CFL bulbs are held in place by a friction fit, but it is a very tight fit. Grasp the CFL by the sqaure plastic base and pull firmly away from the socket. You may have to wiggle it a little, but don't try to pull it out by the globe because they are very fragile and break easily. I would imagine the pins would be interchangeable with some other model, depending on the number of tubes and the number of pins. Just take your bulb with you to compare. If you have any specialty electrical supply houses in your town, that would be a great place to look. I'm giving you a link where you can order them if all else fails, but CFLs have become pretty common, so you shouldn't have too much trouble finding one.
http://www.e-conolight.com/lamps/lamps-compact-fluorescent.html
I figured out on my own that the bulb had to be slid sideways out of the socket. I wore work gloves in case the bulb broke, and it was especially important to use a pliers to hold the socket that's wired through the ceiling while I used my other hand to move the bulb around until I finally figured out that it slid out sideways. Had I followed the above instructions and just pulled firmly away from the socket, I would've broken the bulb, which was exactly what I was trying to avoid.
By the way, this bulb is a Torchiere 2D Compact Fluorescent Lamp.
My apologies for misleading you. I didn't realize it was a lamp of the variety you described in your reply. I was under the impression that you were dealing with a more conventional CFL like the ones in the link I sent you. At any rate, I'm glad you were able to figure it out without injury and your problem is solved.
