Hard drive crash on dell 2400. Bought new Seagate 500gb hard drive. Installed with sata port to motherboard connected. On BIOS setup enabled sata port to auto, only two selections off/auto. On atempting to boot computer, hard drive not recognized. Primary drive not found. Used jumper pins with and without no success. M.Allen
  • 326 Answers
You will have to install a driver before it picks your sata drive up. when your cd starts to install youll see an option F6 to install sata drivers from a floppy
http://xphelpandsupport.mvps.org/how_do_i_install_windows_xp_on_a.htm
let me know if that guide helps
Posted on Aug 11, 2008
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample below:
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will be furnished after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Serial ATA cables. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the motherboard.
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar if possible.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    May 08, 2014 | ASUS K8V-MX Motherboard
    Just recently my iomega external hard drive is missing on my laptop i goto disc management still not found.pls help me fix this.
    make sure , the HDD is running wen uve connected it . Check the cables for fault . Either should be the problem ,, cables or the HDD power . if both are fine then check your port on the PC or laptop. cross check with other pc. Also see if the ports are enabled in bios and device manager . Check in device manager also for ur HDD
    Jun 01, 2011 | Seagate Momentus 5400.6 500GB SATA/300...
    I got a new SATA 500gb HDD but the motherboard wont detect it.
    Access to your Bios Setup & configure the Bios settings.
    Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
    CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
    Features Setup
    OnBoard Floppy Controller : Enabled
    Serial Port1 Address 3F8/IRQ4 : Enabled
    OnBoard IR Port : Disabled
    Parallel Port Address : 378
    Parrllel Port Mode : ECP
    ECP Mode DMA Chnnel : DMA3
    Parallel Port IRQ : IRQ7
    OnBoard PCI IDE Controller : Both
    OnBoard SATA-IDE
    : Enabled *(Make sure This is enabled)
    Audio Device : Enabled
    Modem Device : Auto
    Ethernet Device : Enabled
    If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
    If your 500GD HDD is not detected, try updating the BIOS!
    A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
    Hope it helps.
    May 14, 2011 | PC Chips M955G Motherboard
    ASUS K8S-MX Motherboard, but when I connect IDE
    How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section. Circe@pctechsonline.com
    Dec 13, 2009 | ASUS K8S-MX Motherboard
    My new 500GB WD SATA internal hard drive isn't recognised
    Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
    Nov 19, 2009 | Computers & Internet
    Harddrive is not detecting bios
    get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
    Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
    Apr 10, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
    Unrecognized HDD-- need help!
    You could also try setting the jumper on the hard drive to "limit to 1.5gb/s".
    Oct 04, 2008 | ASUS K8V-MX Motherboard
    Does Asrock P4VM8 support 500GB SATA hard disks?
    near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
    Jun 23, 2008 | Asrock P4VM8 Motherboard
    Dell Dimension 2400 with secondary SATA hard drive keeps crashing
    generally all computers can handle a secondary hard drive. i myself am a dell tech. why not try to increase the wattage output of your power supply from the present 200 or 250 watts to at least 300 or 350 watts to give enough provisions for additional devices that will be connected to your computer. normally a hard drive will get burned or fried because of a loose power cable connection. data cable will never fry your hard drive. try running the hard drive diagnostics if it passes then it should work well. try also using chkdsk /r in the command prompt to fix your hard drive if the damage is not that extensive.
    Jun 20, 2008 | Dell Dimension 2400 PC Desktop
    Problems Installing my 160 GB Seagate SATA HDD
    Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
    Sep 24, 2007 | ASUS P5RD1-VM Motherboard
    Computers & Internet Logo
    113 people viewed this question
    David Payne
    David Payne
