Compuet dont recognize hard disc
Hi... my computer is recognizing it as an USB mass storage device.. but in "my computer" i donot see it as a drive.. cannot do anything.. tried to change the USB cable .. but no use.. i see the blue light is glowing in the device
  • Anonymous Jan 16, 2009
    windows vista new computer does not recognize hard drive
  • 162 Answers
Could be your windows needs to be updated are you running sp2 or vista?
Posted on Aug 12, 2008
Sony Micro Drive USD5G not recognized. I plug it in and computer does not see it. Same effect on all computers tried on. Any suggestions?
You should connect the sony micro device to your computer once its connected to the usb lead it should automatically in windows 7 or you might have to open it open up manually it might be listed as a mass storage device click start right click on my computer you should see your mass storage device if you dont see it
click start control panel administration tools computer management device manager scroll through all of the devices if you see a yellow question or exclamation mark or a red x you will need to update the driver right click on the device to update driver
if your computer came with a motherboard disc the drivers could be on it
if you can see your usb but its not working
ports(com&lpt)right click update driver :hope this helps:
Jul 05, 2011 | Sony Micro Vault Pro USD-5G (USD5G) 5 GB...
Every time i plug in my sony camera to the usb port to upload my pictures, my camera will say " usb mode. connecting to mass storage" then that will go away after a few seconds and then it...
The "USB mode" and "Connecting to Mass Storage" message will get displayed when the Camera is connected to the Computer and is recognized by the Computer as a Mass Storage device. This is not an error message and is a normal operation.
You can change the Mass Storage settings in the Camera (depends on the model) The USB Select or USB Connect option in the Camera can be changed to PTP, Mass Storage or PictBridge mode. Set the option in the Camera to PTP and connect it to the Computer and check if the Computer is recognizing the connection. Once the computer is recognized, it appear as a removable Drive.
You can transfer the images from the Camera to the Computer from the Removable Drive by copying and pasting.
Thanks for contacting FixYa.
Apr 07, 2011 | Sony Cameras
My computor doesnt recognize the hard drive when plugged in
I assume the computer recognizes a mass storage device on USB is plugged in and appropriate drivers are loaded. Try on a different computer with appropriate drivers, restart existing computer and plug it in after computer starts. If still fails dismantle device and remove hard disk and try directly in another enclosure. Cannot provide further info without more information.
Jan 15, 2011 | Iomega Computers & Internet
I am trying to trasfer a large amount of files from my macbook to a dell laptop. The mac will recognize the drive and i am able to backup and save files onto it, however when i plug the drive into the...
The problem most likely is the Dell does not recognize the MAC file format (HPFS), but the MAC will recognize the PC's FAT 32 file system.
First format the USB mass storage device using the Dell, format this device in FAT 32 not in NTFS because the MAC can read and write/copy PC format files but the Dell/PC cannot read MAC format files.
Then Safely remove this device, connect it to the MAC and copy the files onto this drive. When you connect this device to the Dell, you will be able to see the files.
Have fun.
Aug 13, 2010 | Iomega Computers & Internet
External hard drive is not detected
Check Following Instructions:
1. Check your USB cable properly connected to the computer.
2. Go to My computer - right click on property - Hardware - Devices Manager - in below - USB Mass storage device - right click on this - and Uninstall - then again right click - click on Scan - it should be reload your USB drivers
your External Hard Drive will be detected
Apr 25, 2010 | Seagate USB 2.0 External Enclosure + 400GB...
My fe 310 didnt recognize by my computer
Make sure the camera is on and pc is selected on the camera screen when connected to the computer. You will need to have PC highlighted and select ok on the camera as this starts the camera and computer to communicate. Once communication established the LCD screen of the camera goes dark and the computer should generate a removable disk drive. Check the System Tray (lower right corner beside the PC time) for Safely Remove Hardware. When you click on it, it should read "Safely Remove USB Mass Storage Device Drive ?:" If you dont see that, then check the Device Manager to see if the camera is recognized as USB Mass Storage Device. The camera uses the driver usbstor.
Apr 24, 2009 | Olympus FE-170 Digital Camera
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
My Olympus FE-340 is not recognized by my PC operating on XP
Aug 06, 2008 | Olympus Cameras
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Sandisk cruzer thumb drive
This just means it is trying to recognize the device. All you need to do is allow it to recogniz the device and find the proper drivers. You can put files in here by going into my computer and double clicking the mass storage device. Files can be draged or copied in here, then taken anywhere you need to go.
Feb 24, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
229 people viewed this question
David Payne
David Payne
