Hi tieisaj
You'll need to install the network card driver (otherwise known as "ethernet controller") so that you can get internet access.
Here is the location to download the drivers, but make sure you choose the correct operating system since generally theyr'e not compatible with each other. For example, don't use a Windows XP driver if you're running Windows 7.
Google search terms were "HP Compaq d530 drivers"
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
Hope this helps
-BuzzPuppy
Look in device manager, click on network adapter, right click on the controller which is installed in your system, select properties and make sure it is enabled, as at times it gets disabled. If it is enabled you can try to disable and then enable. You can also try reinstalling the driver for the controller. I hope this helps. Good luck and have a pleasent day.
