Computers & Internet Logo
Posted on May 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn on wireless on a gateway computer
Anonymous
Level 3:
President:
  • Master 1,285 Answers
  • Posted on May 01, 2011
Anonymous
Master
Level 3:
President:
Answers
1285
Questions
Helped
296748
Points
3126
2 ways ... look at the bottom right hand corner for a TV like icon w/ red X...click on it and find a connection or go to start, all connection (you should have two TV like icon one is wireless and the other is LAN (wired)) right click on the wireless repair it ...if you are near a connection your laptop (TV like will light up) this is how you know you have internet connection
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Wireless wont turn on using F2 key. is this
There is a physical wireless switch on the left side of the computer. The switch turns both the wireless network adapter and the bluetooth on and off. You need to first make sure that this switch is on.
With switch in the ON postiton, then you can use the FN-F2 keys to toggle the wireless LAN on and off.
The wireless adaptor is probably a mini-pci card that can be access through a panel on the bottom. Wireless cards on laptops are not considered user-replaceable so Gateway does not show where the panel is or if it's mini-pci card. If there is a panel other than the hard drive and memory then that is where the wireless card is. They are not hard to replace though it's best to try to replace it with an exact model.
If the computer is in warranty, they Gateway will have you send it into their service depot to have it replaced,
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
2answers
I have a dsl 2w gateway and I am unable to get the wireless light to come on can YOU help me?????????
You didnt mentioned about the model of gateway laptop, you can turn on the wireless by pressing (Fn+F2) together
Lost wireless connection and yet it works with other computers... do I have an on/off switch on a Gateway 600y?
To turn the wireless emitter on or off in Windows XP:
1 Click Start, then click Control Panel. The Control Panel window opens. If your
Control Panel is in Category View, click Network and Internet Connections.
The Network and Internet Connections window opens.
2 Click/Double-click Network Connections. The Network Connections window
opens.
3 Right-click Wireless Network Connection, then click Enable to turn on the
wireless emitter or click Disable to turn off the wireless emitter.
3helpful
I have a Gateway 7322 laptop. I'm trying to hook
Press the Fn key down, hold it down, then press the F2 key.
Here is the download page for the Gateway Notebook User Guide,
http://support.gateway.com/s/Mobile/Gateway/7305GZ/4429ul.shtml
Wireless connection
Gateway should have it's own software but...you can start with Connect To on the Windows Start Menu and choose wireless connection.
What OS?
2answers
Gateway 4026GZ lost wireless ability
Make sure your wireless card is on (use Fn + F2 to toggle on and off).
Also make sure it is enabled by going to control panel -> network connections and right clicking on your wireless network device and going down to enabled.
Actiontec wireless router
This is a Wireless Gateway not a router. Although the Actiontec website says that it uses NAT firewall like a router would.
If you do not get any green lights this usually means the wireless gateway is broken. Try plugging it into power but not the modem. Wait a few seconds. Are there any green lights?
If so, then the gateway is not configured correctly to work with your modem. You may have a smart modem. Call your ISP, for help.
If not, then it is probably a bad gateway. You can try to connect to the configuration web page that comes with the gateway. OR Power on the unit while holding down the Reset button for a minute. This will reset it to factory defaults.
ActionTec
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
