My Bushnell STEALTHVIEW Night Vision screen goes into a clear white with no images when turned on. Tried to focus, but the screen remains an illuminated white - no images.
Weaver Opticshttps://www.weaveroptics.com > w-repair
Our repairs are handled by Bushnell Outdoor Products and you can find out how send in your Weaver Products for repair or check the status of an existing ...
Missing: Night Vision
Bushnellhttps://www.bushnell.com > w-repair
Hello, when you turn on you Bushnell NV devise does the green come on , looking
through eye piece. If it a white oval screen, then check the batteries and make
sure the polarity is correct.
If you don't have the green screen in the image tube. Then it not working normally and they is a good possibly that the image intensifier tube is bad. Contact Bushnell ask them what it cost to repair it. stewbison
What color is it when you turn on you Bushnell binoculars? I think this Bushnell 26-3150 is a digital NV devise that uses CCTV image tube. In other words, it not anolog operation, but uses a digital devise to convert the iit (image intensifier tube) analog signal to a digital signal. There are advantages using digital signal, increase pixel rate, low power comsuption, etc. stewbison. Call Bushnell Night Vision and listen what they have say on this matter. stewbison.
Hello, welcome to the Russian fablouse image intensifier tube that will destroy itself while setting the closet. You can call Bushnell and ask them what will it cost to repair this monocular. It might be cost prohibitive to do so. If you have had a few years, then sell it on eBay as "night vision parts" Sorry, GB....stewbison
Depending on the configuration of the battery pack, it may be only available from the manufacturer.
If a more common battery pack, you may get one from an alternative supplier.
There are a number of fairly common packs made up of individual cells.
You might compare the pack to those available on eBay.
They do stay on for a while after switch, that is OK. Dim and out of focus may indicate that the output voltage is low. If replacing the battery does not fix it, then the problem may be in the power supply circuit.
1.Start sky watching with moon .You try to locket moon first.See proper how change in vision using focusing knob.
2. Than you try to see Jupitor,Seturn etc.
