Question about SanDisk Sansa e250 MP3 Player
Unable to charge the player
Hi i have bought sansa e250 player recently..........when iam trying to charge it by conecting to the system, it is getting charged for a while until backlight glows and then the charging is getting stopped. Please help me in this.
  • 8,596 Answers
Off-hand that sounds like normal behavior - unless it stops charging after, like, 2 minutes
if this is the case:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
RSanDisk Sansa e250 MP3 Player does not conect to compute
check for hold button whether its locked out or unlocked.
Jan 19, 2014 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player could not detect micro sd add on card
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 mp3 player
Yes I have How do I fix it
Dec 18, 2007 | SanDisk Sansa e250 MP3 Player
How to upload songs into Sansa E250
Th device may be too full. You need at least 6MB for each GB of music on the device to create the "database" or GUI. Delete a few song, restart the device. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Problem in charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 06, 2007 | SanDisk Sansa e250 MP3 Player
Some tracks are not being heard
Try updating the firmware on the device. Sansa Firmware updater; http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
Help
u shud had taken the ply\ayer with the cords.
Sep 02, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Apr 25, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
