Question about Dryers
CHANGING A BELT
HOW DO I CHANGE THE BELT ON MY DRYER, THE MODEL NUMBER IS AWZ7813.
IVE TOOK THE BACK OFF AND I CANT SEE HOW I CAN GET TO THE DRUM????
THE NEXT THING I CAN TAKE OFF IS SOME BOLTS WHICH HAVE ELECTRIC WIRES ATTACTHED TO IT.
IV JUST READ ABOUT RELEASING THE TENSION ARM BUT I CANT SEE ANYTHING LIKE THAT.
CAN YOU PLEASE HELP ME?????
I'm looking at the same problem with my Kenmore. You access from the front on mine. I had two screws under my pull out lint filter that I had to remove then pry up the top, stiff putty knife might be needed. Mine just pull up. Then I had one screw on top left inside front cover and once that was off the door can be lifted slightly on the left side then swung open. Use a bungee cord or someone to hold the tumble barrel up. You should be able to see everything from floor level.
Posted on Dec 16, 2008
How to change drum belt on a maytag dryer
The belt changing is fairly the same across all brands and models, The issue come down to your model number and how to access the belt via panel removals. Can you provide the model number? (Hope you've repaired it by now)
Sep 26, 2014 | Maytag Neptune MDG5500AW Gas Dryer
What is the fabric type belt on the front of the drum drum used for ?
that's the drum seal,that isn't a good model number,you have to replace the drum seal gasket,it holds the heat in the drum and also the clothes,if it isn't torn you can glue it back on,there should be another seal on the back of drum too.go here,put the model number in and you can look at all the parts in your dryer.
https://www.searspartsdirect.com/model/search.html?q=AWZ%203303
open the door,look around the opening where you put the clothes in and you'll see the tag with the model number
Dec 20, 2017 | Whirlpool Dryers
The belt is broken and we need a replacement for it.
Hi and welcome to FixYa, I am Kelly
Go to any of these sites and enter your model number:
http://www.searspartsdirect.com
http://www.appliancepartspros.com
http://www.repairclinic.com
If you have difficulty locating your belt I need your complete model number and will use those same sites to find your belt for you. There are 2 different sized belts for a whirlpool dryer depending upon the model number. 27 inch dryer and 29 inch dryer.
Download this manual to help you change the belt:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The order of removal is the toe panel, top and then the front panel to gain access to change the belt.
Toe panel (page 15 / pdf file page 20)
Top panel (page 14 / pdf flie page 19)
Front panel (page 19 / pdf file page 24)
Make sure you inspect the drum seals (felts) and the the drum rollers in the process of changing the belt.
The manual link I passed is for the 27 inch dryer but access is exactly the same for the larger dryer.
Thanks for choosing FixYa,
Kelly
Mar 30, 2011 | Whirlpool Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
How do I change my dryer belt on 1994 MAYTAG dryer?
Assuming this is stand alone front loading dryer, to replace the belt, you access the drum from both the back service access panel and the top. Pop the top at the front corners and it will hinge up at the back.
Reply back with the make and model number of your specific dryer and I can help you more.
Dec 17, 2009 | Cars & Trucks
Drum belt assembly
take the belt and put it around the drum with the grooves touching the drum, then push a loop of the belt thru the idler pulley bracket and hook it onto the motor pulley. then the idler pulley and bracket will cause tension on the belt. if you need to see a picture then search your model number on google and it should show you a picture of how the belt goes around the motor.
by the way you dont have a good model number, or it is too new to be in most web sites.
Jan 22, 2009 | Kenmore 72802 Gas Dryer
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Jan 21, 2009 | LG DLE2512W Electric Dryer
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
How to change a drive belt on a candy CDC266 tumble dryer
don't know what make you have but if you go to sears .com click on parts put in your model number(inside dryer door)you will find a break down of everything you need to know,let me know how you do-mike
Oct 12, 2008 | Candy CDC266 Dryer
Dryers Logo
124 people viewed this question
Top Dryers Experts
