Question about Gateway FPD2275W LCD Monitor
Monitor goes black
While working the monitor power goes off and comes on ! sometimes i need
to switch it on .
in the screen brightness , volume , no signal comes on and goes off
please help
  • ihagmann Aug 12, 2008
    my monitor goes on and off. Apears windows is loading but the moitor is blinking on and off.
    I have connected another monitor to the machine and it works fine. so not the pc. or dirvers.
  • ltoney512 Aug 25, 2008
    I am having the same problem, the monitor is flickering on and off, I connected another monitor and it worked fine, some one please help!!!!
    Problem Solver:
  • 5 Answers
Snava, Ihagmann,
Have you checked how firmly is the power cable attached to the monitor? Can you reproduce the problem by moving either end or twisting the cable in different parts?
Have you tried a different power cable?
Posted on Aug 12, 2008
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
My LG 2353 monitor screen goes blank by itself. Sometimes it will go into sleep mode or sometimes my screen just blanks out and the power light stays solid red without flickering to indicate whether or not...
shaylane_195, Good description of problem! But you left out one or two key things to tell me. Age of monitor? Approximate total "ON" hours of use? Is unit covered by LG (Lucky Goldstar) warranty? You and only you can tell me if the screen is really BLANK, or is it only BLACK? Do flashlight test to determine true state of screen! Can you see very, very faint image of WIN-desktop holding bright flashlight near your black screen? This monitor works!!! You just need to fix the possible (1) "cold, frosty looking, thermally intermittant solder connection on the "internal switch-mode-power-supply/CCFL inverter board. Yes, your monitor along with many other CCFL back-lit LCD units of all brands also could have some BAD, swollen, leaky electrolytic filter capacitors installed on the SMPS/CCFL inverter board which will need to be replaced with new ones of higher quality. Get back to me, lmistyrel on aim. or do additional comment on fixya, after you do some reading in my and other fixya tech's profiles to discover all options you as consumer/user have open to you. Bye for now. 12fixlouie
Mar 04, 2010 | LG W2353V-PF 23' LCD Monitor
Screen Black but Working
It goes black because it went into shutdown due to fault in the inverter circuits, check the 4 transistors in the inverter circuits for shorts, http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Feb 14, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Power on - blank (black) screen
Disconnect the monitor signal cable from PC and switch on your monitor. It should show some logo with Red, Green and Blue colors with a message similar to "No signal". If so, your monitor is working fine. Sometimes if the brightness and contrast is set to zero using controls present in the monitor, it will not show up anything. check wheather somebody set your monitor brightness and contrast to zero. If so incease them. As a last try connect to different PC and check before approaching a service center. I hope this will help you out. :)
Aug 21, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Monitor black screen
Your first step in troubleshooting this problem is to plug in another monitor to your computer. If you are having the same problem it is related to your computer. If the second monitor works fine then your original monitor is shot.
May 11, 2008 | Mag Innovision LT776s 17" LCD Monitor
Sony SDM HS93 works fine, but: Monitor will not turn on with power button, if I plug in A/C cord power light goes on, monitor works. Sometimes the monitor comes on too bright, other times, too dim....
i get same..controls not working ,,sometimes menu button works and one arrow button..button "ok" button doesnt work and up arrow...brightness not working.
i get black box in upper left corner...quite diffucult to get rid of.
G
iamthehipster@yahoo.com
Feb 25, 2008 | Sony SDM HS93 19" LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD2275W LCD Monitor Logo
88 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
