office Professional 2007 Full Version for PC
Query About Access Database
ERROR [HY000] [Microsoft][ODBC Microsoft Access Driver] Operation must use an updateable query. m getting this error though i set all permissions on mdb file...wat to do??
I am trying to correct autonumber it has missed out a number
Posted on Sep 13, 2008
Yes
Posted on Aug 22, 2008
  • Microsoft Master
  • 2,794 Answers
Is your ODBC driver set for this database in the control panel as well?
Just checking............
Posted on Aug 21, 2008
SOURCE:
HOW TO CONNECT DATABASE TO VISUA LBASIC 6.0
You'll need to instantiate (create an instance of, or an item in memory) what is known as an ODBC connector. You will also need to create a database or have a database to work with - Microsoft Access will work fine for this, alternatively you can use OpenOffice's version of Access.
The code you'll want to use will be approximately
Dim ws as Workspace dim db as database dim strConnection as string set ws=DBEngine.Workspaces(0) let strConnection= "ODBC;DSN=" & DatabaseName & ";UID=" & UserName & ";PWD=" & UserPassword set db=ws.OpenDatabase("", False, False, strConnection)
Apr 07, 2011 | Microsoft Windows XP Professional
Can you give sample source code of visual foxpro program using mySql as database flatform
Create a connection: lcStringCnxRemoto = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=200.1.1.1;" + ; "PORT=3333;" + ; "UID=booking;" + ; "PWD=booking;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" lcStringCnxLocal = "DRIVER={MySQL ODBC 3.51 Driver};" + ; "SERVER=localhost;" + ; "UID=root;" + ; "PWD=clave;" + ; "DATABASE=booking;" + ; "OPTIONS=131329;" SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal)
Accesing data:
SQLSETPROP(0,"DispLogin" , 3 ) lnHandle = SQLSTRINGCONNECT(lcStringCnxLocal) IF lnHandle > 0 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype","cur_roomtype") IF cmd > 0 BROWSE ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2]) ENDIF USE IN cur_roomtype SQLDISCONNECT(lnHandle) ELSE AERROR(laErr) MESSAGEBOX("Can't connect to mySQL. Error: " + CHR(13) + laErr[2])
ENDIF
Creating complex sentences:
TEXT TO lcSQLcommand NOSHOW SELECT Inventory.inventoryid, Inventory.date, Inventory.roomtypeid, Inventory.sold, Roomtype.descrip, Roomtype.rooms FROM inventory Inventory INNER JOIN roomtype Roomtype ON Inventory.roomtypeid = Roomtype.roomTypeID ORDER BY Inventory.date DESC ENDTEXT cmd = SQLEXEC(lnHandle,lcSQLcommand)
Passing parameters to a query:
nValor = 12 cmd = SQLEXEC(lnHandle,"select QuantityRooms from roomtype where roomtypeid = ?nValor","cur_roomtype")
Calling a Stored Procedure:
SQLEXEC(lnHandle, "call myStoreProcedure(@param1)")
GOOD LUCK!
Mar 17, 2011 | Microsoft Visual FoxPro Professional...
Please give me the procedure how to import foxpro files in tally 7.2
To import data from a FoxPro database, use the Microsoft Visual FoxPro ODBC driver. To do so, follow these steps:
1) Click Start, and then click Control Panel.
2) In Control Panel, double-click Administrative Tools.
3) In the Administrative Tools window, double-click Data Sources (ODBC), and then add a new ODBC data source for your FoxPro database or tables by selecting the appropriate Visual FoxPro driver.
4) Start Access, and then open your Access database. 5) On the File menu, point to Get External Data, and then click Import. 6) In the Import dialog box, click ODBC Databases in the Files of type list. 7) In the Select Data Source dialog box, click the Visual FoxPro data source that you created in step 3, and then click OK. 8) In the Import Objects dialog box, click the tables that you want to import, and then click OK.
Jul 05, 2010 | Computers & Internet
How to insert datepicker value in access with use of C#
1.U have to create one acess database .
2 create connection to database using odbc or oledb connection.
3.Write one insert query.
4 execute that query.
5.close the connection
Nov 16, 2009 | Microsoft Visual Basic .NET Standard 2003...
Same as above really
I have fixed my problem. I realised that the Microsoft Access Database DSN did not include the *.accdb driver. I deleted the existing DSN and created a new one. This allowed me to select the ODBC driver that worked for both file types.
I cameto realise that I was only having this problem on machines that have been upgraded to excel 2007 and not on machines with full virgin installations. On install both try to create the appropriate DSN but one with the same name already exists on the machines being upgraded and the creation fails.
I hope this helps others.
Jul 18, 2009 | Microsoft Excel for PC
Microsoft OLE DB Provider for ODBC Drivers error '80040e31' [Microsoft][ODBC SQL Server Driver]Timeout expired . How to solve this problem.
There are several things that could cause this to appear....Try this link: http://social.msdn.microsoft.com/Forums/en-US/sqldataaccess/thread/cccea79b-f7c8-4fd4-85b8-7182d92d8f91/
If that doesn't answer your query, please consult this list and apply the fix that most closely relates to your particular circumstance...
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=Microsoft+OLE+DB+Provider+for+ODBC+Drivers+error+%2780040e31%2
I hope that helps to clear it up!
Mar 27, 2009 | Microsoft Windows XP Professional
How to write jdbc connections
http://www.jdbc-tutorial.com/
window.google_render_ad();
welcome_title_image.gif Java JDBC Tutorial Java JDBC Tutorial
The JDBC ( Java Database Connectivity) API defines interfaces and classes for writing database applications in Java by making database connections. Using JDBC you can send SQL, PL/SQL statements to almost any relational database. JDBC is a Java API for executing SQL statements and supports basic SQL functionality. It provides RDBMS access by allowing you to embed SQL inside Java code. Because Java can run on a thin client, applets embedded in Web pages can contain downloadable JDBC code to enable remote database access. You will learn how to create a table, insert values into it, query the table, retrieve results, and update the table with the help of a JDBC Program example.
Although JDBC was designed specifically to provide a Java interface to relational databases, you may find that you need to write Java code to access non-relational databases as well.
JDBC Architecture jdbc.jpg Java application calls the JDBC library. JDBC loads a driver which talks to the database. We can change database engines without changing database code.
JDBC Basics - Java Database Connectivity Steps Before you can create a java jdbc connection to the database, you must first import the
java.sql package.
import java.sql.*; The star ( * ) indicates that all of the classes in the package java.sql are to be imported.
1. Loading a database driver,
In this step of the jdbc connection process, we load the driver class by calling Class.forName() with the Driver class name as an argument. Once loaded, the Driver class creates an instance of itself. A client can connect to Database Server through JDBC Driver. Since most of the Database servers support ODBC driver therefore JDBC-ODBC Bridge driver is commonly used.
The return type of the Class.forName (String ClassName) method is “Class”. Class is a class in
java.lang package.
try { Class.forName(”sun.jdbc.odbc.JdbcOdbcDriver”); //Or any other driver } catch(Exception x){ System.out.println( “Unable to load the driver class!” ); } 2. Creating a oracle jdbc Connection
The JDBC DriverManager class defines objects which can connect Java applications to a JDBC driver. DriverManager is considered the backbone of JDBC architecture. DriverManager class manages the JDBC drivers that are installed on the system. Its getConnection() method is used to establish a connection to a database. It uses a username, password, and a jdbc url to establish a connection to the database and returns a connection object. A jdbc Connection represents a session/connection with a specific database. Within the context of a Connection, SQL, PL/SQL statements are executed and results are returned. An application can have one or more connections with a single database, or it can have many connections with different databases. A Connection object provides metadata i.e. information about the database, tables, and fields. It also contains methods to deal with transactions.
JDBC URL Syntax:: jdbc: <subprotocol>: <subname> JDBC URL Example:: jdbc: <subprotocol>: <subname>•Each driver
Feb 01, 2009 | Microsoft Windows XP Home Edition
ODBC
give ur add i want to check it out.
Aug 26, 2008 | Microsoft Windows Server Standard 2003 for...
I am getting this error when I attempt to open my staff directory (where the data is supposed to show up on the website): Microsoft OLE DB Provider for ODBC Drivers error '80040e10' [Microsoft][ODBC...
Talk to the person that created the database for the website.
The problem is in the program parameters and not something that can be control by a person viewing it.
Jul 28, 2008 | Computers & Internet
ODBC DRIVER MANAGER FOR RUN TIME ERROR 2147467259
Go to Administrative Tools, Data Sources (ODBC). Check your connection info and test the connection manually there. You may have the wrong user/password combination, or the database name or location is wrong.
Jul 10, 2008 | Microsoft Windows XP Professional With...
Microsoft Office Professional 2007 Full Version for PC Logo
107 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
